" wrote:
Michael Williamson wrote: wrote: Peter, what did they do to the Herc that they flew off of the Forrestal(?) ? (without JATO at that!) Well, it does help with ground run if you can guarantee a 30 kt wind down the runway every time... Mike That's true isn't it?...one tends to forget that ~30 knots is a LOT of airspeed gain, especially at the top of the take-off roll range, takes a comparatevly long time to gather that extra speed. An a/c that you normally rotate at 105 you now rotate at 75 (well, not really but you get my drift) There's also the advantage that you don't have to pull G off the end of the deck, in order to leave the 'ground' and climb over obstacles. Indeed, you can even sink a bit. And of course, the a/c was almost certainly nowhere near MTOW -- max. landing weight (8fps) is only 130,000 lb., vice the 155,000 or 175,000 lb. MTOW, and I imagine the a/c was well under max. landing weight when it landed. The Herc's power-on stall speeds (100% flaps) at landing weights are under 100 knots. For instance, at a landing weight of 110,459 lb. it has power off/on stall speeds (100% flaps) of 80/65 kts. At 122,586 lb. they're 91/75 kts. 50% flaps would be used for takeoff, but even with no wind, at a t/o weight of 100,000 lb. the a/c has a ground run of only 1,500 ft. at sea level. Add 30 kts or more of wind over deck and the Herc's ability to land or takeoff from a large deck carrier isn't a surprise. Guy |
"Gord Beaman" wrote in message news ![]() Peter, what did they do to the Herc that they flew off of the Forrestal(?) ? (without JATO at that!) -- -Gord. Still around as a USMC KC-130. Tex |
"Tex Houston" wrote:
"Gord Beaman" wrote in message news ![]() Peter, what did they do to the Herc that they flew off of the Forrestal(?) ? (without JATO at that!) -- -Gord. Still around as a USMC KC-130. Tex Oh yes indeed, Quite successful, I have the film clips here, impressive. Didn't look like it dropped at the end of the deck either, seemed to be climbing smartly. -- -Gord. |
| Thread Tools | |
| Display Modes | |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| U.S. Air Force award of four rocket launches this year is likely to be delayed | Larry Dighera | Military Aviation | 15 | May 14th 04 02:58 PM |
| Air Force launches rocket with secret military payload from Cape Canaveral | Otis Willie | Military Aviation | 0 | September 9th 03 10:07 PM |
