#11
I bought a used Cherokee 180 back in 1985. It had a Nav12 and a Nav11. Both
had been OHC by Narco right before I bought the plane. I never had a problem with either unit. Of course, I don't know what the previous owner paid Narco.... "Ray Andraka" wrote in message ... Edward A. Falk wrote: OK, my nav122 has died with a stupid mechanical failure in the frequency-selection gear. Seriously, WTF was Narco thinking when they put plastic gears in such an expensive box? So, question the first: Does anybody make aftermarket replacement parts, or should I buy a dead unit and canibalize it? Question the second: If I choose not to fix it, what are good options for a replacement? Does anybody make a clever all-in-one gps or something that would fit in the same panel hole? -ed falk You could call Narco and ask what they'd charge for putting new gears in. I've found their factory service to be quite reasonable. The only caveat is that they will go over the entire unit, bringing it up to the latest mods and doing a full factory acceptance test on it before they let it back out. The upside is that you get a 90 day warranty on the entire unit. From what I understand, whether it is worth it or not depends on the serial number, earlier ones used different boards and have more problems with connectors and what not, and may not be economically repairable. Mine is a "B" chassis, whose synthesizer board went bad. Narco fixed the synth card (replaced a ROM), repainted the face and needles, replaced gears that were cracked but had not failed altogether yet. There was something else they fixed too, but I can't recall what it was. The total charge was under $250 (this was 2 years ago this month). That was well worth it in my book, far less than the cost of any replacement, and less than I got for the NAV 11 on EBay that this unit replaced. Narco will do a flat-fee evaluation of your unit and call you with the cost to repair if you choose as well. The flat fee I think is 1 hour of shop time, which I think was $105. If you choose to repair, that fee is applied toward your repair. |
In article om,
Paul kgyy wrote: I don't know what your panel space requires, but consider a reconditioned King KX125 - has a built-in CDI. Nice unit, but I only have the 3" hole to fill. Also, the Nav122 had glide slope and marker beacon as well. AFICT, *nobody* makes anything with near the capability as that old 122. Too bad. Anywy, it seems I have a number of options available to me; thanks for all your help. -- -Ed Falk, http://thespamdiaries.blogspot.com/ |
In article om, Paul kgyy wrote: I don't know what your panel space requires, but consider a reconditioned King KX125 - has a built-in CDI. Nice unit, but I only have the 3" hole to fill. Also, the Nav122 had glide slope and marker beacon as well. AFICT, *nobody* makes anything with near the capability as that old 122. Too bad. Anywy, it seems I have a number of options available to me; thanks for all your help. Can you find a spot for a marker beacon receiver/display or replace your audio panel with one that has a MB rec in it? If you can, I think the best bet might be a new Nav122D, which has the VOR/LOC reciever functions of the older Nav122 without the MB receiver. Most audio panels these days have an option for an integrated MB receiver. If not, then maybe try to find as late a model of a used 122B as you can in hopes of getting the decent circuit boards & connectors and then refurbishing it if needed. I think you can still get refurbished 122B's from Narco. |
IFR GPS replace DME / ADF? | [email protected] | Instrument Flight Rules | 21 | May 15th 06 03:13 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Tony | Naval Aviation | 290 | March 7th 04 07:58 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Naval Aviation | 2 | February 22nd 04 06:22 AM |
Replace (Fix) ADF? | Tom Nery | Owning | 32 | November 3rd 03 03:30 PM |
