BRS for emergencies
Old September 13th 07, 05:05 PM posted to rec.aviation.soaring
JS
Default BRS for emergencies
The Sparrowhawk which was repeatedly flown far over redline, ripping
the wings off, provided an interesting BRS experiment.
Opening shock was sufficient to launch the pilot out of the fuselage.
Fortunately he was wearing a pilot emergency parachute.
There is evidently more to develop in BRS technology. Aircraft which
deploy ballistic chutes don't always look or behave like the Cirrus or
Discus used in the certification experiments.
Old September 13th 07, 05:38 PM posted to rec.aviation.soaring
Bob Kuykendall
One major challenge for sailplane BRS systems is water ballast.
If you size the BRS system to the ballasted gross weight, you end up
needing a rather large system that costs a lot and takes up a lot of
internal volume.
On the other hand, if you size the BRS to the dry gross weight you
have a system that is overmatched under many flight regimes, including
many in which BRS capability is most desirable - such as climbing away
from a start at a crowded contest site.
You could placard the system into compliance with a sticker that says
"Dump ballast before deploying BRS" or "Do not deploy BRS while
ballasted." But that doesn't address an important issue: most ballast
dump systems can't empty the water out in less than about a minute,
and some take as much as three or five minutes.
I suppose the savvy glider developer could also embed a steel cable
into the wing skin, and tie it into the BRS harness so that deployment
unzips the wing and liberates the water. That'd be a sight to see.
Bob K.
Old September 13th 07, 05:58 PM posted to rec.aviation.soaring
shawn
snip
How about embedding det cord around each wing, connected to go off with
the BRS rocket? Zip the wings off, along with the water ballast. With
just the fuselage to lower, the 'chute can be smaller too ;-)
Shawn
Old September 13th 07, 06:30 PM posted to rec.aviation.soaring
bikensoar
Jim......You are misinformed about the Owl project. The BRS was
never deployed by the pilot. The glider went well past redline. It
reached flutter speed. the glider literally disintegrated with the
pilot
being ejected through the canopy still strapped into the seat pan.
The BRS deployed somehow on its own and the wreckage descended
safely to the ground.
It would be difficult for any recovery system to work well once the
aircraft was 40-50 knots over redline.
The fact that the BRS worked at those speeds is very encouraging
to me.
The truly amazing thing about a system like BRS is the lives that
have been saved at very low deployment altitudes. There have
been saves as low as 200 ft. agl.
And once again, spreading half facts and misinformation on this
site does a disservice to BRS and Windward Performance.
George Y
Old September 13th 07, 06:41 PM posted to rec.aviation.soaring
Paul Hanson
ballast.
snip
a steel cable
so that deployment
a sight to see.
to go off with
water ballast. With
too ;-)
Shawn
BOMBS AWAY!
Paul
Old September 13th 07, 06:47 PM posted to rec.aviation.soaring
Eric Greenwell
snip
Might as well remove the tail boom, too. This would reduce the glider to
just the cockpit with the pilot. Having a known weight, shape, and size
to control would make it substantially easier for the rescue system
designer. It would speed the certification process, because only one
shape would need to be tested, instead of configurations with all
surfaces attached, one or both wings missing, tail missing, etc.
It would be a very safe glider, as most pilots would never get in it!
Old September 13th 07, 07:10 PM posted to rec.aviation.soaring
Marc Ramsey
Details, please, otherwise I will view this as half facts and
disinformation 8^)
Marc
Old September 13th 07, 07:22 PM posted to rec.aviation.soaring
disinformation 8^)
Marc
uh, isnt this Rec.Misinformation.Aviation.Soaring ??? or am I lost?
Old September 13th 07, 07:33 PM posted to rec.aviation.soaring
Paul Hanson
redline, ripping
of the fuselage.
Aircraft which
like the Cirrus or
The BRS was
past redline. It
with the
pilot
the seat pan.
descended
well once the
encouraging
to me.
the lives that
There have
on this
George Y
George, I just attended the ESA (Experimental Sailplane
Association, formerly SHA) western workshop in Tehachapi
where Greg Cole (Sparrowhawk designer/Windward Perf
owner for the uninformed) covered the 'Owl Project
incedent' in his presentation, and Jim is basically
correct. BTW, this is the incident I was referring
to in my earlier post about a flutter breakup and how
smart it was for the pilot to also have a personal
chute cause' it saves his a$$ when the BRS ejected
him, but did not want to mention names at that point,
out of respect. But since it is out for open discussion,
I will add this. The wings fluttered off at 170kts
(the calculated flutter speed BTW) during a botched
'extreme envelope test' involving manually performed
aerobatic maneuvers to gather data for an autopilot
system destined for it's UAV application. When the
BRS was deployed, by the pilot, he was ejected through
the airframe under the extreme G's (I forgot the exact
number they calculated, but it was very high) pulled
during the ensuing deceleration in lawn dart configuration.
Good thing he had his personal chute (and I believe
a helmet too for that matter)...
I am not at all against the BRS (and certainly not
against Windward, I personally love the Sparrowhawk,
which performs quite admirably within it's design parameters),
I just think a BRS should not be considered a 'substitute'
for a personal chute, but rather a nice addition. Most
people need a cushion in the cockpit. Yours can be
made of dirty laundry if you wanted, but I will always
use a chute to fill that role, and think that others
should be encouraged to do the same. I have had this
conversation with several of the pilots at my club,
where incidentally the only fatality there was a fellow
who was not wearing his chute (that day only) when
his HP-14 controls jammed and a spin became unrecoverable.
A BRS would have done the job nicely that time, but
from 5,000 AGL he also had plenty of altitude to jump
ship.
Wear your chutes folks, accidents are not planned events
and you can't guarantee the BRS will operate properly
after an incident/accident that requires you to use
it, but get a BRS if you can as they are indeed great
inventions.
Paul Hanson
"Do the usual, unusually well"--Len Niemi
Old September 13th 07, 08:07 PM posted to rec.aviation.soaring
Bob Kuykendall
He never said it was deployed by the pilot.
The glider literally disintegrated with the pilot
into the seat pan.
Somehow I don't think that's a good thing.
the wreckage descended safely to the ground.
All safety is relative. Every sense of security is at least partly
false.
Thanks, Bob K.
2 "emergencies" this AM Robert M. Gary Piloting 2 September 12th 05 03:06 PM
Ebay Auction Jeppesen VHS (4) tapes collection: Enroute Charts, IFR Emergencies, Departures & Arrivals, Approach Charts Cecil Chapman Products 0 February 9th 05 03:09 AM
ebay auction for King Schools two volume Emergencies on two VHS Tapes Cecil Chapman Products 0 February 9th 05 03:06 AM
Weird Emergencies SelwayKid Rotorcraft 18 April 19th 04 11:33 PM
In Flight Malfunctions and Emergencies Rocky Rotorcraft 31 January 20th 04 05:12 AM
