Rod ends in single shear
Old September 26th 07, 05:58 AM posted to rec.aviation.homebuilt
Steve S.
Default Rod ends in single shear
Folks:
First let me say that I know well that everything is supposed to be in
double shear. Lord knows I have busted my butt to make sure
everything is in double shear.
But.
I have a portion of my aileron circuit that has a fork fitting to
provide the requisite double shear. However the bolt hole in the
crank is seeing some misalignment and is starting to wallow the hole.
I really, really should replace the fork fitting with a rod end (i.e.
it never should have been a fork fitting to begin with, it was a spur-
of-the-moment fix that was really just a band-aid). But the crank
being driven by the fork is going to be impossible to replace with a
two-armed crank that can nest a rod end.
So, I am faced with the possibility of using a rod end in single
shear. I know that this is viewed as being undesirable, as the
bearing can be popped out of the eye under certain conditions. I also
know that the traditional trick to compensate for this is to use a 970
washer (large area washer) on the outer end of the bolt holding the
rod end, such that if the bearing leaves the eye the washer prevents
the rod from departing the scene.
Now, with all of that said, here's my question: How bad is it really
to have the rod end in single shear if I do the washer trick? It's an
aileron rod, I do not think it sees much load at all--certainly far,
far short of it's rated load. I have seen several planes out there
with rod ends in single shear, so it can't be complete suicide . . .
right? No?
Thank you for your thoughts.
Steve.
Old September 26th 07, 06:25 AM posted to rec.aviation.homebuilt
Ed Sullivan
On Tue, 25 Sep 2007 21:58:46 -0700, "Steve S."
Folks:
But.
right? No?
I have a number of them that have been in service for over 20 years,
all with the large washer. Works for me.
Ed Sullivan, Jungster II
Old September 26th 07, 07:34 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Folks:
But.
right? No?
Long as teh arm and bolt are stiff enough not to deform - who cares...
Old September 27th 07, 04:33 AM posted to rec.aviation.homebuilt
On Sep 26, 12:34 am, cavelamb himself wrote:
Folks:
But.
right? No?
The single arm may not have the resistance to twisting that
the two arms do together. You'd want to compare single-arm setups with
what you have. An arm that allows twisting will eventually fail or
might allow enough aileron play to start flutter. Both are bad news.
Dan
Old September 27th 07, 07:45 AM posted to rec.aviation.homebuilt
right? No?
Dan
As long as the uiball is tight against the bell crank or horn there
will be no play.
:Ed
True, nut not necessarily the whole story, Ed.
Because there is a small moment due to the off-axis pushrod, the
arm itself could flex.
If the arm is really thin metal (as possible if a sheet steel part
were used) it MIGHT be possible to excite the aileron system -
ie: cause flutter.
Richard
Shear Pins for Propellors? Rich Lemert Piloting 25 April 3rd 05 09:04 PM
IFR w/pax under Single-Pilot/Single Aircraft 135 Bravo8500 Owning 20 March 9th 05 09:37 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
