Juvat wrote:
Zajcevi posted: snip Was it sole USAF test or also USN fighters were involved? USAF and ANG it would appear. And was also simulated by some types (possibly F-106 like on Top Gun)? Not according to this article. I can hear the conversation now -- "You're thinking of mentioning our mortal enemy, the USN, and their participation in Featherduster in the FWR? How well do you like your career?" F-8s were the only a/c that gave the F-104s trouble, at high altitude/subsonic where the F-8's wing loading rules. The F-8's were also flying an early form of Loose Deuce (The 104s were flying Double Attack). Guy P.S. Do the articles you found describe the F-104 tactics used against the F-86Hs? I've got that. |
Guy Alcala posted:
P.S. Do the articles you found describe the F-104 tactics used against the F-86Hs? I've got that. I don't...I have a couple "Double Attack" articles from FWR (1971 I think)...with editor's note at the end of each reminding readers that Fluid Four is how to get the job done. But I do have a few F-4 RTU manuals from 1966 the dearth of air-to-air information is nothing short of amazing. [Kinda like the first couple versions of the F-16 Dash 1...comic book length.] Then you contrast that to the MCM 3-3 (an unclassified airplane specific behemoth manual) from the 80's...amazing. Specifically I have TACM 51-6 Aerial Combat Training, AFM 51-34 F-4 Aircrew Training (Tactical Fighter), TACM 55-4 v1 F-4 Aircrew Operational Procedures, plus three Phase manuals from MacDill's RTU course. Juvat |
Juvat wrote:
Guy Alcala posted: P.S. Do the articles you found describe the F-104 tactics used against the F-86Hs? I've got that. I don't...I have a couple "Double Attack" articles from FWR (1971 I think)...with editor's note at the end of each reminding readers that Fluid Four is how to get the job done. Snip info on pubs. Thanks Well, to give you the short version, if the (1 v. 1) Zip started on the defensive (420 kts)at low altitude, they'd go negative-G into ground clutter until reaching about 1.1M, making rapid banking reversals to prevent gun/missile shots (rare, as the F-86 pilots found it almost imposssible to reverse and get into a gun/missile envelope owing to their low speed after the defensive break and the negative closure on the accelerating 104s). Once out of AIM-9B/Atoll range, they'd begin a climbing turn at about M1.0 and 2g; typically, by the time they'd reached 180 deg. of turn the F-86s would have lost sight, and the F-104s would go offensive. When offensive, they'd start their pass at a minimum of 500-600Kts, which would allow them to pull up to 5g sustained (more got into buffet) and track the 86s for a gun shot, allowing speed to bleed down to no lower than 400 knots (Note that they'd only turn with the F-86s when the latter were fast, .7M; otherwise, they just made slashing attacks) before quarter rolling away, and proceed as for the defensive separation above. Same basic procedures for 2 v. 2 and 4 v. 4, except that double attack was used and the offensive passes were usually started at 1.1M and speed wasn't allowed to go below 500 kts. For the high altitude combats (35kft. start), the same basic technique was used, except that the initial dive and separation was steeper (ca. 40 deg.) until reaching M1.4 or so @ 10kft, then proceed as before. At both high and low altitude, once the 104s got their energy up after the initial defensive start they were never defensive again. As far as Tom knew, there was only a single, iffy kill called on the 104s by the 86s. One pilot started his climbing spiral a bit early, and the 86 pilot was able to get a tone at about 2,000 ft. range with negative closure. The range officer agreed that the shot was edge of the envelope, but the Zipper pilot admitted that he'd made a mistake and would have had to break if a missile had been fired. Guy |
Guy Alcala posted:
Well, to give you the short version... As always, much obiliged. Juvat |
Guy Alcala wrote: Snip:
P.S. Do the articles you found describe the F-104 tactics used against the F-86Hs? I've got that. Snip: Guy, I'd like to see that 104/86H piece, if it's not too much trouble. BTW I tried to send you a message but 'postoffice.pacbell' refused it. Walt BJ |
Walt BJ wrote:
Guy Alcala wrote: Snip: P.S. Do the articles you found describe the F-104 tactics used against the F-86Hs? I've got that. Snip: Guy, I'd like to see that 104/86H piece, if it's not too much trouble. BTW I tried to send you a message but 'postoffice.pacbell' refused it. Is my reply to 'Juvat' giving the 'short' version, adequate? There was much repetition describing the 1 v.1, 2 v.2, and 4 v. 4, so I was able to condense quite a bit. Besides, you already know the result; the Zip kicked butt;-) Of course, damn near any supersonic fighter with adequate fuel should be able to control the engagement against a subsonic bird like the F-86 if they can avoid the initial attack, although an F-100 (and I imagine the F-102) would probably find things a lot tougher. The F-86 pilots said the 104s were the toughest opponents they'd faced (they'd already gone up against F-100s, F-102s, F-105s, and F-4Cs), and were quite impressed with the 104's ability to sustain high g turns at speed. Despite their better radius, the 86s were unable to cut the corner to take shots, because the 104s stayed fast while turning. Guy P.S. Losing "postoffice.", (plus the obvious Spam trap you'd already deleted) and keeping the rest should work. |
Thinking about getting my IFR rating - Written test programs???? | Grey Stone | Instrument Flight Rules | 6 | July 22nd 03 01:08 AM |
