Making plastic parts
Old September 4th 07, 04:17 AM posted to rec.aviation.homebuilt
Drew Dalgleish
Default Making plastic parts
On Mon, 03 Sep 2007 20:09:55 -0500, cavelamb himself
Drew Dalgleish wrote:
On Mon, 03 Sep 2007 13:08:32 -0500, cavelamb himself
Acyrilic casting resin - arts and crafts stuff...
Would this stuff be suitable for making a lens cover for a wingtip
strobe?
Jerry Wass wrote:
Hmmm--I wonder how they get those little spiders,Scorpions, medalions
etc inside those polished acrylic deskweights???Jerry
Lou wrote:
Does anyone know of a material that starts as a liquid, but hardens as
a platic?
I want to make some custom plastic parts for my plane (no not for the
structure)
that will require making a mold and then pouring in the liquid.
Lou
Dunno, Drew.
I formed a few from Polycarbinate and Lexan with varying degrees of sucess.
But the heat from the bulb turned out to be the real killer.
Actually melted through in less than 1/2 hour.
Granted wind would cool them some, but I gave up and replaced them
with normal wing tip marker lights (glass covers).
I can't guess how well acrylic resin would survive.
But the heat will for sure be an issue...
Guess that's why it says Experimental on the side.
Richard
Thanks Richard I sometimes think that i should install some strobes
on my plane in the name of safety then I price the wehlan stuff and
think I'm already safe enough. I'll maybe try some ground based
experiments myself.
Old September 4th 07, 04:23 AM posted to rec.aviation.homebuilt
Peter Dohm
"cavelamb himself" wrote in message
Peter Dohm wrote:
I was about to suggest thermoforming from either Lexan or Plexiglas,
since I
thought that was how the lenses on Bonanzas and the like were made. So,
now
you made me curious--how much surrounding airspace was available iside
ones you made?
Peter
Almost 1/2 inch above the 12 watt (1 amp) bulb.
Remember that there are thermoforming plastics and thermoSETTING plastics.
That might make all the difference in the world here...
Richard
I'll try to get another look. What I had seem may have had more clearance,
or some source of ventilation; but I don't remember.
Actually, I did have a car a while back with one of those rear window brake
lights that eventually failed. For no obvious reason, the replacement bulb
(of the same physical size and generic part number) quickly burned through
the top of the plastic casing--despite having a peice of foil (which was
original equipment) directly above the bulb. That was also in the 1amp
range at 12-14 volts; but I believe that the clearance was closer to a
quarter inch.
A strobe should generate much less heat, especially localized heat, than an
incandescent bulb; but this is a good problem to keep in mind for nav
lights. Of course, LEDs have become an affordable and reliable alternative
that also eliminate much of the heating problem--especially if the current
source is remotely located.
Peter
Old September 4th 07, 04:45 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Drew Dalgleish" wrote in message
experiments myself.
Drew ............
Perhaps this may suffice . . .
http://www.strobesnmore.com/
Rich S.
Old September 4th 07, 07:16 AM posted to rec.aviation.homebuilt
Richard Isakson
"Lou" wrote...
a platic?
structure)
About thirty five years ago, back when the EAA still cared about homebuilt
aviation, there was a good article in Sports Aviation about forming plastic
sheet into complex shapes for interior trim pieces.
Rich
Old September 4th 07, 09:31 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
since I
now
ones you made?
Peter
Richard
quarter inch.
Peter
Peter,
I just happened to have the plug and one of the "experiments" on hand.
Guess I need to revise the clearance question to LESS than 1/2 inch.
This one, I believe, is polycarbinate (DUE TO THE LACK OF BUBBLES IN THE
PLASTIC).
The lexan attempts were made with .065 scrap from my windshield.
Every one of those bubbled like crazy in the baking phase.
Lexan is hydroscopic and retains considerable water.
This stuff "boils" out while heating unless "baked" out at below 212
for several hours. It was kinda pretty with the colored light on inside
it. But not exactly the sleek smooth aircraft parts I had in mind...
Pic at:
http://www.home.earthlink.net/~cavel...sc.htm#wingtip
More clearance, thicker plastic, maybe they use some kind of special
stuff - I really dunno there.
Just that thin stuff with a fairly hot bulb simply didn't work...
YMMV
Richard
Old September 4th 07, 01:07 PM posted to rec.aviation.homebuilt
Scott[_1_]
What!?!? The Expensive Aircraft Association was once about homebuilts?
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Rich
Old September 4th 07, 03:34 PM posted to rec.aviation.homebuilt
Peter Dohm
brake
bulb
through
quarter inch.
an
alternative
current
Peter
Peter,
PLASTIC).
Pic at:
YMMV
Richard
I am not really sure why, but I was thinking of the type of lens that ends
up being an entire corner of a wing, so that it has a lot of volume and a
lot of area. Now that I have thought about it, 12 to 14 watts is a *lot* of
heat for this size lens.
I am not sure what material is used in the currently offered commercial
assemblies, but it may very well be glass. (As you might guess, I also
don't know what material to use as a mold for glass--much less how to form
the resulting mold.)
Peter
Old September 4th 07, 06:50 PM posted to rec.aviation.homebuilt
Morgans[_2_]
You can make the mold out of about anything that will stand the heat. Wood
has been used, and so has plaster of paris, or even dry sheet rock compound
or concrete. The trick is to line the surface that will be touching the
lexan or plexi with felt, or lacking that, an all cotton material like
t-shirts are made of. The plug needs to be perfect, because any defect in
the plug will transfer onto the plastic lens. Caution, if you go with woven
cloth, some of the weave pattern will come through onto the plastic. Not
good for windshields, but probably OK for light lenses.
When you use lexan, you need to put it in a low temp oven, of around 150 (I
think) for several hours to let all of the water slowly evaporate out of it.
That will prevent the bubbles in the plastic.
The plastic (acrylic or plexi) should be mounted in a frame, and clamped
securely around the edges. When you are ready to mold it, bring the
temperature up rather slowly, until you get a nice amount of sag in the
middle. Then you are ready to pull it down onto the plug.
The plug should be mounted on a base that has a support which is at least
smaller than the outside of the plug, and the support should be on a base
that will not tip over as you begin the process of pulling the plastic down
around the plug. It should be held there until it cools, almost to room
temperature. The excess can then be cut off with an abrasive cut off wheel
on a dremmel tool or die grinder.
If there are rather sharp, deep bends, it may be necessary to smooth the
plastic onto the plug as it is being pulled downward. Wear cotton gloves,
with perhaps a thicker pair of gloves under it to keep from burning your
hand. You will need a helper, unless you came outfitted with more than two
hands. g
Old September 4th 07, 08:46 PM posted to rec.aviation.homebuilt
brake
bulb
through
quarter inch.
an
alternative
current
Peter
Peter,
PLASTIC).
Pic at:
YMMV
Richard
Peter
Well, I think we know it has been done before.
I know I've seen those corner style covers.
But the details?
Might be I was just too close and too thin for the amount of heat.
Continue researching this, Peter.
Like my Ex was fond of saying..."Three weeks in the lab will save you
4 days in the library every time".
Richard
Old September 4th 07, 08:47 PM posted to rec.aviation.homebuilt
way back in once upon a time time...
Pirep on replacing interior plastic parts [email protected] Owning 1 April 12th 05 06:06 AM
Plastic Interior Parts? Mike Spera Owning 16 March 30th 05 09:35 PM
Repairing Plastic Interior Parts of 40-year-old Aircraft jls Home Built 6 December 7th 04 11:04 PM
172 plastic interior parts G.R. Patterson III Owning 9 May 28th 04 11:28 PM
Cessna 172 interior plastic parts [email protected] Piloting 3 February 11th 04 05:19 AM
