#11
But for a 1950s type AC, it was quite handy and cheap. The alternative
was the A-4 for you Navy types and the F-5 for the AF types. I can't speak for the A-4 but the F-5 made a fanstastic trainer but a really bad weapons attack platform. Of course, there was the Spad that spanned three wars. The A-7 was a 60's design. The first proposals were essentially an F-8 with a modified wing optimized for lifting heavy bomb loads and more pylons. Navy went out with an A-4 replacement requirement. An emphasis on range/loiter with greater payload (A-4 Nam load was typically 6xMk82 and CL tank). Out went the J-57, in went the fan (originally TF-30P6), fuselage modified to eliminate need for wing incidence system (and its "interesting" flying qualities). It was quite good for the Vietnam environment, particularly shipboard where it did not require tanker support. As DS1 turned out, where air supremacy was achieved and the AAA threat only existed around specific hard targets, it was a fine airframe for the theatre ... but it lacked some of the goodies for the latest ordnance. It's system-supported dumb bombing capability was only slightly less than the F-18 (a couple additional mils dispersion). The TA-4 was a superb trainer. The A-4 was a superb, iron sight bomber. The single seat A-4 was the most enjoyable airplane I've ever flown. That includes some heavy iron that a lot of folks consider the ultimate rides of their day. R / John |
Guy Alcala writes: John Carrier wrote: The A-7's empty weight was a bit over 20K IIRC, certainly not 15 (even in the A-7A version ... the E was much heavier). The A-7 never lifted its empty weight in stores. That would have taken it well over max gross. Dorr's book lists the A-7A @ 15,037 lb. empty, MTOW 32,500 lb. A-7D is listed at 19,781 lb. empty, 42,000 lb. MTOW, essentially agreeing with Tom's data from Jane's. Typical bombload during Vietnam for Navy A-7s was about 6,000 lb., although during DS they tended to operate with only 4,000 lb. such as 4 x Mk. 83 1,000 lb. bombs (plus an AIM-9 or two), as they'd removed two pylons to decrease the drag. USAF A-7Ds tended to operate with 4-6,000 lb. in Vietnam, plus two tanks and a pod or two if going into a high-threat area. Navy a-87s in Vietnam tended not to carry tanks (they were closer to the targets) unless they were acting as buddy tankers, and they had internal ECM so didn't need to take up a pylon or two with that. From the A-7D SAC Chart, Oct 1970: Empty Weight: 19,733# Basic Weight: 20,331# Max Takeoff: 42,000# Note that: Full internal fuel is 9263#, Full External fuel is 7848# (4 300 U.S. Gallon cans) While the weapons loadout charts aren't included, the loads for teh example missions indicate that each wing pylon was good fpr 2000#. The performace section shows a typical load of 2 M117 750# (nominal, actual weight was a hair over 800#) each on 4 pylons, or 2 pylons of bombs and 2 tanks. The '79 Jane's lists lists teh pylon ratings as 3500# each for the wing outboars, and 2500# each for the 2 pairs of wing inboars, for a total of 15,000#. Given the SLUF's lack of Excess Power, I doubt that a load of that size was ever considered. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Peter Stickney wrote:
snip From the A-7D SAC Chart, Oct 1970: Empty Weight: 19,733# Basic Weight: 20,331# Max Takeoff: 42,000# Note that: Full internal fuel is 9263#, Full External fuel is 7848# (4 300 U.S. Gallon cans) While the weapons loadout charts aren't included, the loads for teh example missions indicate that each wing pylon was good fpr 2000#. The performace section shows a typical load of 2 M117 750# (nominal, actual weight was a hair over 800#) each on 4 pylons, or 2 pylons of bombs and 2 tanks. The latter seems to have been typical in SEA. Dorr has photos of 354th TFW A-7Ds with 8 Mk. 82s in a slant 4 (possibly a clearance issue with the tanks, if not gross weight) on intermediate pylon MERs plus tanks on the I/Bs; or 6 x CBU-58s, three per MER (same location as above) plus tanks. One shot shows the slant four Mk.82 load (probably. It's an end-on in-flight shot where the bomb type is a bit hard to define, showing a pair of A-7Ds flying on either wing of an F-111 leadship carrying a full load of 24 bombs), plus probably single MK. 82s on the O/Bs; for a total of 10. Oddly enough, for an a/c that was used entensively for CSAR Dorr has no shots of A-7Ds carrying Mk.82 snakes. [BTW, the weight of M117s seems to have changed quite a bit during production. The F-105B & D SACs in the D&S volume shows them at 799 lb., while alll later SACs and other sources show them at 823 lb.] The '79 Jane's lists lists teh pylon ratings as 3500# each for the wing outboars, and 2500# each for the 2 pairs of wing inboars, for a total of 15,000#. '82-'83 Jane's has it right (per a former A-7 jock I know): 3,500 for the the O/B and Intermediate pylons, 2,500 for the I/Bs. Given the SLUF's lack of Excess Power, I doubt that a load of that size was ever considered. Well, it's credited by Jane's with a t/o roll of 5,600 ft. @ MTOW, but that's presumably in a far lower drag configuration than wall- -to-wall loaded MERs. Besides 5,600 feet is 520 feet more than the F-105D requires with 16 x M117s (albeit less than an F-105G at max. gross), so I think we can safely assume that an A-7D's t/o from Korat at max. gross would make the F-105D look relatively spritely. In any case, the A-7 handily met the requirement for doubling the A-4's payload/range. Guy |
![]() "Daryl Hunt" wrote in message ... "John Carrier" wrote in message news ![]() From the former operators whom I work with every day. A-7B 19,500 empty, A-7E 21.500 empty. Typical bomb load off 27C was 8 or 10 Mk82 (depending on wind ... the cats were short). Otherwise 10-12 Mk82. Preferred was 4-6 Mk83 on the parent racks (no MERs/TERs with weight and drag), rare for the Navy in Viet Nam. Add 400# for two sidewinders (given the ACM capability of the SLUF, they would have proven more effective mounted backwards). Tanker typically 2x300Gal drop + D704 = 6000+ lbs. It would appear that your 6K, give or take, is the typical operational load. None of those I talked with (two of with combat experience) thought a field T/O at max gross of 42K was practical unless the concrete was REAL long and the day was REAL cold. I don't think A-7D's were launching in SEA at max gross given the typical wx etc. The airplane was a real pig at 38K or over. There is always restrictions on Carrier AC that are not on concrete jumpers. Guys, Daryl Hunt is also known as "Dead Meat". Do a search on google groups for Daryl Hunt or Dead Meat and you'll see the type of nut job that you are trying to debate with. Don't debate with him and let him get back to finding his medication. Some examples of his work: "Groom lake still has a squadron of the YF-12s. I have no idea why they are still there and why the get preflighted. I don't even know who actually controls them. Yet, as of 1991, they were still there. The difference between the A-12 and YF-12 was the mission. the A-12 was a ground attack Nuclear Fast Attack (fast ain't even the word here) .... Whereas, for about a decade, the SR had a mission until it was nuetralized by a 3 stage SA missile." .......... "No, the FB-4 was in the 30s but the Air Force had three designated in Incirlik Turkey as Strategic Bombers. The FB-111 was not quite online. When it came online, the FB-4 no longer carried that designator. Are there pictures of the FB-4 Nuke Carriers? No, they confiscated film frome the cameras from anyone that anyone came within vision with. Would they be in the Internet? I doubt it. It's like saying the original C-130 from 1953 is in original condition as it claims at Wright Pat as it sits with a 1957 radome, 4 AC generators on the Engines and the Gun Mounts under the Carpet. I remember it as a Spectre Gunship. Yup, history has a tendancy to be rewritten. When some of us are long gone, there will be no more recollection of any of this and history will be changed forever once again with the passing of time." .........(ON KAL007) "Okay, since you can't do the story on this one, let me hit you with the real story, youngster. Not the official one that was put out to save the Soviet Militaries face and avoid a war. BTW, this happens more than you will ever know. The US keeps a geo sat above the Kamchuka Penninsula at all times. We lost the Sat. During the lag time to get another one in place, the US had to rely on Aircraft to bridge the gap. YOU, the Soviets introduced a new 100k+ AM that could knock out the SR-71 so the SR could only do a side shoot in inernational waters. We were launching a RC-135 and a EC-135 to get pictures at very close range. The RC was a Camera Ship while the EC provided Cover from international Air Space. The EC operated while the RC was making the camera run. Those two put your defense fighters on edge. The EC would come in after a routine flight while the RC came in with cooked engines from running in Mil Power for too long a time. The RC carried the same engines that a C-141 Carried so it was more than just a bit overpowered by that days standards. Ever fly an AC right at Mach running very close to Zero altitude? When speed and atlitude won't work, you bring lots of Gas with you. Fighters can only run for a few minutes at this type of speed near sea level whereas the Tanker can run much longer. This means the Tanker is relatively safe if you don't mind riding the worlds most hairy Carny ride in the World. Heat Seekers can't touch it, the EC keeps the Radar Missiles at bay and if you use your guns at that speed, you will fly into your own bullets. A complete NDI of the RC plus all 4 engine changeout on return was considered a routine mission. This mission didn't last very long as a new Sat was readied and launched to replace the malfunctioned Sat. During this time, the KAL was shot down by an over zealous pilot. Never did understand why since these types of games were played by both sides on a daily basis in that part of the world. Your T-95 Bear was very good at it also. None of this was ever done "Officially" by either side." TJ |
![]() "TJ" wrote in message ... Hey TJ. Haven't seen you for quite a bit. Guess you only come out when your buddies are spewing ****. Where are all the good trolls these days. |
GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 04:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
