On Oct 15, 8:49 am, Bertie the Bunyip wrote:
The examiner wouldn't allow him to slip because he reckons they are dangerous with the flaps out and that he should wiggle the ailerons back and forth to lose height. He didn't even want him to slip clean. Jesus wept. This examiner had had a fright in a 172 (this was an archer anyway) and did not alow anyone to slip with flaps out. While I am firmly in the camp that says some cessnas can get a litle fuzzy in pitch with full flaps, this is just stupidity incarnate. Shoot. We do slips with full flaps all the time in 172s, have done so for years, and never had a scare. I wonder if that "Avoid Slips With Flaps Extended" applied to some earlier models? I'll have to check the TCDS sometime. Dan |
Matt: At least in my experience shock cooling did exist. I flew sky divers
in a Skylane and had taken over after another pilot who would climb hard and chop the throttle and descend to the ground. There were frequent low hour Top Over hauls, and cracked cylinders. When I began flying the bird the owner asked me to be aware of cooling it down to fast. My method was to climb to the drop and then close the cowl flaps, carry 15" MP and spiral tightly down. It stopped the low hour top overhauls. My descent rate could be pretty high and the engine was kept relatively warm. Stu Fields Experimental Helo Magazine. "Matt Whiting" wrote in message ... Bertie the Bunyip wrote: Matt Whiting wrote in It is the same if the same delta T is present, but my point is that it is easier to heat something quickly than cool it quickly. Even at 250 C, you are only 523 degrees above absolute zero. So, this the absolute largest delta T you can induce for cooling, and it is very hard to get absolute zero, so you are more likely to have a cool temp closer to 0 C yielding a delta T of only 250 degrees. On the hot side things are more open-ended. It isn't too hard to get 450 C exhaust gas temperatures. For an engine that is started at say 20 C ambient temperature, you now have a delta T of 430 degrees which is much greater than the 250 likely on the cooling side of the cycle. That is one reason why I suspect that "shock heating" is more likely to be an issue than "shock cooling." I suspect you can induce a higher delta T during a full-throttle initial climb than you can during an idle descent from a cruise power setting. Right, I'm with you now. yeah, I can buy that. Froma strictly clinical viewpoint it absolutely makes sense. My experience with damage says otherwise, though I can offer no explanation why that should be the case. Years ago I towed gliders with Bird-dogs and we cracked a lot of cylinders when we just closed the throttle after release. When we moved to gradual reduction to ultimately 1500 RPM the problem disappeared completely. Later, when I flew big pistons,the procedures for cooling down the cylinders on the way down. You were almost gaurunteed a crack if you yanked the taps closed. Can't see how we went from cold to hot any more than you would just starting up and taking off. I've just bought an aerobatic airplane with a Lycoming. We're not expecing to get to TBO with the engine because we'll be doing aerobaics with it, but of course we're prepared to live with that. I suppose the point I'm making is that even if shick cooling is over- rated, it certainly does no harm to observe trad practices as if it did. I suspect, as with most "real world" problems, that there is more in play than delta T induced stress. Probably geometry and other factors. Maybe having the thin fins on the outside vs. thick metal on the inside is making a big difference in the stress profile. I've not had experience with the larger engines or with radials. However, my experience with O-470 and smaller engines is that shock cooling just isn't an issue and many folks are paranoid for nothing. Operating the engine as if shock cooling was an issue is probably not a problem in most cases, but if it causes you, as it has with Jay, to not practice essential emergency procedures, then I disagree that it causes no harm. This may be very harmful should Jay experience an engine failure for real. Matt |
Matt Whiting wrote:
Bertie the Bunyip wrote: Matt Whiting wrote in It is the same if the same delta T is present, but my point is that it is easier to heat something quickly than cool it quickly. Even at 250 C, you are only 523 degrees above absolute zero. So, this the absolute largest delta T you can induce for cooling, and it is very hard to get absolute zero, so you are more likely to have a cool temp closer to 0 C yielding a delta T of only 250 degrees. On the hot side things are more open-ended. It isn't too hard to get 450 C exhaust gas temperatures. For an engine that is started at say 20 C ambient temperature, you now have a delta T of 430 degrees which is much greater than the 250 likely on the cooling side of the cycle. That is one reason why I suspect that "shock heating" is more likely to be an issue than "shock cooling." I suspect you can induce a higher delta T during a full-throttle initial climb than you can during an idle descent from a cruise power setting. Right, I'm with you now. yeah, I can buy that. Froma strictly clinical viewpoint it absolutely makes sense. My experience with damage says otherwise, though I can offer no explanation why that should be the case. Years ago I towed gliders with Bird-dogs and we cracked a lot of cylinders when we just closed the throttle after release. When we moved to gradual reduction to ultimately 1500 RPM the problem disappeared completely. Later, when I flew big pistons,the procedures for cooling down the cylinders on the way down. You were almost gaurunteed a crack if you yanked the taps closed. Can't see how we went from cold to hot any more than you would just starting up and taking off. I've just bought an aerobatic airplane with a Lycoming. We're not expecing to get to TBO with the engine because we'll be doing aerobaics with it, but of course we're prepared to live with that. I suppose the point I'm making is that even if shick cooling is over- rated, it certainly does no harm to observe trad practices as if it did. I suspect, as with most "real world" problems, that there is more in play than delta T induced stress. Probably geometry and other factors. Maybe having the thin fins on the outside vs. thick metal on the inside is making a big difference in the stress profile. I've not had experience with the larger engines or with radials. However, my experience with O-470 and smaller engines is that shock cooling just isn't an issue and many folks are paranoid for nothing. Operating the engine as if shock cooling was an issue is probably not a problem in most cases, but if it causes you, as it has with Jay, to not practice essential emergency procedures, then I disagree that it causes no harm. This may be very harmful should Jay experience an engine failure for real. Matt Shock cooling damage is merely the effect of different rates of thermal dimensional change between the aluminum cylinder head and the steel valve seats and possibly between the head and the barrel where its threaded on. When contracting, the head shrinks faster than the valve seats and barrel and huge tension stresses are built up in the area of the head between the valve and the nearest hole, which is usually the spark plug. Most shock cooling damage is a crack between the exhaust valve and the nearest plug hole. It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... Shock cooling is generally a problem when at the extremes, going from full power to idle. You won't get enough stress to cause damage going from cruise power to idle, so for airplanes not used for towing, or aerobatics or some flight training scenarios, it's not a problem. John |
"J.Kahn" wrote in
: Matt Whiting wrote: Bertie the Bunyip wrote: Matt Whiting wrote in It is the same if the same delta T is present, but my point is that it is easier to heat something quickly than cool it quickly. Even at 250 C, you are only 523 degrees above absolute zero. So, this the absolute largest delta T you can induce for cooling, and it is very hard to get absolute zero, so you are more likely to have a cool temp closer to 0 C yielding a delta T of only 250 degrees. On the hot side things are more open-ended. It isn't too hard to get 450 C exhaust gas temperatures. For an engine that is started at say 20 C ambient temperature, you now have a delta T of 430 degrees which is much greater than the 250 likely on the cooling side of the cycle. That is one reason why I suspect that "shock heating" is more likely to be an issue than "shock cooling." I suspect you can induce a higher delta T during a full-throttle initial climb than you can during an idle descent from a cruise power setting. Right, I'm with you now. yeah, I can buy that. Froma strictly clinical viewpoint it absolutely makes sense. My experience with damage says otherwise, though I can offer no explanation why that should be the case. Years ago I towed gliders with Bird-dogs and we cracked a lot of cylinders when we just closed the throttle after release. When we moved to gradual reduction to ultimately 1500 RPM the problem disappeared completely. Later, when I flew big pistons,the procedures for cooling down the cylinders on the way down. You were almost gaurunteed a crack if you yanked the taps closed. Can't see how we went from cold to hot any more than you would just starting up and taking off. I've just bought an aerobatic airplane with a Lycoming. We're not expecing to get to TBO with the engine because we'll be doing aerobaics with it, but of course we're prepared to live with that. I suppose the point I'm making is that even if shick cooling is over- rated, it certainly does no harm to observe trad practices as if it did. I suspect, as with most "real world" problems, that there is more in play than delta T induced stress. Probably geometry and other factors. Maybe having the thin fins on the outside vs. thick metal on the inside is making a big difference in the stress profile. I've not had experience with the larger engines or with radials. However, my experience with O-470 and smaller engines is that shock cooling just isn't an issue and many folks are paranoid for nothing. Operating the engine as if shock cooling was an issue is probably not a problem in most cases, but if it causes you, as it has with Jay, to not practice essential emergency procedures, then I disagree that it causes no harm. This may be very harmful should Jay experience an engine failure for real. Matt Shock cooling damage is merely the effect of different rates of thermal dimensional change between the aluminum cylinder head and the steel valve seats and possibly between the head and the barrel where its threaded on. When contracting, the head shrinks faster than the valve seats and barrel and huge tension stresses are built up in the area of the head between the valve and the nearest hole, which is usually the spark plug. Most shock cooling damage is a crack between the exhaust valve and the nearest plug hole. It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... Shock cooling is generally a problem when at the extremes, going from full power to idle. You won't get enough stress to cause damage going from cruise power to idle, so for airplanes not used for towing, or aerobatics or some flight training scenarios, it's not a problem. I can buy that.. Bertie |
![]() "J.Kahn" wrote Shock cooling damage is merely the effect of different rates of thermal dimensional change between the aluminum cylinder head and the steel valve seats and possibly between the head and the barrel where its threaded on. When contracting, the head shrinks faster than the valve seats and barrel and huge tension stresses are built up in the area of the head between the valve and the nearest hole, which is usually the spark plug. Most shock cooling damage is a crack between the exhaust valve and the nearest plug hole. It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... Shock cooling is generally a problem when at the extremes, going from full power to idle. You won't get enough stress to cause damage going from cruise power to idle, so for airplanes not used for towing, or aerobatics or some flight training scenarios, it's not a problem. Yours is the first explanation that I can believe. Thanks. I can also believe that cruise power to idle is not a huge problem, and that perhaps it is even more true if the airspeed is kept down a bit, while the power comes off. -- Jim in NC |
J.Kahn wrote:
It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... What about the aluminum piston in the steel cylinder? Matt |
: J.Kahn wrote: It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... What about the aluminum piston in the steel cylinder? That can happen too! But the clearances are cgrater ther than it would be in a valve stem or head to cylinder seat. Bertie |
On Fri, 19 Oct 2007 11:05:32 +0000 (UTC), Bertie the Bunyip
wrote: Matt Whiting wrote in : J.Kahn wrote: It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... What about the aluminum piston in the steel cylinder? That can happen too! But the clearances are cgrater ther than it would be in a valve stem or head to cylinder seat. If we had that kind of piston to cylinder clearance in an automotive engine we'd think it was worn out. :-)) At least in the "old days". Roger (K8RI) Bertie |
Engine out practice | Jay Honeck | Piloting | 155 | November 9th 07 03:07 AM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (09/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
