#11
Les Matheson wrote:
It may read to a number 40, but that is not degrees, it is units of AOA. Units are relatable to Angle of Attack, but not equal to angle. IIRC F-4 optimum turn was 16 units, not 16 degrees of AOA, buffet was 23 units. Pilots don't know degrees, they fly units. Test pilots and engineers can tell you what the unit-angle relation is, but it isn't 1:1. Les "Bill Daniels" bildan@comcast-dot-net wrote in message . .. Interesting question. This AOA indicator reads out to +40 degrees and AFIK no general aviation airfoil stalls at more than 16 degrees. Whatcha usin' in on? Bill Daniels "Dan" wrote in message ... I need the pinout for ARK-10A/A24G-8 AOA indicator. Part number is SLZ9421. Can anyone provide a source or the information? Dan, U.S. Air Force, retired Any idea what the conversion is? I have modified a vane AOA transducer to use synchro. I suppose I could figure it out. Dan, U.S. Air Force, retired |
![]() "Dan" wrote 1/2 scale A-10, aluminum, Vne 350ish, range on internal fuel at 75% approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It started as an mind exercise based on my headroom requirements not being available in any homebuilt design plus A-10 being a rather neat aircraft. I'm not going to build it because I will probably never get my medical back, but I make sub assemblies for the fun of it. I have made two main instrument panels for it, one IFR the other VFR. It's occupational therapy ![]() Sounds cool! Re think it as a two place, and find someone else that has the same dream, or you can fly with another pilot. -- Jim in NC |
![]() "Dan" wrote in message ... Rich S. wrote: "Dan" wrote in message ... 1/2 scale A-10, aluminum, (snip) Whew! Had to read that three times. I thought you said, "1/2 A scale . . ." I envisioned a Cox .049. ![]() Rich S. You know it's just a matter of time before someone builds a man capable airplane powered by a huge number of TeeDee .049 engines. Dan, U.S. Air Force, retired Hmm, just duct tape a bunch of them on a sailplane - mine only requires 20 pounds of thrust for level flight. Bill Daniels |
Morgans wrote:
"Dan" wrote 1/2 scale A-10, aluminum, Vne 350ish, range on internal fuel at 75% approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It started as an mind exercise based on my headroom requirements not being available in any homebuilt design plus A-10 being a rather neat aircraft. I'm not going to build it because I will probably never get my medical back, but I make sub assemblies for the fun of it. I have made two main instrument panels for it, one IFR the other VFR. It's occupational therapy ![]() Sounds cool! Re think it as a two place, and find someone else that has the same dream, or you can fly with another pilot. When I saw the two seater version of the real thing I thought about it. Problem is I want a sliding canopy so that's out. Besides, despite the back seat being closer to the CG the math gets complicated. In my plan there's a hell hole on the bottom between the engines. In order to make CG with the second seat I'd have to move the batteries aft to where the access panel is. Dan, U.S. Air Force, retired |
Bill Daniels wrote:
"Dan" wrote in message ... Rich S. wrote: "Dan" wrote in message ... 1/2 scale A-10, aluminum, (snip) Whew! Had to read that three times. I thought you said, "1/2 A scale . . ." I envisioned a Cox .049. ![]() Rich S. You know it's just a matter of time before someone builds a man capable airplane powered by a huge number of TeeDee .049 engines. Dan, U.S. Air Force, retired Hmm, just duct tape a bunch of them on a sailplane - mine only requires 20 pounds of thrust for level flight. Bill Daniels Now THAT I'd like to see. You could do like the guy with the Cri Cri did and use a pair of model jet engines. Dan, U.S. Air Force, retired |
Dan wrote:
cavelamb himself wrote: Dan wrote: Morgans wrote: "Dan" wrote Mine reads to + 30º. I am finishing out an instrument panel for an airplane I will never be able to afford to complete. My own design. Hmmm, interesting. Now that our curiosity is aroused, care to tell us more? Planform, construction materials/methods, approximate performance parameters, locomotion, how many places? So many questions! ;-)) 1/2 scale A-10, aluminum, Vne 350ish, range on internal fuel at 75% approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It started as an mind exercise based on my headroom requirements not being available in any homebuilt design plus A-10 being a rather neat aircraft. I'm not going to build it because I will probably never get my medical back, but I make sub assemblies for the fun of it. I have made two main instrument panels for it, one IFR the other VFR. It's occupational therapy ![]() Dan, U.S. Air Force, retired I thought about building a cockpit simulator - for similar reasons. Decided to go sailing instead. But I certainly understand... Richard Sailing has its advantages not the least of which is no FAA. I haven't been sailing in decades, maybe I should build a boat instead. Dan, U.S. Air Force, retired Dan, U.S. Air Force, retired if you want to build, build. If you want to fly, buy. Works the same with boats. |
Dan wrote: cavelamb himself wrote: Dan wrote: Morgans wrote: "Dan" wrote Mine reads to + 30º. I am finishing out an instrument panel for an airplane I will never be able to afford to complete. My own design. Hmmm, interesting. Now that our curiosity is aroused, care to tell us more? Planform, construction materials/methods, approximate performance parameters, locomotion, how many places? So many questions! ;-)) 1/2 scale A-10, aluminum, Vne 350ish, range on internal fuel at 75% approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It started as an mind exercise based on my headroom requirements not being available in any homebuilt design plus A-10 being a rather neat aircraft. I'm not going to build it because I will probably never get my medical back, but I make sub assemblies for the fun of it. I have made two main instrument panels for it, one IFR the other VFR. It's occupational therapy ![]() Dan, U.S. Air Force, retired I thought about building a cockpit simulator - for similar reasons. Decided to go sailing instead. But I certainly understand... Richard Sailing has its advantages not the least of which is no FAA. I haven't been sailing in decades, maybe I should build a boat instead. Dan, U.S. Air Force, retired Dan, U.S. Air Force, retired if you want to build, build. If you want to fly, buy. Works the same with boats. See? There you go being practical again. I have plans for 12 - 16 foot sailboats. Maybe you can buy me a 42 footer for my birthday, it's 1 November ![]() Dan, U.S. Air Force, retired |
Dan wrote:
cavelamb himself wrote: Dan wrote: cavelamb himself wrote: Dan wrote: Morgans wrote: "Dan" wrote Mine reads to + 30º. I am finishing out an instrument panel for an airplane I will never be able to afford to complete. My own design. Hmmm, interesting. Now that our curiosity is aroused, care to tell us more? Planform, construction materials/methods, approximate performance parameters, locomotion, how many places? So many questions! ;-)) 1/2 scale A-10, aluminum, Vne 350ish, range on internal fuel at 75% approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It started as an mind exercise based on my headroom requirements not being available in any homebuilt design plus A-10 being a rather neat aircraft. I'm not going to build it because I will probably never get my medical back, but I make sub assemblies for the fun of it. I have made two main instrument panels for it, one IFR the other VFR. It's occupational therapy ![]() Dan, U.S. Air Force, retired I thought about building a cockpit simulator - for similar reasons. Decided to go sailing instead. But I certainly understand... Richard Sailing has its advantages not the least of which is no FAA. I haven't been sailing in decades, maybe I should build a boat instead. Dan, U.S. Air Force, retired Dan, U.S. Air Force, retired if you want to build, build. If you want to fly, buy. Works the same with boats. See? There you go being practical again. I have plans for 12 - 16 foot sailboats. Maybe you can buy me a 42 footer for my birthday, it's 1 November ![]() Dan, U.S. Air Force, retired Get a smaller boat to start with. They are a lot more fun and a whole lot less hassle. (and a whole lot less expensive!) I might offer to sell my Catalina 18 for your birthday. But ONLY because I have a lead on a Catalina 30. ![]() http://www.home.earthlink.net/~cavelamb/index.htm Richard, U.S. Navy, retired |
![]() "Dan" wrote in message ... Bill Daniels wrote: "Dan" wrote in message ... Rich S. wrote: "Dan" wrote in message ... 1/2 scale A-10, aluminum, (snip) Whew! Had to read that three times. I thought you said, "1/2 A scale . . ." I envisioned a Cox .049. ![]() Rich S. You know it's just a matter of time before someone builds a man capable airplane powered by a huge number of TeeDee .049 engines. Dan, U.S. Air Force, retired Hmm, just duct tape a bunch of them on a sailplane - mine only requires 20 pounds of thrust for level flight. Bill Daniels Now THAT I'd like to see. You could do like the guy with the Cri Cri did and use a pair of model jet engines. Dan, U.S. Air Force, retired It's been done. Bob Carlton has an airshow act with a jet sailplane. Jet sailplanes may well have a real future. Although the specific fuel efficiency of model airplane dog whistles is terrible, (but improving) mating them with an extremely efficient airframe seems to work really well. Some 'back of the envelope' calcualtions show that a single RC model microjet in the 50 Lb thrust range would push my glider along at well over 100 knots. The 75 gallon wing tanks normally used for water ballast would provide a very nice range. If the 'dog whistle' quits, just retract it an you still have a 50:1 glide ratio. Bill Daniels Bill Daniels |
Bill Daniels wrote:
"Dan" wrote in message ... Bill Daniels wrote: "Dan" wrote in message ... Rich S. wrote: "Dan" wrote in message ... 1/2 scale A-10, aluminum, (snip) Whew! Had to read that three times. I thought you said, "1/2 A scale . . ." I envisioned a Cox .049. ![]() Rich S. You know it's just a matter of time before someone builds a man capable airplane powered by a huge number of TeeDee .049 engines. Dan, U.S. Air Force, retired Hmm, just duct tape a bunch of them on a sailplane - mine only requires 20 pounds of thrust for level flight. Bill Daniels Now THAT I'd like to see. You could do like the guy with the Cri Cri did and use a pair of model jet engines. Dan, U.S. Air Force, retired It's been done. Bob Carlton has an airshow act with a jet sailplane. Jet sailplanes may well have a real future. Although the specific fuel efficiency of model airplane dog whistles is terrible, (but improving) mating them with an extremely efficient airframe seems to work really well. Some 'back of the envelope' calcualtions show that a single RC model microjet in the 50 Lb thrust range would push my glider along at well over 100 knots. The 75 gallon wing tanks normally used for water ballast would provide a very nice range. If the 'dog whistle' quits, just retract it an you still have a 50:1 glide ratio. Bill Daniels Bill Daniels I hadn't realized it had been done. I wonder how altitude affects performance of the engine. Dan, U.S. Air Force, retired |
Century Ic Pinout | Grandmaster | Owning | 1 | November 28th 06 03:18 PM |
KR-21 pinout | Tri-Pacer | Piloting | 0 | September 9th 06 02:37 AM |
Pinout for StormScope WX-900 | epotenziani | Products | 0 | August 22nd 05 08:32 PM |
KAA 455 pinout | Mike Rapoport | Owning | 0 | February 28th 05 12:57 AM |
RT-540A pinout help | Billc851 | Home Built | 1 | December 12th 04 04:27 PM |
