T-6 landing on Hwy 41 at OSH
Old August 1st 07, 04:55 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default T-6 landing on Hwy 41 at OSH
RST Engineering wrote:
Unmitigated bushwa. Most aircraft engines (fixed pitch & CS prop)
will stop the prop at normal glide speeds.
Never had an engine failure, have you?
Also just shutting off the engine doesn't stop the prop from
windmilling. To do that you have to have a prop that fully feathers
and even then they don't always stop fully.
As a matter of fact I have. In a 172 and the prop continued to spin until I
was on the ground and didn't stop until the AS was about 45.
Old August 1st 07, 07:41 PM posted to rec.aviation.piloting
Mark T. Dame
Unmitigated bushwa. Most aircraft engines (fixed pitch & CS prop) will stop
I have, and the prop kept spinning. I didn't know the engine was dead
until I went to add power and got nothing.
-m
## Mark T. Dame
## CP-ASEL-IA, CFI-A, AGI
## insert tail number here
## KHAO, KISZ
"The gene pool has no lifeguard."
Old August 1st 07, 07:49 PM posted to rec.aviation.piloting
Gig 601XL Builder
-m
That makes it 3 to 1. You might try adding oil now and then.
Old August 1st 07, 09:38 PM posted to rec.aviation.piloting
Al G[_2_]
"RST Engineering" wrote in message
Many. Never had a prop stop until after I landed. Even the Aeronca Chief
wouldn't do that.
Al G
Old August 2nd 07, 02:27 AM posted to rec.aviation.piloting
Kyle Boatright
Every chance, Bob. Back in the '60s when I did my primary training it was
quite common for the instructor to pull the plug over the airport and have
you "make" the field. The prop on the 0-200 150 stopped at best glide
speed.
In the O-300 172 I took into the bridge at Grass Valley with dual mag
failure, the prop stopped at best glide speed.
In the O-470 182 I put onto the dragstrip at Hanna with a blown jug, the
Sorry, them's the facts.
My experience is different. When I did prop stopped glide testing in the
RV-6, I had to go well under 60 knots indicated to get the prop to stop. And
I fly behind a wood prop which has very little inertia. A metal prop would
have probably windmilled at an even slower speed.
KB
Mig-15 landing Glenn[_2_] Aviation Photos 0 April 12th 07 01:50 PM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
landing franck jeamourra General Aviation 1 February 10th 04 01:29 PM
landing franck jeamourra Owning 1 February 10th 04 09:29 AM
