How do you plan the descent in emergency landing practice?
Old October 15th 07, 08:01 PM posted to rec.aviation.piloting
brtlmj
Default How do you plan the descent in emergency landing practice?
Do you experienced pilots just have a sixth sense about how to get the
aircraft exactly where it needs to be? Is it something you consciously
analyze throughout the descent or just instinctlvely do?
It helps to know the typical field size in your area. Then you could
think "this is my intended touchdown point, I want to be two fields to
a side and three fields behind it, and see it at an angle of, say, 40
degrees".
Mind you, I have never flown power, and I am not exactly experienced
either :-)
Bartek
Old October 15th 07, 08:06 PM posted to rec.aviation.piloting
Stefan
brtlmj schrieb:
Glider pilots are taught to ignore altimeter during circuit and
landing.
Guess why I suggested the "looks about right" method... ;-)
Old October 15th 07, 08:08 PM posted to rec.aviation.piloting
Gig 601XL Builder
brtlmj wrote:
Correct. Additionally, altimeter will tend to stick with engine off.
WHAT?
Old October 15th 07, 08:31 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Knowing your power-off descent rate will help. In my plane, I know that
my power off descent rate at best glide speed is about 50% higher than the
500 ft./min rate that I generally use in a normal pattern. If I arrive at 1,
000 ft. AGL abeam of my landing spot. I know that I'll have to make an
abbreviated pattern to make the runway. I also aim for a spot a several
hundred feet down the landing area to prevent landing short. The sight
picture through the windshield on final will tell you where you're going to
go. If you're overshooting, your landing spot will move down. If you're
coming up short, the landing spot will move up in the windshield. I try to
overshoot slightly as I turn final, then adjust the descent rate with a hard
slip to put it down at the near edge of the landing area.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200710/1
Old October 15th 07, 08:57 PM posted to rec.aviation.piloting
brtlmj
WHAT?
Engine off - no vibration - altimeter sticks.
B.
Old October 15th 07, 09:16 PM posted to rec.aviation.piloting
Jim Logajan
WHAT?
Yet another failure mode for liquid crystal displays I hadn't known about.
Old October 15th 07, 09:51 PM posted to rec.aviation.piloting
Gig 601XL Builder
WHAT?
B.
In my one fixed wing engine out that didn't happen. But I could see where it
could.
Old October 15th 07, 10:09 PM posted to rec.aviation.piloting
Frank Ch. Eigler
where it could.
A parked altimeter consistently unmoved by overnight weather changes
could be a tip-off.
- FChE
Old October 16th 07, 05:54 PM posted to rec.aviation.piloting
Robert M. Gary
WHAT?
So what do they do during the IFR cert? Shake the plane around?
-Robert
Old October 16th 07, 06:52 PM posted to rec.aviation.piloting
brtlmj
I have no idea. As I said, I do not fly power. Is shutting down an
engine (or all engines) in flight required as a part of any
certification?
Bartek
Emergency landing at airfield Danny Deger Piloting 10 January 8th 07 06:31 PM
Emergency landing theoretical gatt Piloting 21 May 15th 06 03:07 PM
Live emergency landing on tv right now C. Massey Piloting 7 May 4th 06 02:49 AM
C-141 emergency landing Christchurch Miche Military Aviation 11 February 6th 04 04:04 AM
N30793, Emergency Landing Tom Hughes Piloting 5 August 21st 03 03:56 AM
