ANN coverage of the P-51 landing accident at OSH...
Old July 31st 07, 01:43 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
B A R R Y[_2_]
Default ANN coverage of the P-51 landing accident at OSH...
Here's a good set of photos of the accident showing a different perspective
than the video we've seen.
Check out the prop damage on the blue turtle deck.
Old July 31st 07, 02:09 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Peter Dohm
. net...
perspective
Scott Wilson
http://flickr.com/photos/lscan/sets/72157601065523576/
In the video, it really looked like the situation had already deteriorated
more than a quarter mile out, and then it just continued to get worse. (And
the assumptions which I initially made are now in serious doubt.)
That further amplifies a question that I have for Dudley:
You mentioned a distinction military and civilain pilots; and I can think of
several possible reasons: the civilians pilots are usually older, less
experienced in type, and formation flying is not part of their primary
occupation--but I suspect that there is something even more basic that I am
leaving out.
Peter
Old July 31st 07, 04:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Dudley Henriques[_2_]
Peter Dohm wrote:
. net...
perspective
Scott Wilson
leaving out.
Peter
Yes. It's so basic it has a tendency to lose itself in analysis.
The military was just as aware as everyone else about the hazzards
associated with section landings. Putting multiple airplanes on the same
runway landing at the same time has obvious risks. If lead for example
blows a tire on the side the trailer is landing on, the resulting swerve
could be a real issue. Judgment and unforseen incursions on the runway
are also considerations. The list of possible issues is indeed long and
filled with pot holes that could spoil your day.
The military however has a problem we as civilians don't have. They have
a situation that involves time. In combat, there is always the issue
of getting multiple aircraft on the ground quickly and turned around,
rearmed and refueled and back into the air again. Also, there is the
issue of vulnerability. Fighters slowed down to pattern speeds and dirty
are duck soup for attacking enemy fighters.
For the reasons I've stated above, the 360 overhead approach was
initiated by the military. The objective of this type of approach is to
space close in and tight, keep the pattern speeds up, and get the birds
down as quickly as possible. Section landings became an integral part of
this scenario and was accepted and is accepted even today as a
reasonable risk factor considering extensive flight training and
awareness of the pilots doing this work.
It is worthy of note that even in the military, landing prop tailwheel
fighters this way was considered a far greater risk factor than landing
high performance nose wheel jet fighters; the reason being the loss of
visual cues for the wingman landing next to his element lead.
Now enter civilians with a few bucks and flying P51 Mustangs and you
have a situation where the time factor is no longer present in the
section landing equation. The powers that be who set up training
schedules for these pilots in these aircraft know quite well the dangers
of section landings in prop fighters. For this reason, organizations
like Warbirds of America and EAA and the T34 Formation Training Syllabus
specifically note that section landings in P51's are NOT considered to
be safe enough to warrant the risk factor.
So this is basically how it works. If you own a P51 and you have taken
the trouble to seek out and take the suggested training given by people
who know what they are doing, you don't attempt section landings in P51
aircraft.
There is no law however that MAKES the P51 owner attend these classes.
The result I believe, we have seen with this latest accident at Oshkosh.
Both of these pilots were good sticks in these airplanes. It saddens me
to know that this accident was so damn preventable simply by following
basic information and training readily available for pilots flying P51
Mustangs, and in play as we speak.
Dudley Henriques
Old July 31st 07, 05:09 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Peter Dohm
"Dudley Henriques" wrote in message
deteriorated
(And
think of
am
leaving out.
Peter
aircraft.
Dudley Henriques
That's almost the proverbial "elephant in the room" which has been present
so long that it seems to dissappear. I did not even consider the need to
get assets quickly inside a ground defense perimeter and on the ground with
a minimun loss of speed; and then, if necessary, relaunch an air defense as
rapidly as possible.
Thanks again for the much needed observations.
Peter
Old July 31st 07, 05:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
My pleasure. Sorry it has to be under such bad circumstances.
DH
deteriorated
(And
think of
am
leaving out.
Peter
aircraft.
Dudley Henriques
Peter
Old July 31st 07, 10:24 PM posted to rec.aviation.piloting
Big John
Dudley
Our pilots used to catch the German fighters (and jets) in pattern and
run their score up. Shooting fish in a barrel.
Never flew an overhead pattern until after the War that I can
remember.
The pitch off the deck was the procedure used until after War and the
accident rate doing that became excessive and they changed to the
overhead.
An off the deck pitch let you make a touch down after about only 15
seconds from the pitch
350 mph on approach. Throttle idle on pitch and pull up TIGHT in turn
to bleed off airspeed. After 180 degrees of climbing turn your
airspeed was down to where you could put down full flaps and drop
gear, continuing the last 180 degrees of turn to align with runway and
then touch down at normal touch down speed.
A pitch up almost killed me. Came back to base just after take off
with a leaking fuel cap. Made the normal tight pitch up (forgot I was
heavy with fuel) and bird stalled in last 90 degrees of turn. I rudder
walked the bird down and hit on right main gear and right aileron.
Took around and was much more cautious next landing. If I haven't been
a good and LUCKY pilot would not be here today (
Nice dry day here in Houston today.
Big John
On Tue, 31 Jul 2007 11:24:02 -0400, Dudley Henriques
Peter Dohm wrote:
. net...
perspective
Scott Wilson
leaving out.
Peter
aircraft.
Dudley Henriques
Old July 31st 07, 10:45 PM posted to rec.aviation.piloting
Hi John;
That approach is what we called a 360 Tactical overhead approach. I used
a variation of it as a finishing touch on my demonstration in the 51 and
also on arrival at a show site weather and ATC permitting :-)
I used 300 at 46 and 27 and pitched off the deck into a straight 45
climb line roll set. Neutralizing, I immediately initiated a 270 degree
roll to the opposite side of the downwind leg (pattern left/roll right)
I stopped the roll at 270 by stomping on the top rudder and holding in
firm forward stick. This stopped the airplane at the second knife edge
solidly. At that point I blended in back pressure using top rudder to
hold nose position through the transition from climbing knife edge into
the turn to downwind at 1500 feet AGL. The rest was your standard
circling close in turning approach in the 51 keeping the power up so as
not to foul the plugs.
If this approach was done just right, it was beautiful to watch from the
ground and was extremely good for maintaining visual cues in the cockpit
for me. Once I had things slowed down to 160 and had 20 degrees of flap
and the gear lights on the bird, the rest was just keeping it in close
and turning milking in the flaps until full down on final.
Over the fence at 120 or a bit less and tail low on the mains.
The main thing crowds liked with this approach aside from the roll was
the sound you always got with the 51 low, fast, and at METO.
Dudley Henriques
Big John wrote:
Dudley
remember.
overhead.
Big John
Peter Dohm wrote:
. net...
perspective
Scott Wilson
leaving out.
Peter
aircraft.
Dudley Henriques
Old August 1st 07, 03:33 PM posted to rec.aviation.piloting
Big John
Dudley
OK show off )
We used between 300-350 mph as that was a good increase from our
cruise speed of 230-240. The Merlin at METO was certainly a sweet
sound )
Starting off the deck we probably got back up to 500-600 feet max in
pattern.
Of course we were not trying to put on an airshow. Lots of things you
could do in bird to impress the 'great unwashed masses' )
The thing I missed most was the "plop, plop, plop" of the Merlin at
idle in pattern before they stopped the full idle because it was
sucking cold air in and warping the valves.
Looking at the clip many more times you can see #2 angling in toward
#1 well prior to contact. Only way I can see that happening is that #2
lost sight of #1.
Transmissions will help NTSB sort that out.
I'm going to quit making surmises based on part of the data. The more
I look at clip the more I see that could be the root cause.
Think we have pretty well covered the basic P-51 flying. Am sure yours
was light and the ones I flew were heavier, always with ammo, full
fuel, etc. If I were doing an airshow I'd not put any fuel in fuselage
tank to keep the CG within proper limits and not have to burn tank
down. Could do more with a light bird vs a heavy one.
Hope your health is progressing in good shape. I started Omega 3, on
my own, for my heart and I got so dizzy I could hardly walk. Stopped
yesterday and feel much better today.
The very best.
Big John
On Tue, 31 Jul 2007 17:45:21 -0400, Dudley Henriques
Hi John;
Dudley Henriques
----clip----
Old August 1st 07, 03:48 PM posted to rec.aviation.piloting
Health is hanging in there John; the back is a mess and I'm adjusting to
cataract surgery changes but aside from that I'm still able to put one
foot in front of the other :-)
You're right; my bird was lighter. I had no fuselage tank in the
airplane and tried as well to have the fuel in the mains balanced out at
about 50 gals maximum for demonstration work. If I was heavy I had to
compensate for that naturally.
I agree. We've beaten the 51 issue to death on what data is available.
I've looked at another angle of the crash and I totally agree with you
that the A slanted in and hit the D with the prop through the corner of
the stabilizer and sliced it nearly in half behind the cockpit.
The violent snap of the A at impact had to be a combination of control
input reflex and some extremely strong physical forces caused by the
prop impacting the D.
Anyway, as you say, even old hands like us are just guessing. The final
report will include the radio transmissions and that should fill in a
lot of blanks.
Take care. I'm glad you're hanging in health wise. Remember, to stay
young, "Climb High" "Fly Fast" :-)
Dudley
Big John wrote:
Dudley
OK show off )
sound )
pattern.
lost sight of #1.
The very best.
Big John
Hi John;
Dudley Henriques
----clip----
Old August 1st 07, 10:05 PM posted to rec.aviation.piloting
Big John
Dudley
My back is also bad. I use "capsaicin", Pepper Juice. I tolerate it
well and can add additional applications as I need to control the
pain. I use it both at neck and lower back. If you haven't tried and
want to send me your mail address at my home e-mail address I'll send
you some. It can get warm like jock strap lotion.
My catract surgery is also giving me problems. Couple of months ago
said come back in 3 months. Want to get some decent eyes (20-10) back
to fly.
Take care.
John
On Wed, 01 Aug 2007 10:48:55 -0400, Dudley Henriques
lot of blanks.
Dudley
Big John wrote:
Dudley
OK show off )
sound )
pattern.
lost sight of #1.
The very best.
Big John
Hi John;
Dudley Henriques
----clip----
Gear Up, pt 6 - P-51D from 353rd FG at Raydon has a landing accident.jpg (1/1) Mitchell Holman Aviation Photos 0 April 19th 07 03:31 AM
Mustangs of Old, concluded - P-51D from 353rd FG at Raydon has a landing accident.jpg (1/1) Mitchell Holman Aviation Photos 0 December 30th 06 03:52 AM
Six aboard USS Kitty Hawk injured in F/A 18 landing accident Otis Willie Naval Aviation 0 January 31st 05 10:50 PM
B-17 landing accident today, Van Nuys, Calif. Paul Hirose Military Aviation 21 May 17th 04 06:07 AM
C172S Landing accident Greg Esres Piloting 53 August 4th 03 03:44 PM
