On Mon, 17 Sep 2007 10:53:08 -0700, "Robert M. Gary"
wrote: Have you tried 100LL, or racing fuel from a local speed shop? We use so little in weed eaters and such, it might be worth the price. I have but I'm concerned that the lead and high octane might create deposits in the engine. What I need is not better gas but just clean (even crappier) gas. The local airport (7B3 Hampton NH) sells mogas bought from the terminal in Portland ME that has no additivates whatever. I buy it ($3.90 a gallon) for the small engines (chain saw, generator, off-season lawnmower and snow blower) that are likely to sit for months between uses. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
On Sat, 15 Sep 2007 13:45:13 -0700, Jay Honeck
wrote: This from a thread in rec.aviation.owning: Leave unleaded mogas in your lawnmower for a year, and it likely won't start. Autogas lacks the stabilizer package found in avgas. You know, I've heard that ever since I started using mogas in my planes, but I've never seen a cite, nor have I *ever* noticed a problem with unleaded gasoline in *any* of my lawn mowers, leaf blowers, or snow blowers. I put 'em away in the spring/winter, and start 'em up the following winter/summer -- and away we go. Same with my Honda Goldwing -- I top it off, and it just sits till next year. No troubles. Can anyone point me to anything that proves (or disproves) the "fact" that unleaded mogas deteriorates faster than avgas? in australia at least there are additives in automotive fuel that degrade on exposure to uv light. this causes a fine flakey sediment to settle out. this was the cause of 'dont use in aircraft' warnings in our country. Stealth Pilot |
degrade on exposure to uv light. this causes a fine flakey sediment to settle out. this was the cause of 'dont use in aircraft' warnings in our country. They *added* stuff to the gas that causes flakey sediment? Have you got a cite for that? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Sun, 16 Sep 2007 21:14:12 +0800, Stealth Pilot
wrote: in australia at least there are additives in automotive fuel that degrade on exposure to uv light. A lot of transparent fuel tanks in Oz, are there? :-) Ron Wanttaja |
Again from Chevron
http://www.chevron.com/products/prod...esting/pg5.asp sites the internationally recognized formulation standards which include specs for stability and gum solvent content. We own two 10k gal gasoline tanks, one for 89 oct unleaded and one for 89 oct unleaded plus lube additive for the old truck valve trains. Each of those tanks sit less than 1/2 full for 5-6 months before I buy a load to split between them, usually in the spring. When less than 1/2 full, those tanks have a lot of surface area exposed allowing evaporation of the gas's lightest components, not to mention water condensation. We see no problems with gasoline that has been stored for 5-6 months. We've got a fleet of over 50 gas powered trucks ranging from pickups to midsized bulk trucks that range in age from the 1960's to current production. The trucks that don't get used year around start and run fine each spring with the fuel that's left in the tanks from when we put them away each fall. No fouled plugs, not fuel system problems. Our fuel rep said that you "might" see some performance degradation in high compression/high horsepower engines from the fuel oxidizing slightly while it sat, but as long as it meets the current manufacturing standards, it should be fine. He said that most problems reported are from users that have contaminated gas that has all but totally evaporated in their fuel systems. The contaminates remain behind then get flushed into carb jets and needle valves or fuel injectors by fuel from the tank. He said that contamination is a much bigger problem than age. We buy unbranded fuel strictly on price. Sometimes it contains ethanol, sometimes it doesn't, sometimes we end up with a branded product, most of the time we don't. We never notice a difference. Our guy wasn't pushing any special brand or formulation. YMMV. I noted that several of the posts mentioned small engines. Are these 4 strokes burning straight gas or 2 strokes burning blended gas/oil mixtures? Jim "Jay Honeck" wrote in message ps.com... This from a thread in rec.aviation.owning: Leave unleaded mogas in your lawnmower for a year, and it likely won't start. Autogas lacks the stabilizer package found in avgas. You know, I've heard that ever since I started using mogas in my planes, but I've never seen a cite, nor have I *ever* noticed a problem with unleaded gasoline in *any* of my lawn mowers, leaf blowers, or snow blowers. I put 'em away in the spring/winter, and start 'em up the following winter/summer -- and away we go. Same with my Honda Goldwing -- I top it off, and it just sits till next year. No troubles. Can anyone point me to anything that proves (or disproves) the "fact" that unleaded mogas deteriorates faster than avgas? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
strokes burning straight gas or 2 strokes burning blended gas/oil mixtures? In my case, it's both. I've got an annoying mix of 2- and 4-stroke gasoline tools -- but none of them show any kind of problems running "old" gasoline. Thanks for the information about your experiences. I'm sure gasoline EVENTUALLY goes "bad", due to evaporation and water contamination -- but I think it's highly unlikely that "aviation gasoline" is any different than "auto gasoline" in this regard. I simply don't believe that the oil companies put any extra money into production of aviation gasoline, especially when they sell such a tiny, insignificant amount of it. Does anyone (besides me) think that oil companies would keep the two formulas as close to identical as possible, with the exception of lead, in the interest of cost savings? Personally, I think this is just another busted aviation myth. But I'm sure there will always be those who believe that the $4.40/gallon stuff is better than the $2.89/gallon stuff, just like there are those who swear by Marvel Mystery Oil, flying on "the step", and fear stalling when turning the same direction as the wind. (Hey -- anyone want to debate "shock cooling" now that it's getting cold out?) :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
The biggest difference between standard mogas and avgas would be that avgas
is actually manufactured to a tighter Mil spec than the petroleum industry standard for mogas. It's also handled in ways to minimize contamination. Mogas can be transported in the same pipline or truck directly after a load of diesel or other fuel without any cleaning procedure. Mogas and diesel fuel can be co-mingled in the same truck, in separate compartments. Avgas must be handled and hauled alone. Avgas can only follow mogas or after cleaning procedures. Same for Jet A, Jet A can follow a Kerosene shipment, but not a diesel fuel or gasoline shipment. Jim "Jay Honeck" wrote in message ups.com... I noted that several of the posts mentioned small engines. Are these 4 strokes burning straight gas or 2 strokes burning blended gas/oil mixtures? In my case, it's both. I've got an annoying mix of 2- and 4-stroke gasoline tools -- but none of them show any kind of problems running "old" gasoline. Thanks for the information about your experiences. I'm sure gasoline EVENTUALLY goes "bad", due to evaporation and water contamination -- but I think it's highly unlikely that "aviation gasoline" is any different than "auto gasoline" in this regard. I simply don't believe that the oil companies put any extra money into production of aviation gasoline, especially when they sell such a tiny, insignificant amount of it. Does anyone (besides me) think that oil companies would keep the two formulas as close to identical as possible, with the exception of lead, in the interest of cost savings? Personally, I think this is just another busted aviation myth. But I'm sure there will always be those who believe that the $4.40/gallon stuff is better than the $2.89/gallon stuff, just like there are those who swear by Marvel Mystery Oil, flying on "the step", and fear stalling when turning the same direction as the wind. (Hey -- anyone want to debate "shock cooling" now that it's getting cold out?) :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Sep 16, 3:09 pm, "Jim Burns" wrote:
The biggest difference between standard mogas and avgas would be that avgas is actually manufactured to a tighter Mil spec than the petroleum industry standard for mogas. It's also handled in ways to minimize contamination. Mogas can be transported in the same pipline or truck directly after a load of diesel or other fuel without any cleaning procedure. Mogas and diesel fuel can be co-mingled in the same truck, in separate compartments. Avgas must be handled and hauled alone. Avgas can only follow mogas or after cleaning procedures. Same for Jet A, Jet A can follow a Kerosene shipment, but not a diesel fuel or gasoline shipment. They do the same here. The truck's tanks have to be flushed with 100LL before they can fill them with it and the batch is tested and a detailed printout sent with the load. The liability for Avgas is huge compared to Mogas, and the refinery and trucking outfit have to carry more insurance for that, too. There are many ways we pay for our litigious society. Dan |
On Sep 16, 2:09 pm, "Jim Burns" wrote:
The biggest difference between standard mogas and avgas would be that avgas is actually manufactured to a tighter Mil spec than the petroleum industry standard for mogas. It's also handled in ways to minimize contamination. Mogas can be transported in the same pipline or truck directly after a load of diesel or other fuel without any cleaning procedure. Mogas and diesel fuel can be co-mingled in the same truck, in separate compartments. Avgas must be handled and hauled alone. Avgas can only follow mogas or after cleaning procedures. Same for Jet A, Jet A can follow a Kerosene shipment, but not a diesel fuel or gasoline shipment. Avgas is not transported by pipelines in the U.S. due to the existence of TEL contaminating pipeline. They're all trucked, often from a refinery half the country away. That's one of the big reasons why 100LL costs more than $1/gallon over mogas, and that price delta is going to further increase as the overall consumption avgas decreases. |
Jim Burns wrote:
It's also handled in ways to minimize contamination. I always thought the special handling was because of the lead in 100LL and for the protection of the unleaded fuels from lead contamination, not for the protection of the Avgas. -- The mail address works, but please notify me via usenet of any mail you send to it, as it has a retention period of just a few hours. |
Sunday 072907 in Oshkosh Pt 1 - the C17 [5/6] - "19 C17 more drama, this time from the sun just above the picture.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 30th 07 10:49 PM |
$5.64 for a gallon of "Chateau de AvGas" | Jay Honeck | Piloting | 22 | July 4th 07 04:33 PM |
FS: 2002 "Ghosts: A Time Remembered" (Aviation) Calendar | J.R. Sinclair | Aviation Marketplace | 1 | December 20th 05 07:52 PM |
