Cessna Anticipates AvGas Demise
Old October 5th 07, 06:36 PM posted to rec.aviation.piloting
Default Cessna Anticipates AvGas Demise
On Oct 5, 10:42 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
Stefan wrote:
Cessna will offer the 172S Skyhawk with a Thielert turbo diesel
engine
I'd rather say that Cessna is anticipating the difficulty to explain
why they still sell engines with 50 year old technology, once the
pilots start to recognize that there are modern engines around which
burn less than half the fuel.
Are you saying the Thielert turbo diesel burns half the fuel? Wow!!!
A bit more than half. The 135 hp Centurion burns around 4
GPH in cruise. And that's Jet-A, which costs considerably less than
100LL.
The avgas supplies threaten to dry up because the
refineries don't want to bother with it. Avgas constitutes something
like 1% or less of the gasoline market, and carries hundreds of times
the liability. Would you bother with it under those conditions?
Dan
Old October 6th 07, 01:21 AM posted to rec.aviation.piloting
On Oct 5, 12:46 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
engine
100LL.
Dan
Apples and oranges Dan, the engine that is going in the new Skyhawk is a
turbocharged 155HP. What does it burn?
Dunno that. The original Thielert STC was for a 135 hp engine
in a Skyhawk. Less than the original engine, and a little less
performance because of that, but it generated that hp at about 2300
propeller RPM instead of the Lycoming's 2700 so that less hp would be
lost to drag.
See http://www.centurion-engines.com/
Dan
Old October 6th 07, 01:48 AM posted to rec.aviation.piloting
Larry Dighera
On Fri, 5 Oct 2007 13:46:06 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote in
turbocharged 155HP
How will that affect useful load compared to the 180 HP equipped
C-172S?
Old October 6th 07, 01:45 AM posted to rec.aviation.piloting
Larry Dighera
On Fri, 05 Oct 2007 18:23:29 +0200, Stefan
wrote in :
Cessna will offer the 172S Skyhawk with a Thielert turbo diesel engine
I'd rather say that Cessna is anticipating the difficulty to explain why
they still sell engines with 50 year old technology, once the pilots
start to recognize that there are modern engines around which burn less
than half the fuel.
I like the idea that there is more energy per pound in Jet A fuel than
AvGas, but I have no idea of the failure modes nor expected TBO and
other performance, operational, and maintenance issues. What should a
pilot expect to find has changed in the Thielert engine equipped C-172
other than higher power available at altitude, increased range, and
fewer refueling options?
Old October 6th 07, 02:41 AM posted to rec.aviation.piloting
Vaughn Simon
"Larry Dighera" wrote in message
news
AvGas,
Whoa! There is more energy in Jet A per GALLON. Depending on which weight
and BTU averages you are using, Jet A and Avgas come out pretty close on BTUs
per pound. Remember, Jet fuel is heavier than gasoline.
Vaughn
Old October 6th 07, 02:43 AM posted to rec.aviation.piloting
Roy Smith
news
AvGas,
weight
Which weighs more, a pound of Jet-A or a pound of Avgas?
Old October 6th 07, 03:10 AM posted to rec.aviation.piloting
Ron Lee[_2_]
news
AvGas,
weight
Can't tell you
However, I know that my fuel tanks hold 38 gallons. What is that
weightwise for 100LL and Jet-A?
Ron Lee
Old October 6th 07, 12:31 PM posted to rec.aviation.piloting
Matt Whiting
news
AvGas,
weight
It depends on how much you pay for it. As you need to subtract the
weight lost from your wallet from the fuel to get net weight per pound.
Matt
Old October 6th 07, 05:45 AM posted to rec.aviation.piloting
M[_1_]
On Oct 5, 6:41 pm, "Vaughn Simon"
It's pretty close, but Jet A should have slightly higher BTU per pound
due to larger average hydrocarbon molecules in jet fuel.
The biggest difference is that the diesel engines have higher thermo
efficiency than gasoline engine, therefore their BSFC is quit a bit
lower. It burns less pound of fuel per hour to produce the same
horsepower on a diesel engine. Another factor, which only has to do
with economy, is that we pay for fuel in volume (gallons), not
pounds. If Jet A and 100LL are both $4 per gallon, you get more
pounds of jet A with that $4. These two factor combined, diesel
powered Cessna would burn about 30% less $ worth of fuel per hour at
the same power output, assuming JetA and 100LL cost the same per
gallon. That's quite significant. These days it seems that Jet A is
consistently less per gallon than 100LL.
BTW, the 135HP Thielert has a CS prop so that it can put out 100% of
rated power during takeoff and climb. That should produce about the
same horsepower as the 160HP C-172 with a fixed pitch prop.
It's really about time for Cessna to wake up to the fact that the low
end GA is being slowly strangled partly caused by the use of 100LL in
GA fleet. As a fuel, 100LL has this strange economy that the less the
overall consumption, the higher the price delta between 100LL and
autofuel. Remember 100LL requires special handling in the entire
chain of manufacturing and distribution, and it's not transported by
pipeline in the U.S. That largely fixed infrastructure cost has to be
amortized over a ever shrinking pool of consumption. We already see
the average price gap between 100LL and autofuel widen in the last few
years to something more like $1.30 - $1.50. It's going to get worse.
The low end GA, which is most sensitive to the fuel price, is getting
squeezed because 100LL is the only fuel they can use at most airports,
except for a few lucky ones that can use autofuel STC and have access
to ethanol free autofuel.
100/130 avgas Roy Smith General Aviation 1 December 24th 06 09:17 AM
Old AvGas gwengler Piloting 2 December 16th 06 01:07 PM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
The demise of the Sea Harrier Henry J Cobb Naval Aviation 39 April 25th 04 07:27 PM
Here's to Arafat's Speedy Demise robert arndt Military Aviation 0 September 12th 03 07:45 AM
