When you guys weld up your 4130 airframes do you use any type of rust
inhibitor in the tubes? I have read about some that you spray in the tubes ait crawls up the walls to coat the whole inside, and it is supppose to leak out of any weldment that had a pinhole in it. I am just curious if you use anything like this or not. Thanks! -- Have a good one! Steve www.americanspiritppc.com |
YUP, Best thing is Boiled linseed oil--(can't hardly find raw anymore)
Weld a 1/2 collar of 1/8" pipe ftg to lower front cross pc. Weld same to rudder post near top. put a couple of little valves on each ftg. Borry a refrig vacuum pump, attach to top ftg. attach couple ft of plastic hose to lower valve. place in bottom of gallon container, pour in couple qts of linseed oil, CLOSE BOTTOM VALVE, pull vacuum on fuselage---if you can't pull a good vacuum, you gotta leak---pressure it up & get a young kid ( that ain't been listenin to loud music) & have him listen for leaks---WELD UP LEAKS---tRY AGAIN, YOU PROBABLY MISSED ONE! Then pull vacuum, shut vacuum valve( don't want erl in vac pump), open lower valve, suck in 2 or 3 qts of oil. shut both valves. leave oil in a day or so, rotating fuselage 4 times. If you got a little argon, attach to top ftg, open bottom ftg, & blow out excess oil. The argon keeps oxygen out while oil is draining, the oil combines with any remaining oxygen, and turns to paint if it sees any oxygen, thereby sealing any teensy weensy holes. DONT WELD ON FRAME ANY MORE!! Steve Thomas wrote: When you guys weld up your 4130 airframes do you use any type of rust inhibitor in the tubes? I have read about some that you spray in the tubes ait crawls up the walls to coat the whole inside, and it is supppose to leak out of any weldment that had a pinhole in it. I am just curious if you use anything like this or not. Thanks! -- Have a good one! Steve www.americanspiritppc.com |
On Wed, 27 Aug 2003 16:53:15 GMT, "Steve Thomas"
wrote: When you guys weld up your 4130 airframes do you use any type of rust inhibitor in the tubes? I have read about some that you spray in the tubes ait crawls up the walls to coat the whole inside, and it is supppose to leak out of any weldment that had a pinhole in it. I am just curious if you use anything like this or not. Thanks! -- Have a good one! Steve www.americanspiritppc.com Once again, I'm breaking from tradition regarding this building method. What method do I use? Absolutely nothing. Here's the way I figure it. I'm 55 now. I've welded this fuselage together to the best of my ability and have closed off all openings. Is it air tight? Proably not, there my be a pinhole somewhere. But the fuselage will be sandblasted, at which time I get to inspect it one more time, than it will be coated with primer and then coated with paint. By the time all this is done, there will be precious few places for water to get into, and that's without the fabric covering. With the fabric covering, almost no water will be able to reach the tubes. And even if it could, there would be very very few places for it to get inside the tube. Did I mention that the fuselage sits level rather than tail down? Well that's a factor too. Finally, even if I somehow left a gaping hole for moisture to enter the tubing, which isn't the case but for argument's sake let's assume so, it still won't matter much in my lifetime. So I decided not to painstakingly drill a hole through every joint so that linseed oil or whatever could be poured into it and then roll the fuselage around to slosh each tube, then drain it out, sort of. I mean sheesh, what a mess to deal with and how much added weight would this be? All for no good reason that I could see. The entire fuselage doesn't rust out from the inside, never has. Only a few tubes that were improperly welded and were tail down ever rusted much and then it took 30 or 40 years to do so. Corky Scott |
Corky Scott wrote:
Once again, I'm breaking from tradition regarding this building method. What method do I use? Absolutely nothing. Here's the way I figure it. I'm 55 now. I've welded this fuselage together to the best of my ability and have closed off all openings. Is it air tight? Proably not, there my be a pinhole somewhere. But the fuselage will be sandblasted, at which time I get to inspect it one more time, than it will be coated with primer and then coated with paint. By the time all this is done, there will be precious few places for water to get into, and that's without the fabric covering. With the fabric covering, almost no water will be able to reach the tubes. And even if it could, there would be very very few places for it to get inside the tube. Did I mention that the fuselage sits level rather than tail down? Well that's a factor too. Finally, even if I somehow left a gaping hole for moisture to enter the tubing, which isn't the case but for argument's sake let's assume so, it still won't matter much in my lifetime. So I decided not to painstakingly drill a hole through every joint so that linseed oil or whatever could be poured into it and then roll the fuselage around to slosh each tube, then drain it out, sort of. I mean sheesh, what a mess to deal with and how much added weight would this be? All for no good reason that I could see. The entire fuselage doesn't rust out from the inside, never has. Only a few tubes that were improperly welded and were tail down ever rusted much and then it took 30 or 40 years to do so. Corky Scott Corky, you're better off drilling a 1/8" hole in a low spot than to leave just one small pinhole. Used to drive a 18wheeler. Air brakes with big air tanks that had to be bled, ie a short piece of rope is tied to a valve on the bottom of the tank. If not bled regularly (every day), when you pull the rope all sorts of dark brown gunk get blown out the bottom. There was a spare tank sitting over in the yard that no one had used for a year or two. I went over one day and pulled the rope on it. Wasn't much pressure in it, but it squirted a slow steady stream of water for a minute or so before petering out. Here's the process. Airframe (which is acting as a tank here) get hot during the day. The air pressure rises and forces humidity out of the small amout of air in the tubes before the air gets squeezed out the pinhole. Leaves maybe 0.1oz of water. Night comes and the airframe cools. Very slowly, air, wet with evening dew is drawn into the tube (with it's 0.1oz of water), where it waits to start the cycle again the next day. Paint won't help. If there's a pinhole, the paint will get blown off when the pressure rises (the linseed oil runs into the hole from the other side and acts as a plug, not a patch). My unrequested advice: Either close it, and close it properly, or leave it all the way open. -- ----Because I can---- http://www.ernest.isa-geek.org/ ------------------------ |
On Fri, 29 Aug 2003 00:07:15 GMT, Ernest Christley
wrote: Corky Scott wrote: Once again, I'm breaking from tradition regarding this building method. What method do I use? Absolutely nothing. Here's the way I figure it. I'm 55 now. I've welded this fuselage together to the best of my ability and have closed off all openings. Is it air tight? Proably not, there my be a pinhole somewhere. But the fuselage will be sandblasted, at which time I get to inspect it one more time, than it will be coated with primer and then coated with paint. By the time all this is done, there will be precious few places for water to get into, and that's without the fabric covering. Corky, It's not the water you see that hurts, it's the water in the air rhat gets sucked in and out of those tubes as they heat and cool. As the tubes cool they suck damp air in, and the moisture condenses out into the tubes. If you don't drain them at the low point the water builds up and it WILL rust the tubes. Better to leave both ends wide open, and allow the structure to breath, than to leave a few pinholes and not protect the tubing. With the fabric covering, almost no water will be able to reach the tubes. And even if it could, there would be very very few places for it to get inside the tube. Did I mention that the fuselage sits level rather than tail down? Well that's a factor too. Finally, even if I somehow left a gaping hole for moisture to enter the tubing, which isn't the case but for argument's sake let's assume so, it still won't matter much in my lifetime. So I decided not to painstakingly drill a hole through every joint so that linseed oil or whatever could be poured into it and then roll the fuselage around to slosh each tube, then drain it out, sort of. I mean sheesh, what a mess to deal with and how much added weight would this be? All for no good reason that I could see. The entire fuselage doesn't rust out from the inside, never has. Only a few tubes that were improperly welded and were tail down ever rusted much and then it took 30 or 40 years to do so. Corky Scott Corky, you're better off drilling a 1/8" hole in a low spot than to leave just one small pinhole. Used to drive a 18wheeler. Air brakes with big air tanks that had to be bled, ie a short piece of rope is tied to a valve on the bottom of the tank. If not bled regularly (every day), when you pull the rope all sorts of dark brown gunk get blown out the bottom. There was a spare tank sitting over in the yard that no one had used for a year or two. I went over one day and pulled the rope on it. Wasn't much pressure in it, but it squirted a slow steady stream of water for a minute or so before petering out. Here's the process. Airframe (which is acting as a tank here) get hot during the day. The air pressure rises and forces humidity out of the small amout of air in the tubes before the air gets squeezed out the pinhole. Leaves maybe 0.1oz of water. Night comes and the airframe cools. Very slowly, air, wet with evening dew is drawn into the tube (with it's 0.1oz of water), where it waits to start the cycle again the next day. Paint won't help. If there's a pinhole, the paint will get blown off when the pressure rises (the linseed oil runs into the hole from the other side and acts as a plug, not a patch). My unrequested advice: Either close it, and close it properly, or leave it all the way open. |
![]() One more comment , if you please---If you seal it up, haveplugs in each end, and pressure test it before you fly it----If you prang it kinda hard one day & wonder if you cracked a weld--simply pressure it up-(nitrogen, argon,etc) then see if it bleeds down----If it does, pressure it up with Freon, and go sniffin with a leak detector. Saw back a few years ago where a guy left it pressured up, and put a small gage in the ftg. ---one more thing to pre-flight. clare, @, snyder.on, .ca wrote: On Fri, 29 Aug 2003 00:07:15 GMT, Ernest Christley wrote: Corky Scott wrote: Once again, I'm breaking from tradition regarding this building method. What method do I use? Absolutely nothing. Here's the way I figure it. I'm 55 now. I've welded this fuselage together to the best of my ability and have closed off all openings. Is it air tight? Proably not, there my be a pinhole somewhere. But the fuselage will be sandblasted, at which time I get to inspect it one more time, than it will be coated with primer and then coated with paint. By the time all this is done, there will be precious few places for water to get into, and that's without the fabric covering. Corky, It's not the water you see that hurts, it's the water in the air rhat gets sucked in and out of those tubes as they heat and cool. As the tubes cool they suck damp air in, and the moisture condenses out into the tubes. If you don't drain them at the low point the water builds up and it WILL rust the tubes. Better to leave both ends wide open, and allow the structure to breath, than to leave a few pinholes and not protect the tubing. With the fabric covering, almost no water will be able to reach the tubes. And even if it could, there would be very very few places for it to get inside the tube. Did I mention that the fuselage sits level rather than tail down? Well that's a factor too. Finally, even if I somehow left a gaping hole for moisture to enter the tubing, which isn't the case but for argument's sake let's assume so, it still won't matter much in my lifetime. So I decided not to painstakingly drill a hole through every joint so that linseed oil or whatever could be poured into it and then roll the fuselage around to slosh each tube, then drain it out, sort of. I mean sheesh, what a mess to deal with and how much added weight would this be? All for no good reason that I could see. The entire fuselage doesn't rust out from the inside, never has. Only a few tubes that were improperly welded and were tail down ever rusted much and then it took 30 or 40 years to do so. Corky Scott Corky, you're better off drilling a 1/8" hole in a low spot than to leave just one small pinhole. Used to drive a 18wheeler. Air brakes with big air tanks that had to be bled, ie a short piece of rope is tied to a valve on the bottom of the tank. If not bled regularly (every day), when you pull the rope all sorts of dark brown gunk get blown out the bottom. There was a spare tank sitting over in the yard that no one had used for a year or two. I went over one day and pulled the rope on it. Wasn't much pressure in it, but it squirted a slow steady stream of water for a minute or so before petering out. Here's the process. Airframe (which is acting as a tank here) get hot during the day. The air pressure rises and forces humidity out of the small amout of air in the tubes before the air gets squeezed out the pinhole. Leaves maybe 0.1oz of water. Night comes and the airframe cools. Very slowly, air, wet with evening dew is drawn into the tube (with it's 0.1oz of water), where it waits to start the cycle again the next day. Paint won't help. If there's a pinhole, the paint will get blown off when the pressure rises (the linseed oil runs into the hole from the other side and acts as a plug, not a patch). My unrequested advice: Either close it, and close it properly, or leave it all the way open. |
![]() One more comment , if you please---If you seal it up, haveplugs in each end, and pressure test it before you fly it----If you prang it kinda hard one day & wonder if you cracked a weld--simply pressure it up-(nitrogen, argon,etc) then see if it bleeds down----If it does, pressure it up with Freon, and go sniffin with a leak detector. Saw back a few years ago where a guy left it pressured up, and put a small gage in the ftg. ---one more thing to preflight. The CH7 (?) Angel homebuilt helicopter has a pressurized frame with gauge if I'm not mistaken. I'm kinda with Corky on the longevity of the tubing, but on my aircraft I definitely like having raw linseed in the tubes to indicate frame cracks. That stuff will leak out and leave a red indicator before the crack is noticeable to the naked eye. It will also snitch on cracks under paint. That alone is worth the oil to me. More than once it was the stitch in time that saved nine. |
On Fri, 29 Aug 2003 02:33:04 GMT, clare @ snyder.on .ca wrote:
Corky, It's not the water you see that hurts, it's the water in the air rhat gets sucked in and out of those tubes as they heat and cool. As the tubes cool they suck damp air in, and the moisture condenses out into the tubes. If you don't drain them at the low point the water builds up and it WILL rust the tubes. Better to leave both ends wide open, and allow the structure to breath, than to leave a few pinholes and not protect the tubing. Well that's good information, thanks Clare. Don't think it will change my mind at this point but it's nice to know how the process works. The Christavia has so many tubes and they are of such thickness that I'm reasonably sure the airframe will outlive me and my son, as long as I don't create new openings by gronking it against a mountain or something. I compared the fuselage to a Wag-Aero 2+2 and was shocked to see how beefy the Christavia was by comparison. The problem is that the beefiness comes at the cost of additional weight I wish I did not have to deal with. Corky Scott |
sealing cork float against gasoline - how to... | jt | Home Built | 13 | July 18th 03 10:51 PM |
