The F-16 control stick?
Old September 21st 03, 04:48 PM
Christopher
On Sun, 21 Sep 2003 09:31:13 -0600, "Tex Houston"
"Christopher" wrote in message
On Sun, 21 Sep 2003 13:06:29 +0100, "Simon Robbins"
Initially it was a force-sensing stick, but later they added some
"play"
to
it.
By *play* how many degrees can the pilot now move it?
Check out http://www.ultra-msi.com/mini.html, a supplier to the aerospace
industry of force-joyticks.
Just did and got this:
The page cannot be found
The page you are looking for might have been removed, had its name
changed, or is temporarily unavailable.
I tried and got the correct page.
Me to without the /mini.html I then put the /mini.html in and it
loaded fine.
Christopher
"Kites rise highest against
the wind - not with it."
Winston Churchill
Old September 21st 03, 07:23 PM
GregD
It is also interesting to note that the amount of force applied to, or
deflection of, the control stick does not translate into xx degrees of
control surface deflection. The stick inputs are seen as rate inputs,
not deflections, so when you want to roll faster you apply more force
to the stick and the control surfaces deflect whatever amount it takes
to achieve that rate. This is also the reason you don't have to tweak
the stick in the other direction to stop a roll or pitch rate. When
you release force on the stick, the control system senses a zero rate
input and the roll (or pitch) stops right then and there. Hope that
makes sense.
GregD
Old September 22nd 03, 12:46 AM
Air Force Jayhawk
All are quite welcome
AFJ
On Sun, 21 Sep 2003 09:15:52 GMT, (Christopher)
On Sun, 21 Sep 2003 04:59:59 GMT, "Earl Heron"
Thanks for the thoughtful post, Ross. Joe Bill's article was fascinating!
Yes, it's very informative, thanks.
"Air Force Jayhawk" wrote in message
http://www.codeonemagazine.com/archi...ct_86/cockpit/
Explains it better than I can...
Ross "Roscoe" Dillon
USAF Flight Tester
(B-2, F-16, F-15, F-5, T-37, T-38, C-5, QF-106)
On 20 Sep 2003 18:54:19 GMT, ELETEME (Kurt R.
Todoroff) wrote:
Does it move when say when the pilot wants to climb, or does it have
pressure sensors on a rigid stick so the stick can inform the
computers the pilots hand is pressing on the front of the stick and
he
wants the F-16 to climb?
Both. However, the purpose of the movement is only to provide artificial
feel
or feedback to the pilot. I read in the flight manual (a while back)
that the
stick moves either 1/4 inch or 1/8 inch longitudinally and laterally. I
don't
know how many degrees of pitch and roll movement about the translation
point
this equates to. For all intents and purposes, the stick is rigid. I
think
that General Dynamics incorporated this feature into the second block of
F-16A/B aircraft.
Kurt Todoroff
Markets, not mandates and mob rule.
Consent, not compulsion.
Remove "DELETEME" from my address to reply
Christopher
Winston Churchill
control stick (complete not only grip) from mig-21 papcio Aviation Marketplace 0 May 3rd 04 07:08 PM
complete control stick for sale papcio Home Built 2 April 29th 04 10:27 AM
complete control stick for sale papcio Aviation Marketplace 0 April 29th 04 06:25 AM
genuine mig-21 control stick FOR SALE nazgul Aviation Marketplace 0 April 16th 04 02:48 PM
FA Infinity Military Style Control Stick Grip Terry Ladouceur Home Built 3 October 8th 03 12:52 AM
