It might have cost a little more, but when you are spending, what, over 200
AMU's to buy an airplane, should it not be possible to include some design improvements that costs a little more, than take the easy way out with nearly a dozen added (should be) unnecessary drains? They're not just unnecessary -- they're dangerous. That is 13 separate points of failure that should not be in that wing. I've had several quick drains leak over the years -- one quite badly -- now imagine 13 of them! All plumbing fittings, by their very nature, will eventually leak. These will, too. There's really no other way to put it: Cezzzna really screwed the pooch with their wing design. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Recently, Jay Honeck posted:
It might have cost a little more, but when you are spending, what, over 200 AMU's to buy an airplane, should it not be possible to include some design improvements that costs a little more, than take the easy way out with nearly a dozen added (should be) unnecessary drains? They're not just unnecessary -- they're dangerous. That is 13 separate points of failure that should not be in that wing. I've had several quick drains leak over the years -- one quite badly -- now imagine 13 of them! All plumbing fittings, by their very nature, will eventually leak. These will, too. There's really no other way to put it: Cezzzna really screwed the pooch with their wing design. Our club's 172 SP had those drain points. As I recall, only 10 of them were in the wing, with the other 3 on the cowling. I can only imagine the pretzel fuel flow that made that many drains necessary. I agree with the OP that suggested that Cessna's lawyers designed that aspect of their planes. Neil |
On Tue, 02 Oct 2007 09:56:00 GMT, "Neil Gould"
wrote: Recently, Jay Honeck posted: It might have cost a little more, but when you are spending, what, over 200 AMU's to buy an airplane, should it not be possible to include some design improvements that costs a little more, than take the easy way out with nearly a dozen added (should be) unnecessary drains? They're not just unnecessary -- they're dangerous. That is 13 separate points of failure that should not be in that wing. I've had several quick drains leak over the years -- one quite badly -- now imagine 13 of them! All plumbing fittings, by their very nature, will eventually leak. These will, too. There's really no other way to put it: Cezzzna really screwed the pooch with their wing design. Our club's 172 SP had those drain points. As I recall, only 10 of them were in the wing, with the other 3 on the cowling. I can only imagine the pretzel fuel flow that made that many drains necessary. I agree with the OP that suggested that Cessna's lawyers designed that aspect of their planes. AIUI, it's because they're bladders and folds on the bottom could gather water. If it was a wet wing they wouldn't need as many, like the older models. |
Help
I flew a 'Top Hat' four way trim switch for thousands of hours and never saw a second one. Anyone know where it was located? Our emergency procedure for run away trim was to pull the circuit breaker(s). Big John ************************************************* On Fri, 28 Sep 2007 09:43:28 -0700, "Robert M. Gary" wrote: On Sep 28, 9:15 am, Christopher Brian Colohan wrote: After flying Tomahawks and Citabrias, I took my first lesson in a Cessna 172 last night. I asked many questions, but I had one question which nobody in my flying club (including the chief pilot) knew the answer to when I was the Why does the electric elevator trim have two switches (both of which must be depressed) on the yoke instead of one? I assume this is a recent model 172. To avoid a stuck switch (or shorted switch) from running the trim. In the preflight checklist that Cessna provides one of the tests under the "trim test" section is to ensure that the trim does not move with either of the switches is moved by itself. Additionally you should ensure that the electric trim does not work at all when the auto-pilot cut-off is held down. The best theory I could come up with was "to avoid runaway trim if one switch stuck", but that is not very satisfying... Anyone know why? Chris |
Big John wrote in
: Help I flew a 'Top Hat' four way trim switch for thousands of hours and never saw a second one. Anyone know where it was located? Our emergency procedure for run away trim was to pull the circuit breaker(s). Switches like that are illegal now. You have to have passive fail systems on trims and autopiots nowadays. Bertie |
Bertie
I'm going to the "Wings over Houston" Air Show at Ellington this week end. Besides getting some cockpit time in the P-40 and P-51, I'll talk to some of the current Heavy Iron drivers, with birds on display, about what the trim is on the birds newer than I flew. From past shows expect to see at least the F-15, F-16, F-117 and also Navy jets, Blue Angels, etc. Probably some Chinese Migs that were kept at Ellington. Its 62 years since I flew the P-40 and 58 years since I flew the P-51 so need the cockpit time to refresh where all the controls, etc., were/are ![]() Big John ************************************************** *****88 On Sun, 30 Sep 2007 07:47:28 +0000 (UTC), Bertie the Bunyip wrote: Big John wrote in : Help I flew a 'Top Hat' four way trim switch for thousands of hours and ----clip---- Switches like that are illegal now. You have to have passive fail systems on trims and autopilots nowadays. Bertie |
Big John wrote in
: Bertie I'm going to the "Wings over Houston" Air Show at Ellington this week end. Besides getting some cockpit time in the P-40 and P-51, I'll talk to some of the current Heavy Iron drivers, with birds on display, about what the trim is on the birds newer than I flew. From past shows expect to see at least the F-15, F-16, F-117 and also Navy jets, Blue Angels, etc. Probably some Chinese Migs that were kept at Ellington. Its 62 years since I flew the P-40 and 58 years since I flew the P-51 so need the cockpit time to refresh where all the controls, etc., were/are ![]() Have fun! Ask 'em if they have any LeBlond valve springs while you're there. Bertie |
If the switches are in parallel and one of them develops an internal short
circuit, you will still have trim runway; if they are in series, both must be closed simultaneously. Sounds like a dumb idea to me, but check with a mechanic or radio shop for a knowledgeable answer...I'm not sure that I would expect the Chief Pilot to be the expert on electrical questions. Bob Gardner "Christopher Brian Colohan" wrote in message ... After flying Tomahawks and Citabrias, I took my first lesson in a Cessna 172 last night. I asked many questions, but I had one question which nobody in my flying club (including the chief pilot) knew the answer to when I was the Why does the electric elevator trim have two switches (both of which must be depressed) on the yoke instead of one? The best theory I could come up with was "to avoid runaway trim if one switch stuck", but that is not very satisfying... Anyone know why? Chris (Another question: 13 fuel drains? What were they thinking??? But I am pretty sure the answer is "the lawyers designed that part, not the engineers.") |
On Sep 28, 1:30 pm, "Bob Gardner" wrote:
If the switches are in parallel and one of them develops an internal short circuit, you will still have trim runway; if they are in series, both must be closed simultaneously. Sounds like a dumb idea to me, but check with a mechanic or radio shop for a knowledgeable answer...I'm not sure that I would expect the Chief Pilot to be the expert on electrical questions. Bob, I'm curious why you think it's a dumb idea? As far as I know they are in series and it seems like a fairly clever idea to me since it greatly reduces the possibility of a malfunctioning switch causing runaway trim. I'm not sure if it's a solution looking for a problem or if that's a legitimate concern, but given how simple and cheap it is to implement, why not? |
My memory isn't what it used to be, and though I flew a lot of planes with
trim switches I don't remember there being two. I must have a "two separate actions" thing going on in my thinking machine. Bob "tjd" wrote in message ups.com... On Sep 28, 1:30 pm, "Bob Gardner" wrote: If the switches are in parallel and one of them develops an internal short circuit, you will still have trim runway; if they are in series, both must be closed simultaneously. Sounds like a dumb idea to me, but check with a mechanic or radio shop for a knowledgeable answer...I'm not sure that I would expect the Chief Pilot to be the expert on electrical questions. Bob, I'm curious why you think it's a dumb idea? As far as I know they are in series and it seems like a fairly clever idea to me since it greatly reduces the possibility of a malfunctioning switch causing runaway trim. I'm not sure if it's a solution looking for a problem or if that's a legitimate concern, but given how simple and cheap it is to implement, why not? |
"Bad pressure switches discovered in Ospreys" | Mike[_1_] | Naval Aviation | 0 | June 22nd 07 07:14 PM |
How much do you trim? | Mxsmanic | Piloting | 89 | October 13th 06 05:14 AM |
Gear Warning Switches on a Mosquito | scooter | Soaring | 6 | March 9th 05 01:15 PM |
Fading Rocker Switches | O. Sami Saydjari | Owning | 2 | February 16th 04 03:54 PM |
FS on EBAY, circuit breaker switches | flyer | Home Built | 0 | December 3rd 03 06:59 PM |
