Holding Pattern Question
Old September 25th 07, 12:37 AM posted to rec.aviation.ifr
Bonehenge (B A R R Y)
Default Holding Pattern Question
On Mon, 24 Sep 2007 23:32:00 GMT, Matt Whiting
If no delay is expected, why issue a hold?
Because people who write written exams need a reason to ask a
question? G
Old September 25th 07, 01:42 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Matt Whiting" wrote in message
For a variety of reasons. Let's say your destination is an uncontrolled
field and there's traffic ahead of you for that field. The controller can't
clear you for the approach because the preceding aircraft hasn't cancelled,
but he expects it to cancel before you'd experience any delay.
Old September 25th 07, 01:48 AM posted to rec.aviation.ifr
Matt Whiting
In that case, you better ask for an EFC if you haven't received further
clearance prior to arrival at the holding fix.
Matt
Old September 25th 07, 01:58 AM posted to rec.aviation.ifr
Steven P. McNicoll
Yes, but in that case the controller expects to issue an approach clearance
before you arrive at the holding fix. That's why no delay is expected.
Old September 25th 07, 01:54 AM posted to rec.aviation.ifr
Dennis Johnson
can't clear you for the approach because the preceding aircraft hasn't
cancelled, but he expects it to cancel before you'd experience any delay.
I thought you had to get an expect further clearance time as part of the
hold instructions in case your radio failed shortly after directed to hold?
Otherwise, how would you know how many turns to make in holding before
proceeding on course? I'm not arguing, just asking,
Dennis
Old September 25th 07, 02:02 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Dennis Johnson" wrote in message
hold? Otherwise, how would you know how many turns to make in holding
before proceeding on course? I'm not arguing, just asking,
Why is it that comm radios fail but nav radios do not?
http://www.faa.gov/airports_airtraff...406.html#4-6-1
Old September 25th 07, 02:16 AM posted to rec.aviation.ifr
Mark Hansen
Dennis
The EFC is of use only if you experience communication failure. Assuming
that's the case, then with no EFC, you're expected to proceed upon reaching
the holding fix as though the EFC was zero.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old September 25th 07, 02:36 AM posted to rec.aviation.ifr
BillJ
I'm probably over-thinking holding patterns and have become confused.
When given instructions to hold at a non-published holding pattern, ATC will
specify:
1. The direction from the fix, such as north, north-east, etc.
2. The name of the holding fix.
3. The radial, course, or airway on which the aircraft is to hold.
4. The leg length and direction of turns if they are not standard.
5. The expect further clearance time.
Here's my question: If I'm told to hold on a radial (as opposed to a
course), does that mean that I'm flying away from the station when I'm "on
course" in the holding pattern?
For example, I'm given the instruction, "Hold south of the VOR on the 180°
radial, expect further clearance in 15 minutes." Once I get established in
the holding pattern, do I track inbound to the station on the 180° radial or
do I track outbound on the 180° radial?
How would that be different if I were given the same instructions, except
hold on the 180° course (instead of the 180° radial)?
Dennis
Remember on the outbound leg you are correcting for the wind with double
or triple the crab angle used inbound. So you will not be tracking
parallel to any radial if there is a wind.
Bose X - $995 and holding... [email protected] Piloting 23 November 30th 05 12:57 AM
Holding pattern reporting Yossarian Instrument Flight Rules 14 July 4th 05 10:57 AM
Stupid Newbie Pattern Question Lakeview Bill Piloting 76 June 11th 05 02:54 PM
Holding at CHS Stuart King Instrument Flight Rules 3 November 10th 03 07:52 PM
Holding Pattern Entries Dan Luke Instrument Flight Rules 17 July 11th 03 05:18 AM
