Why Are Gasoline-Like Fuels Favored For Aircraft?
Old October 7th 03, 07:09 AM
CHANGE username to westes
Default Why Are Gasoline-Like Fuels Favored For Aircraft?
Since taking up aviation as a hobby, I have wondered why gasoline, and
similar oil-derived liquid fuels, have become the defacto standard for all
forms of general aviation and commercial and military aircraft. Comparing
Jet fuel to something like natural gas, Jet fuel is four times as expensive.
Liquid fuels are extremely heavy, and certainly airplanes do not need extra
weight.
This leads me to wonder why haven't engines been commercialized that can
burn gas-based fuels? Is the only reason safety, because of the
explosive nature of gas fuels like natural gas or hydrogen?
Isn't there some way you could use two separate gases, which in their
separate state are inert, but combined together under high pressure, become
explosive? Such a combination would not ignite if the airplane crashed
(you could separate the gases into separate containers on each side of the
airplane, at the wingtips), but in controlled injection into a high pressure
compartment could be made explosive in a controlled way, in a very limited
space.
Think how much fuel is being wasted each day on airplanes, simply to support
the extra weight required to carry the fuel itself. Think how dangerous
airplanes are during relatively survivable impacts to the ground, primarily
because they are gasoline bombs. I would be very interested to read about
efforts to develop gas based engines for general aviation or commercial
aircraft. I would appreciate any pointers to web sites or books.
Will
NOTE: To reply, CHANGE the username to westes AT earthbroadcast.com
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
