Stryker/C-130 Pics
Old September 20th 03, 03:32 PM
Kevin Brooks
"Paul Austin" wrote in message . ..
"Kevin Brooks" wrote in message
om...
"Tony Williams" wrote
I understand that basic Stryker is right on the size/weight
carrying
limits of the C-130. Any info on how the Herc will cope with the
bigger versions, like the one carrying a 105mm gun?
By buying A400Ms?
Seriously, the Stryker (idiot spelling)
Maybe because it was named for a fellow (MoH winner IIRC) named
Stryker?
sacrifices too much for C-130
compatibility, particularly in the area of protection.
How can you support that? The amount of protection required is
dependent upon a number of factors, including specific threat,
operational terrain, etc. And applique/bolt-on armor is an option if
required. Not to mention that *some* deployable protection is a bit
better than what we have now, which is pretty much limited to the
kevlar vest and helmet mounted on the crunchies.
The MagicTech
remote sensing/remote fires stuff isn't ready yet, never mind
"electric armor" that's needed to make what amounts to a LAV
mounted
army viable.
Huh? Why is this required to make it "viable"? The USMC has found
their LAV's to be very much "viable" in places like Panama,
Afghanistan, and Iraq--ISTR that the Army folks were quite jealous
of
the LAV in Panama.
And the Marines augmented their LAVs with what? As an adjunct to a
heavy armor core, LAVs have great mobility and reliability (a lot more
than the LVTP7s which had serious electronics reliability problems for
lack of water cooling on the hull).
Calling the LVTP 7 "heavy armor" is quite a stretch if you are
considering the survivability/protection issue. Fact is that the LAV
affords Army early entry forces with a level of protection and ground
mobility, not to mention firepower, that they do not now enjoy;
therefore its use on an interim basis is of benefit to those forces.
If the Army is to be both rapidly deployable and as
effective on the ground as it currently is, then much more capable
airlift is required. In fact, A300M is too small (only marginally
larger box or payload than a C-130). What's needed is Pelican or
LTA
kind of solutions.
That would presumably be "A400" which you are referring to. I
believe
you are ignoring the fact that we currently have *no* airborne armor
deployment capability to speak of, and the Stryker will provide
additional versatility to an Army that is currently capable of
either
light or heavy operations, but lacks the ability to deploy *more*
survivable, and lethal, assets into an AO by air to fill that large
void that exists between "light" and "heavy". Not to mention that
ever improved ISR and attendant targeting capabilities make the
LAV-based force more lethal than you give them credit for.
Take a simple scenario where an early entry ground force is tasked
to
provide an urban cordon/containment/evac element to support a SOF
raid
(sounds a bit like Mogadishu, huh?). What method would you
prefer--travel by HMMWV or foot, or travel and support from
Strykers?
Kind of a no-brainer.
The Army and the Marines have gamed light and medium forces augmented
by sophisticated communications and fire support significantly in
advance of the Stryker brigades fought conventional mech opponents.
What got found was that if _everything_went right, the US forces did
OK. If_anything_went wrong, the US forces lacked the resilience to
recover and prevail. In particular, the Marine games found that if the
opponents targeted communications and fire support nodes that
defeating the US forces was pretty easy.
Kind of hard to target mobile fire support assets. How easy would it
be for an enemy lacking even air parity to target HIMARS? But the real
question is, how would those same games have played out if it was our
*current* early entry force (i.e, light infantry only) that had to
deal with that same threat? Much worse, that's how.
And you never answered the question--do you want those air deployable
LAV's in this scenario, or do you want depend upon bootleather and a
few HMMWV's? How about during the urban fight in general--do you want
to be solely dependent upon helos and unarmored vehicles, or do you
want that added capability that the moderate protection afforded by
the LAV gives your assaulting infantry force? These appear to be
no-brainers to me.
As far as deployability is concerned, as usual people forget
logistics. The Stryker brigades have a smaller logistics footprint
than a heavy mech brigade because of reduced POL requirements but the
remaining beans and bullets have to come by boat. If that's the case,
then send the heavy mech units the same way
No, they don't *have* to come by boat, especially in the early stages,
which is after all when the SBCT's are going to be most valuable. The
Marines deployed LAV's into Afghanistan--how many boat docks in Afghan
land? Just how would you have sent those heavy mech units into that
country? Roll through Pakistan first? I don't think so... And even
when port facilities can be seized, there is no assurance that they
will be usable in the short term--witness the time required to open
that Iraqi port to friendly shipping? The SBCT fills a niche; no, it
can't do everything, but by golly it is better than having to depend
upon the poor bloody light infantry for *everything* during the early
entry phase, too. The Stryker is an interim vehicle, to be fielded to
no more than what, three to five brigades in the total force? Sounds
like it has a lot to offer to the current mix of available forces,
which are either too heavy for rapid deployment, or too light to
survive in higher intensity scenarios.
Brooks
Old September 19th 03, 06:50 AM
John Keeney
om...
I understand that basic Stryker is right on the size/weight carrying
By buying A400Ms?
Stryker?
Most common reply when asking folks working up the Stryker
their opinion: "It tolls real nice."
Old September 20th 03, 03:34 PM
Kevin Brooks
"John Keeney" wrote in message ...
om...
By buying A400Ms?
Stryker?
Tolls?
Brooks
Old September 18th 03, 04:48 PM
Tony Williams
By buying A400Ms?
Seriously, the Stryker (idiot spelling) sacrifices too much for C-130
compatibility, particularly in the area of protection. The MagicTech
"electric armor" that's needed to make what amounts to a LAV mounted
army viable. If the Army is to be both rapidly deployable and as
larger box or payload than a C-130). What's needed is Pelican or LTA
kind of solutions.
You surprise me. Somewhere I have an article providing detailed
comparisons between the C-130J, A400M and C-17, and IIRC the A400 is
about midway between the other two in both the dimensions and weights
of the loads which could be carried; in other words, substantially
better than the C130.
Tony Williams
Military gun and ammunition website: http://www.quarry.nildram.co.uk
Military gun and ammunition discussion forum:
http://forums.delphiforums.com/autogun/messages/
Old September 18th 03, 05:22 PM
JT
By buying A400Ms?
kind of solutions.
They should have cancelled the Stryker program and invest the money on
further developing the FCS. With the right mix of technology, a viable
lighweight option can be made. It will never offer the same level of
armor protection as an M1A2 but that is not it's intended purpose.
With new lightweight metals, composites and ceramics used in critical
areas, combined with speed, manuverability, stealth features and
active counter measures the FCS seems like it will be very effective
at its role.
-----JT-----
Old September 19th 03, 12:04 AM
Kevin Brooks
(JT) wrote in message om...
By buying A400Ms?
kind of solutions.
at its role.
And what do you propose to send the troops into combat in until 2010
or later (realistic estimate of widespread fielding is more in the
2012-2015 timeframe last I heard), when FCS becomes operational?
Stryker is an *interim* solution--it has always been identified as
such (even the Stryker Brigade Combat Team was initially designated
the "Interim Brigade Combat Team"). The Army needs a deployable light
armored capability *now* to carry the load until FCS becomes
available.
Brooks
-----JT-----
Old September 19th 03, 05:26 PM
JT
(Kevin Brooks) wrote in message . com...
at its role.
available.
Brooks
I understand that this is an interim force...more of a reason why we
should stop pouring all this money for equipment that will only be
used for 8-10 years at most. If more funding went to the FCS the 2010
timeline may be more realistic. I have read reports that some
technologies are still a few years away but the FCS is intended to be
modular so as soon as those technologies are developed they will be
added to the system. Anyways, a baseline FCS will probably surpass the
Stryker/Piranha III design. I know warfare is rapidly changing (the
main reason why the US is going through these major changes with all
it's branches of the armed forces) but we could probably keep the
forces we currently have for a few more years until the FCS comes out.
To make matters worse there is still controversy as to just how
portable the Stryker is inside a C-130 and the level of required
protection has so far been dissapointing.
Basically my thought is why not save resources and instead of having
the small upgrade, just hold on for a few short years and upgrade our
current forces while concentrating more on the true leap that the FCS
will provide.
-----JT-----
Old September 21st 03, 04:48 AM
phil hunt
By buying A400Ms?
What's this? Is it related to the "battlefield Internet" I've head
about?
"electric armor"
And this?
ITYM A400M.
A: top posting
Q: what's the most annoying thing about Usenet?
---California International Air Show Pics Posted!!!! Tyson Rininger Aerobatics 0 February 23rd 04 11:51 AM
TRUCKEE,CA DONNER LAKE 12-03 PICS. @ webshots TRUCKEE_DONNER_LAKE Instrument Flight Rules 3 December 19th 03 04:48 PM
Aviation Pics Tyson Rininger Aviation Marketplace 0 November 7th 03 01:04 AM
b-17C interior pics site old hoodoo Military Aviation 0 September 15th 03 03:42 AM
Nam era F-4 pilot pics? davidG35 Military Aviation 2 August 4th 03 03:44 PM
