Lycoming SB for soft pin plugs
Old August 16th 07, 05:55 PM posted to rec.aviation.owning
Robert M. Gary
Default Lycoming SB for soft pin plugs
I have an IO-360-A3B6 with 1000 SFNEW in 1998. We pulled a cylinder
and the pin plugs where gone (we guessed this from the oil analysis).
The mechanic says he thinks he remembers some sort of SB put out by
Lycoming that there was a defect in the plugs and that they were made
too soft. Has anyone heard of such an SB???
-Robert
Old August 16th 07, 06:33 PM posted to rec.aviation.owning
Dave Butler
http://www.lycoming.com/support/publ...fs/SI1492C.pdf
DB
Old August 17th 07, 05:34 AM posted to rec.aviation.owning
Robert M. Gary
http://www.lycoming.com/support/publ...structions/pdf...
DB
Well, that's me. Now the cylinders are worn from the busted pin plugs.
That's at least one cylinder that will need to be replaced. I wonder
if Lycoming will offer any assistance ($$$) in addressing this since
the SI seems to acknowledge that the pin plugs were inproper.
-Robert
Old August 17th 07, 05:55 AM posted to rec.aviation.owning
Scott Skylane
/snip/ I wonder
the SI seems to acknowledge that the pin plugs were improper.
-Robert
Robert,
HAAAHHAAAAAAHHAAAAA, that's a good one! Seriously, have you complied
with the SB religeously since it came out in July 2000? No? I didn't
think so. Not that it would matter, anyway. However, Lycoming will be
happy to sell you the new plugs and cylinders at full retail, and not a
penny more...
Happy Flying!
Scott Skylane
N92054
Old August 17th 07, 07:58 AM posted to rec.aviation.owning
Robert M. Gary
/snip/ I wonder
-Robert
Robert,
think so.
Yes, I have (BTW Its not an SB, its an SI).
-Robert
Old August 17th 07, 02:14 PM posted to rec.aviation.owning
Jim Burns[_2_]
I "think" the problem was when Lycoming switched from alum/bronze pin caps
to aluminum caps. I've been told there is no problem with either the
alum/bronze caps that preceded or followed the aluminum caps, nor is there a
problem with the aluminum "piloted" press fit ends that are pressed into the
pins. Superior also makes pins with press fit plugs, although they problems
with the pins cracking in an earlier version.
Superiors SL points out that you can not mix pins/plugs of different weights
on the same engine.
Can an A&P familiar with the different pins chime in?
DB
-Robert
Old August 17th 07, 11:58 PM posted to rec.aviation.owning
[email protected][_1_]
On Fri, 17 Aug 2007 08:14:50 -0500, "Jim Burns"
on the same engine.
Pretty much nailed it. Minor nits, the piloted pins don't "press" in,
they slip in quite nicely until the inside of the pin gets varnished
up.
Every once in awhile they just start shaving. Have seen issues with
ALL the types in service.
Lycoming useta say "unofficially" that you could mix plug types if you
paired them in opposing cylinders.
Am curious what the OP or his tech found that requires cylinder
replacement.
Regards;
TC
Old August 18th 07, 12:59 AM posted to rec.aviation.owning
Robert M. Gary
on the same engine.
up.
The shop is recommending pulling all cylinders and doing a top. Does
one cylinder having an issue with pin plugs mean others much (the IA
says so, I'm not sure). I'm thinking I just want to replace this
cylinder and then fly it. The oil analysis will show if there is
another plug wearing.
replacement.
The IA said the cylinder was "2 one thousands" out of spec. Actually
one of the reasons we choose this cylinder to pull ( from the oil
analysis we knew we had to pull one of them do to progressively higher
AL counts), was that the cross hatching was gone on #1 (this is recent
because we boroscoped it at annual and didn't see this).
This engine has 1000 SFNEW in 1998 so I was not expecting to have to
replace cylinders. The IA did say that the bottom looks like a new
engine, no sign of any problems down there (we change the oil about
every 30 hours).
Anyway, the IA is recommending a full top and I'm not sure that is the
way to go.
-Robert
Old August 18th 07, 01:16 AM posted to rec.aviation.owning
Jim Burns
up.
The pressed in plugs I refered to are factory pressed into the pins such as
the Superior SL13444-1. We ran across this type of pin on the last cylinder
we swapped on the Aztec. We pulled and pressed the plugs out of the old pin
just in case we needed it (we didn't, the new cylinder came with a pin) the
old plug stems were "fluted" and definately had been pressed into the pin.
The new pin confirmed the construction, it also had factory pressed in plugs
rather than caps.
From Superiors service letters:
To further improve the durability of the piston pin plug, Superior Air Parts
has now developed a new
piston pin assembly, the SL13444-1, for the 5.125 inch Textron Lycoming
cylinders. This new
assembly incorporates a heavy wall piston pin and two piloted plugs that are
press-fitted into the inside
diameter of the piston pin during manufacturing. Superior believes that the
use of the SL13444-1
piston pin assembly will provide greater engine reliability and durability
because it greatly reduces the
possibility of the plugs spinning in the piston pin.
Looking for a soft copy of CAR3 Dave Owning 1 April 29th 06 02:13 PM
Cherokee 180 soft brake - causes? Nathan Young Owning 22 March 1st 06 05:21 PM
The Soft Release? Gary Boggs Soaring 19 January 24th 06 09:22 PM
Light Twins. How soft??? Montblack Owning 19 December 3rd 03 10:38 PM
Light Twins. How soft??? Montblack Piloting 19 December 3rd 03 10:38 PM
