A-10 gear fairing
Old September 28th 03, 10:14 PM
TJ
"Kirk Stant" wrote in message
m...
A question for any Warthog jocks (or fans) out the
Why is the front of the right gear fairing on all A-10s painted gloss
black? Is is a radome of some sort? If so, what for?
Unless, of course, you would have to kill me if you told me, etc...
Just curious,
Kirk
Old F-4 WSO
I posted your question onto the Warthog territory forum. It is the ILS
antenna. The Mike Badrocke cutaway drawings still have the ILS in the nose
(an early manufacturer concept), but this was moved to the starboard gear
fairing due to Avenger vibration. Info straight from the guys who fly and
fix 'em.
TJ
Old September 28th 03, 10:37 PM
Tex Houston
"TJ" wrote in message
fix 'em.
TJ
Say again type of vibration. There has to be a story here somewhere.
Tex
Old September 28th 03, 10:55 PM
Thomas Schoene
"Tex Houston" wrote in message
starboard gear fairing due to Avenger vibration. Info straight from
the guys who fly and fix 'em.
TJ
How much of a story do you need to explain this? Placing an antenna in
close proximity to a very energetic 30mm gatling gun muzzle seems like an
obvious trouble spot. I'm slightly surprised the RWR antennas are still up
there.
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old September 28th 03, 11:24 PM
Tex Houston
"Thomas Schoene" wrote in message
ink.net...
TJ
up
there.
You still did not explain "Avenger".
Tex
Old September 28th 03, 11:42 PM
Yeff
GAU-8A/Avenger 30mm cannon.
-Jeff B.
yeff at erols dot com
Old September 28th 03, 11:48 PM
Thomas Schoene
ink.net...
antenna in close proximity to a very energetic 30mm gatling gun
muzzle seems like an obvious trouble spot. I'm slightly surprised
the RWR antennas are still up there.
GAU-8/A Avenger. That's the name of the gun!
Old September 29th 03, 02:13 PM
TJ
ink.net...
TJ
an
up
there.
Tex
I never replied. The response was from Thomas. The 30mm goes by the name
Avenger.
http://www.hill.af.mil/museum/photos/coldwar/gau8.jpg
TJ
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Landing gear door operation Elliot Wilen Military Aviation 11 July 8th 03 03:30 AM
