Tow Vehicle Woes
Old October 18th 07, 05:28 AM posted to rec.aviation.soaring
tommytoyz
Default Tow Vehicle Woes
When I had my Hitch installed on my Honda Accord, it was welded on,
not bolted. Never had a problem.
Old October 18th 07, 04:23 PM posted to rec.aviation.soaring
Peter[_4_]
Ditto, I am on my second Odyssey (03 & 06). Several thousand miles of
straight out x/c. Good and convenient tow vehicle. PeterK
"Udo" wrote in message
My Honda Odyssey has a sub frame which holds a 3500 lb hitch.
I understand may car is based on an Accord chassis.
I have 120000 miles on it 75% of it with my trailer.
On its own, at normal highway speed, I get 25-27m/g
If you like your accord you will love the Odyssey, new or used
Udo
Old October 22nd 07, 03:44 AM posted to rec.aviation.soaring
chris
Ray,
Have you looked into Subaru Foresters and Outbacks? They tow good,
and if you can resist the turbo options the gas mileage is fine. They
are all wheel drive so if you landout in a field you'll have better
traction than the front wheel drive cars.
I've got 73000 trouble free miles on my Forester.
Chris
Old October 22nd 07, 01:22 PM posted to rec.aviation.soaring
rlovinggood
Chris,
Yes, I am considering the Forester. I know you and RQ tow with turbo
versions, but I would look ONLY at the normally aspirated models
because I don't want to pay for the premium octane fuel required for
the turbo models.
The tough adjustment will be that I've been "corrupted" by the
additional power of a V6 and I don't know what it will be like to tow
with a four cylinder, again. Also, both the Forester and the Outback
are smaller than the Accord which will take some time to adjust to.
The 07 Forester is rated to tow 2,400 lbs, but I don't know what the
max tongue weight is. Probably 10% of the max trailer weight.
So, I guess I'm looking for a good, used, Forester.
One good thing: Time is on my side. My flying is done for the winter
and I don't have to worry about towing it anywhere for a while.
Ray
On Oct 21, 10:44 pm, chris wrote:
Ray,
Chris
Old October 22nd 07, 09:49 PM posted to rec.aviation.soaring
On Oct 22, 5:22 am, rlovinggood wrote:
Chris,
the turbo models.
Ray
Ray,
Chris- Hide quoted text -
- Show quoted text -
I think my 05 Outback is rated for 200 lbs tongue weight and 2,700
trailer weight. It has the factory hitch. It's in the shop right now
for an unrelated matter so I can't check.
It's the regular 2.5i version, non-turbo 168 hp. Drives 70-80 no
problem through New Mexico with a Cobra trailer and a 570 lb glider
and other gear in the trailer. This is mostly on I-40 and some
highways. There are places it would probably go a little slower here
though.
Bob
Old October 22nd 07, 10:24 PM posted to rec.aviation.soaring
James D'Andrea
the turbo models.
There is a fellow pilot at Truckee (elev. 5,900') who tows his Genesis
2 in a Cobra fiberglass top trailer using a normally aspirated Subaru
Forrester. I'm not sure of the vehicle's year but its the generation
before the current one, maybe a 2003. He has towed it from sea level
and over the Sierra Nevadas without complaints or incident. So I
wuold imagine that a Forrester will be more than enough tow vehicle at
your elevation. He also likes the car's AWD capability as he lives in
the Sierras where it snows heavily during the winters. As an aside,
not all AWD systems are equal. Most systems favor FWD and do not
engage the rear wheels unitl slippage is detected in the front
wheels. Subarus have several versions of AWD depending upon the model
but they have continuous AWD in common, always sending power to all
four wheels. To see how Subaru AWD compares to the competion see
http://www.youtube.com/watch?v=XyLgYskj-oc and
http://www.youtube.com/watch?v=Q7dVF...elated&search=
Tow Vehicle Woes rlovinggood Soaring 25 October 18th 07 10:40 PM
Saturn V Vehicle for the Apollo 4 Mission in the Vehicle Assembly Building 6754387.jpg [email protected] Aviation Photos 0 April 12th 07 01:38 AM
license woes gen Piloting 30 November 10th 06 08:03 PM
Volkslogger woes Dan Rihn Soaring 10 March 25th 04 03:10 PM
