#11
Arno,
Does anyone feel the same? Am I missing a particular technique? Many reviewers have mentioned this. It seems to be mostly a mater of training. Also, setting the respective bugs to the desired value seems to help most pilots. -- Thomas Borchert (EDDH) |
Bertie the Bunyip wrote: You don't do trig while you're shooting pool and expect to win the game. You're right, I do geometry. :-)) |
john smith wrote in
: In article , Bertie the Bunyip wrote: You don't do trig while you're shooting pool and expect to win the game. You're right, I do geometry. :-)) Nobody can do geometry properly with the required alchohol load to play pool properly Bertie |
![]() wrote in message ups.com... On Oct 6, 9:21 am, Arno wrote: Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno You'll get used to it... there is a transition time to go from round dial to tapes, but once you get used to tapes you will find that they do have certain advantages. I worked on the 777 EFIS, which used the tape format, and after several hours in the 777 simulator, the tapes became as easy to read at a glance as the round dials. It just takes conditioning your mind to be able to rapidly scan them, and being able to pick up trend information from the tape motion instead of needle motion. At least that was my experience. A lot of human factors work went into the tape formats, and it was with the understanding that training would be required for pilots to adapt to them. Dean I have never seen the system for the 777, but I did get a look at the low end equipment at the LSA Expo in Sebring Florida, and felt that what I saw was pure crap! It is certainly possible to make a tape motion system that works well, and I have seen some "physical" versions that I liked when I was an avionics tech twenty years ago. However, those have a moving needle which moved in opposition to the moving tape and at a slower rate than the tape. The result was that the needle gave the coarse indication, at a glance, and the tape gave the precise measurement when required--and, in the case of a higher flying aircraft which would require a three needle altimeter, may have been more intuitive to read. However, on the implementations that I have seen, the representations of needles were fixed and the numbers moved on a virtual card or tape. In my opinion, they were egregeous! Peter |
![]() "Bertie the Bunyip" wrote in message .. . Phil wrote in news:1191696116.820241.83540@ 19g2000hsx.googlegroups.com: On Oct 6, 10:21 am, Arno wrote: Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno I am a fellow computer geek, and a student pilot. I usually fly a plane with steam gauges, but a couple of times now I have flown with digital displays. Like you, I found it a little hard to adjust to the digital displays. The digital displays I was using presented altitude and tachometer values simply as numbers. The analog displays I am used to present these values as positions on a dial, showing the current value in its context of a spectrum of values. With the analog displays, I am used to adjusting the position of the pointer. With the digital display, I need to simply set the correct numerical value. It's a little mental adjustment, and given that I am a newbie to all this it is an extra distraction. But, I do think that it is mostly a matter of what you are used to. Flying is a right hand brain activity. At least the handling portion is. The right hand side of the brain dosn't do abstractions like numbers, at least not until the left hand side (which can't fly worth a ****) sends it over to the right side in a readily digestable form which enables the right brain to chew it into a picture. An analogue display cuts the left hand side out of the loop and enables the calcualtion rate to increase the right sides "frame rate" so that corrections can be made more frequently thus enabling the pilot to fly the airplane more smooothly and with more authority. Caorse rule of thumb math can be laid over this for descent angles, interceptin angles and wo on, but generally, the fewer numbers involved, the better. People who prefer the numbers usualy don't fly very well at all. You don't do trig while you're shooting pool and expect to win the game. Bertie Very well said! Peter |
with the understanding that training would be required for pilots to adapt to them. That's interesting. Do you have any reference of research comparing various display methods? Tapes for speed and altitude in today's cockpits are ubiquitous of course. So far I thought it was a case of someone starting it and others just copying it. Arno |
"Peter Dohm" wrote in news:x1SNi.1432$aa.376
@bignews1.bellsouth.net: "Bertie the Bunyip" wrote in message .. . Phil wrote in news:1191696116.820241.83540@ 19g2000hsx.googlegroups.com: On Oct 6, 10:21 am, Arno wrote: Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno I am a fellow computer geek, and a student pilot. I usually fly a plane with steam gauges, but a couple of times now I have flown with digital displays. Like you, I found it a little hard to adjust to the digital displays. The digital displays I was using presented altitude and tachometer values simply as numbers. The analog displays I am used to present these values as positions on a dial, showing the current value in its context of a spectrum of values. With the analog displays, I am used to adjusting the position of the pointer. With the digital display, I need to simply set the correct numerical value. It's a little mental adjustment, and given that I am a newbie to all this it is an extra distraction. But, I do think that it is mostly a matter of what you are used to. Flying is a right hand brain activity. At least the handling portion is. The right hand side of the brain dosn't do abstractions like numbers, at least not until the left hand side (which can't fly worth a ****) sends it over to the right side in a readily digestable form which enables the right brain to chew it into a picture. An analogue display cuts the left hand side out of the loop and enables the calcualtion rate to increase the right sides "frame rate" so that corrections can be made more frequently thus enabling the pilot to fly the airplane more smooothly and with more authority. Caorse rule of thumb math can be laid over this for descent angles, interceptin angles and wo on, but generally, the fewer numbers involved, the better. People who prefer the numbers usualy don't fly very well at all. You don't do trig while you're shooting pool and expect to win the game. Bertie Very well said! Thenkew Bertie |
Dean,
I just noticed something interesting, looking at pictures of recent Boeing and Airbus PFDs. For altitude, they are both pretty much the same, but for the speed tape, Airbus does not have a big number at the center of the tape but instead the number on top of the tape and just a thin line at the center. After my experience today I like the Airbus better because it is less conducive to reading the numbers rather than "get the picture": Airbus A340: http://simflight.nl/users/reviews/CL...nshots/PFD.jpg Boeing 777: http://www.meriweather.com/777/fwd/pfd.html Arno |
ups.com... .... You'll get used to it... there is a transition time to go from round dial to tapes, but once you get used to tapes you will find that they do have certain advantages. I worked on the 777 EFIS, which used the tape format, and after several hours in the 777 simulator, the tapes became as easy to read at a glance as the round dials. It just takes conditioning your mind to be able to rapidly scan them, and being able to pick up trend information from the tape motion instead of needle motion. At least that was my experience. A lot of human factors work went into the tape formats, and it was with the understanding that training would be required for pilots to adapt to them. Dean Hey Dean, the tape systems I've seen have the scale fixed on the display and the tape that moves up and down the scale appropriately. That is not how the Garmin system works from what I've seen. The G1000 in the local 182 actually moves the scale in relation to a fixed pointer that is mid-scale on the display, so you have to read numbers relative to a pointer instead of judging a tape marker relative to a fixed scale. This is much more difficult than the old fixed scale displays, but I don't see how they could cram as much on the screen as they do if they still used fixed scale depictions. Those old instruments used the barberpole concept very well and went right along with the round gages for system monitoring where we would rotate the gauges in the panel such that "normal" had all needles pointing the same direction; no interpretation needed unless one of the needles wasn't pointing like the rest. In some ways technology has made the panel much less intuitive and more time consuming. Think about traffic signals - Red means stop, but we could have just as easily put up a digital display that said "Cross traffic beginning". Which would be easier for the driver to interpret most quickly? -- Jim Carter Rogers, Arkansas |
OSH Homerun? Glass Cockpit for the Budget-Challenged | Marco Leon | Piloting | 4 | July 27th 07 11:27 PM |
winter is hard. | Bruce Greef | Soaring | 2 | July 3rd 06 06:31 AM |
Why Not Use PC To Make Glass Cockpit? | Le Chaud Lapin | Instrument Flight Rules | 52 | July 19th 05 03:45 AM |
It ain't that hard | Gregg Ballou | Soaring | 8 | March 23rd 05 01:18 AM |
Glass Cockpit in Older Planes | Charles Talleyrand | Owning | 2 | May 20th 04 01:20 AM |
