White lead & castor oil on prop shaft?
Old August 20th 07, 04:58 PM posted to rec.aviation.homebuilt
wright1902glider
Default White lead & castor oil on prop shaft?
While attempting to distract myself from 8 hours of filing documents
on Friday, I Youtubed up the Republic / Air Corps training film on how
to field assemble the P-47 Thunderbolt. (Where I work, that's called
multi-tasking.) In the film, they describe coating the prop shaft of
the R-2800 with the "perscribed mixture" of white lead and castor oil
before installing the prop.
Just out of curiousity, how would someone comply with this procedure
now? Castol oil is easy enough to get, but white lead? Substitutes?
And what exactly does the white lead do? Does it act as a packing or
anti-corosive?
I've found that when restoring or reproducing vintage things,
attempting to find the correct materials is a real challenge, if not
impossible. When I built my Wright machine, the only easy materials to
find were the steel rod, sheet, and wire.
Harry Frey
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Increase efficiency of rotating shaft. jigar Home Built 8 October 6th 06 05:29 AM
Subaru flywheel pto shaft [email protected] Home Built 5 November 28th 05 12:05 AM
Thrust vs Shaft Horse Power? Evan Williams Military Aviation 9 July 22nd 04 02:45 AM
Lubricating the primer shaft Michael Horowitz Home Built 9 November 20th 03 12:26 AM
