Alloys for certified parts?
Old August 1st 07, 02:54 PM posted to rec.aviation.homebuilt
Fred[_3_]
Default Alloys for certified parts?
On Aug 1, 12:17 pm, "Morgans" wrote:
"Vaughn Simon" wrote
... As an LSA, tt is certified to an industry standard, not an FAA
standard. I recently checked out in one and it even has a "warning" in
the cockpit to that effect.
Yes, BUT don't let that warning read with too much meaning, either.
there are many, many homebuilts that far exceed the FAA
standards. Some of the quality in homebuilts make certified aircraft look
like erector set airplanes, in comparison. g
Of course. As I pointed out to the Bradley Aerospace
(Bradley Aerobat) company rep, 6061 T6 has 95% of
the yield strength of 2024 T3, and better corrosion
resistance so that you can make back some of that
minor weight penalty by using less paint.
He keeps harping on how 6061 is not "aircraft aluminum".
So I asked him which standards organization sets the
standards for "aircraft aluminum". His response to that
was to delete my earlier article comparing 2024 to 6061.
http://groups.msn.com/bradleyaerobat
As far as I can tell, "aircraft aluminum" is marketing hype
used to promote non-aviation products to a naive public.
As such, the term fits right in with Bradley Aerospace's
approach to marketing.
FF
Old August 1st 07, 03:06 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 31 Jul 2007 22:42:40 -0700, John Kimmel
On Jul 31, 4:03 am, Dave wrote:
I have run across someone who insists that
6061 T6 is not "aircraft grade aluminum".
He claims that there are no certified parts made
from 6061. I find that hard to believe. Aren't there
certified aircraft with welded aluminum frames?
That is a pretty broad statement.
Parts are made from any materials that the manufacturer
desires/specifies. Wood, aluminum, brass, glass and anything in between.
That includes 6061 of all tempers.
That is kinda what I thought. I'd like to find some specific examples
of certified aircraft parts made from 6061. I took a gander at
Aircraft
Spruce's online catalog, but the search function isn't set up for
that.
I'm thinking that certified metal props will probably be 6061 too.
FF
Main rotor blade and tail rotor blade spars and skins for Sikorsky S-61
and CH-53 are 6061-T6
the Fokker friendship was built from 6o61 as are the chris heintz
designs.
metal props are usually 2025.
Stealth Pilot
Old August 1st 07, 10:03 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Morgans" wrote in message
While I believe you are on the winning side in your argument about
aircraft materials, the Zodiac may not be the best example to prove your
point. As an LSA, tt is certified to an industry standard, not an FAA
standard. I recently checked out in one and it even has a "warning" in the
I don't, or I wouldn't have bothered checking out in the plane. My comment was
only to point out that the OP might want to find a more bulletproof example to
prove his point.
Vaughn
Old August 1st 07, 11:42 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Bingo !
Old August 2nd 07, 12:56 AM posted to rec.aviation.homebuilt
Dan[_2_]
Bingo !
Remember "parachute luggage" from the 1970s? "Made from the same
material as Air Force parachutes."
Dan, U.S. Air Force, retired
Old August 2nd 07, 02:55 AM posted to rec.aviation.homebuilt
On Aug 1, 8:06 am, Stealth Pilot
Aircraft
that.
FF
designs.
Stealth Pilot- Hide quoted text -
- Show quoted text -
The Cessnas I work on every day have a lot of extruded angle
in them, and I bet much of it is 6061T6. Perhaps the spar caps are
2024T3 extrusions.
Dan
Old August 2nd 07, 04:52 PM posted to rec.aviation.homebuilt
Bill Chernoff
Yep. Like "surgical steel".
Old August 2nd 07, 10:15 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
designs.
2024T3 extrusions.
Any welded aluminum is unlikely to be 2024.
I have heard that DC-3s used 6061.
FF
Old August 4th 07, 04:29 AM posted to rec.aviation.homebuilt
Maxwell
ps.com...
Seems like the drop tanks on the F-15 were 6061, they were certainly
weldable. Possibly the early Harriers too. Been too many years to recall for
sure. I welded on both of these programs at McDonnell Douglas, back in the
70s.
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
"certified' parts Jimmy B. Owning 51 March 18th 05 06:04 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 02:20 AM
