Matt Whiting wrote:
Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) It doesn't (in metals) unless the temperature change is very high and very localized as in welding. -- Jim Pennino Remove .spam.sux to reply. |
rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) How 'bout this: It's the disparate rates of cooling in some parts of the engine (versus others) that causes the differential cooling that induces stress? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) How 'bout this: It's the disparate rates of cooling in some parts of the engine (versus others) that causes the differential cooling that induces stress? Yes, that is what I said originally. It is differential cooling that causes the problem, not the rate of cooling itself. If you could cool the entire engine uniformly, I don't think it would matter much how fast you cooled it. It isn't the rate itself that causes a problem, it is the difference in rates from one location to another. However, I still think that the greatest thermally induced stress occurs during the initial heat-up from a cold start, but I don't have any data to confirm that and I don't have an instrument airplane with which to collect the data. Matt |
"Matt Whiting" wrote in message news ![]() Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) Matt By implication, a fast cooling rate would cause *more* differential cooling, since the cylinders cool from the fins inward. The faster the cooling, the higher the delta-T between the internal and external surfaces of the cylinders. The higher the delta, the more internal stresses on the cylinders due to the different growth between the hot and cold surfaces. But you already knew that and were just being difficult, eh? KB |
Kyle Boatright wrote:
"Matt Whiting" wrote in message news ![]() Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) Matt By implication, a fast cooling rate would cause *more* differential cooling, since the cylinders cool from the fins inward. The faster the cooling, the higher the delta-T between the internal and external surfaces of the cylinders. The higher the delta, the more internal stresses on the cylinders due to the different growth between the hot and cold surfaces. But you already knew that and were just being difficult, eh? It is a subtle point maybe, but an important one. It isn't the rate of cooling that matters. It is a difference in rate between two locations. Faster cooling doesn't necessarily a greater differential, it all depends on how the cooling is done. In some materials and at some temperatures, the rate of cooling can change the fundamental material properties. That is a different issue than what is involved with engines. Matt |
Matt Whiting wrote:
When I practiced in my Skylane and also in the club Arrow, I retarded the throttle smoothly in probably 2-3 seconds. I didn't worry about shock cooling and never saw any signs of distress in either the O-470 or the O-360. I have an 0-320, and we probably take 3-5 seconds to smoothly retard the throttle to idle during simulated engine failure practice. Thinking back to the *actual* engine failure due to oil loss, the time elapsed between seeing no oil pressure on the gauge, the initial obvious signs that the engine was seizing (bucking and shaking), and the time it quit completely was probably a total of 10 seconds. So comparing the simulated engine failure to THAT type of actual engine failure, taking 5 seconds to retard the throttle is NOT out of the realm of realism or accuracy with regard to simulated practice. To Jay, do you monitor your engine analyzer when you go from cruise power into the pattern and then pull the throttle back during your approach? How gradually do you pull power back there, and how do the temps on the analyzer compare to what you did in the simulated engine-out practice? Shirl |
power into the pattern and then pull the throttle back during your approach? How gradually do you pull power back there, and how do the temps on the analyzer compare to what you did in the simulated engine-out practice? Yep. The shock-cooling alarm never goes off during a regular approach, because of the gradual nature of things. By the time we enter downwind, we've got the prop and mixture full forward, and are adjusting manifold pressure (throttle) only slightly to control airspeed. We're looking for 100 mph/90 knots on downwind. This wind-down from cruise speed (160 mph/140 knots) usually takes several minutes, unless we're being asked to keep our speed up at a controlled field. We generally carry power into the flare (hey, it's a Cherokee, and a nose-heavy one at that), slowly retarding power as we touch down. Apparently this procedure (which we do without thinking about it) is engine-friendly enough to keep the temperature rate-of-decline outside of the shock cooling alarm's parameters. In the future I think we'll practice slow flight (which mimics this whole engine management procedure) before practicing engine-out stuff. That should prevent the whole shock-cooling problem, methinks. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
Jay Honeck wrote: In the future I think we'll practice slow flight (which mimics this whole engine management procedure) before practicing engine-out stuff. That should prevent the whole shock-cooling problem, methinks. Slow flight might increase the problem. You're mushing along with poor flow through the cowling, low airspeed and using power...perhaps you're going to increase engine temp. over cruise. As for the analyzer warning. I had one on my 182 when hauling jumpers. Just pushing the nose over at the top of the climb *without reducing power* would result in a "shock cooling" alarm, just the increase in airspeed created a cooling rate that exceeds the limits. I quickly learned to ignore the shock cooling warning. Trainer aircraft are flown hard all the time. Students/renters cram the power in on takeoff and yank it to idle on downwind time after time. Those engines last well. I flew jumpers for 17 years in 182s and 206s. With the exception of one airplane flown by an idiot (this guy would cram the power in right after start with no warmup) we didn't have to replace cylinders, engines went TBO or beyond. From my experience more damage is done on power increases than reduction. Be as gentle as you can to your engine but don't go crazy about the shock cooling thing. |
Jay:
In the future I think we'll practice slow flight (which mimics this whole engine management procedure) before practicing engine-out stuff. That should prevent the whole shock-cooling problem, methinks. Dale: Slow flight might increase the problem. You're mushing along with poor flow through the cowling, low airspeed and using power...perhaps you're going to increase engine temp. over cruise. That was my first thought, that slow flight would increase temp and, therefore, how would it prevent the shock-cooling problem (if indeed it is one)? |
| Thread Tools | |
| Display Modes | |
| Topi - Mig29 engine failure during practice - "topi.wmv" (14/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 10:15 PM |
| Topi - Mig29 engine failure during practice - "topi.wmv" (13/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 10:15 PM |
| Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 10:15 PM |
| Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 11:13 PM |
| A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 05:06 PM |
