Others have suggested
increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. A suggestion: I bought a copy of the condor flight simulator a while ago, in part to explore on the ground how things like this work out. It does let you practice and explore limits of glider abilities. You can find out, for example, exactly how much altitude a 360 will take in various configurations, or how much altitude you really need for a 180 back to the airport. John Cochrane |
On Oct 22, 11:30 am, BB wrote:
Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. A suggestion: I bought a copy of the condor flight simulator a while ago, in part to explore on the ground how things like this work out. It does let you practice and explore limits of glider abilities. You can find out, for example, exactly how much altitude a 360 will take in various configurations, or how much altitude you really need for a 180 back to the airport. John Cochrane Doing these tests in the actual glider (at high altitude) with a data logger will produce reliable numbers. The simulator might or might not reproduce the performance accurately enough. Todd Smith 3S |
BB wrote:
Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. I find it a very useful technique if I am high enough on final to use it. Generally, I use it shortly after turning final as I realize I am too high, even with full spoiler. That's when I have 500' agl or so, which is plenty. Going from 50 knots to 70 knots (watch the flap setting speed) doubles the rate of energy loss. When I slow down to 50 knots again (still at full spoiler), my new "aim point" is much closer, and I can reduce the spoilers to (ideally) about half. If I'm "low", say less than 200', when I decide I'm too high, slipping is my choice. I've never used S turns: if I'm high enough to make turns on final, it's easier and safer to dive off the speed. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Oct 22, 5:58 pm, Eric Greenwell wrote:
I find it a very useful technique if I am high enough on final to use it. Generally, I use it shortly after turning final as I realize I am too high, even with full spoiler. That's when I have 500' agl or so, which is plenty. Going from 50 knots to 70 knots (watch the flap setting speed) doubles the rate of energy loss. When I slow down to 50 knots again (still at full spoiler), my new "aim point" is much closer, and I can reduce the spoilers to (ideally) about half. All this is way outside my experience, and I'm not going to attempt it myself (though I might nobble an instructor experienced at it). However I still have a question: do you dive and then return to normal approach speed before rounding out, or round out at the much faster speed? If the latter, does not the extra float in ground effect negate the losses from extra drag in the dive, especially with a slippery glass ship versus a draggy wood and fabric glider (such as one a pilot might train in)? Dan |
BB wrote:
Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. I had this taught to me as part of my UK Basic Instructor renewal course/checks. It works well in a glider with good airbrakes, but not in something like my Open Cirrus (unless, perhaps, it's a long, long approach so that there's time to drop below glide path with full brake and normal approach speed, then bleed off the speed and come back into the approach funnel at the proper speed). It's one for the experienced (and properly taught) because you need to know what's going to happen after you round out. In, say, a Puchacz, the brakes are so good that you get only a comparatively small increase in float. In my Cirrus, 10kt extra with full airbarke will far more than double the float at a height where there is nothing you can do about it except hang on. Libelles are known to be similar, and from a previous poster the Duo Discus as well. Fortunately, those who fly gliders with "weak" airbrakes soon learn about approach speed control .... |
Tim Taylor wrote:
[....] I have used the technique of slowing down to minimize forward speed, increase sink and decrease glide angle. Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. Last years article in soaring I believe confirms my feeling that this is a technique that should not be held up as one of the primary techniques that should be used. I am working on developing models to asses each in terms of effectiveness, time required, safety and options left to the pilot. Increasing speed has its uses, and it has the distinct advantage of being able to get out of rather more easily and safely than slowing down, when you find you have over-done it. Of course there is the concern that those who find themselves needing a lot of it may not be the persons who'll know promptly when they've had enough, nor how best to handle having too much--but there are ways to avoid being one of them. The S-turns can be helpful when one has both the horizontal and vertical space for them, if we arrange to be finished with them before we are low, and ALWAYS watch our drift, as it changes with altitude and airspeed changes--both IAS and GS--throughout the final approach. I often see people failing to correct for drift as soon as they should, which only leads to further complications. I've found it useful to practice with increasing amounts of variation from the basic final approach airspeed, both plus and minus, in order to get to know what works with my glider in the relatively controlled environment of my home field. This is at least a start in preparing for the inevitable off-field or strange-field approach and landing, not to mention the unheralded/unheeded arrival of geese, Cessnas, Boeings, or skydivers in the pattern. I can only advise any rated pilot to try each of those techniques under benign conditions, working in small increments away from the nominal speeds and configurations, changing one variable on each approach. Pretty much what you learned to do in high-school science labs. It may not be rocket science, but please do have a plan on every approach--just as you do on every departure--to include touchdown and stop points. And when you are on the ground make sure you know why the plan worked, or why it did not--before you take the next step. Thanks for the opportunity to harangue the assemblage. I'll try to remember to impose some limits on this sort of thing next time, possibly. Jack |
High on Final, Summary
Thanks to all that have given input so far. My original intent was to do some modeling before starting the discussion, but this is RAS and it has a life of it's own. So here is the issue. You are high on final and full spoilers are to enough; what do you do? List of options so far: 1. Slip 2. "S" turns 3. Dive until intercepting normal angle for spoilers 4. Dive until near the ground, then decelerate 5. Slow down until intercepting normal angle for spoilers 6. 360 degree turn Unfortunately I still don't have good data for what happens to the polar as speed increases with the spoilers open. Condor was a good suggestion, and I am working to see if I can get meaningful data from it. John Cochrane brought the discussion back to the real point which is what would you use in the real world? It is interesting but not that useful to discuss how you do this at your home airport with 2500 to 9000 feet of runway and know precisely the field elevation. When your aircraft and your own safety are on the line in a real off-field, what are you going to do? This is where I find teaching some of these other techniques interesting, but possibly dangerous. The rule of primacy for learning or as the Doobie Brothers album from the 70's title "What were once vices are now habits" suggests we will do in an emergency what we have practiced. Is someone really going to dive a glider to the ground and pull out to land in a short off field landing? Is there really a need to be on the ground 10 seconds faster than using some of the other techniques? Maybe only if a severe thunderstorm is approaching and you must be on the ground now. I think in general the high parasitic drag technique being taught by some schools is a hyped method that may give some less experienced pilots the idea this is a good technique to use for off-field landings. I think it is time to get back to basics and teach sound techniques that provide the best tools for pilots to use day in and day out. The dive until intercepting normal angle for spoilers has some merit, but I still think should be used with caution. Why, because we train to look at landings from a specific angle for a narrow range of landing speeds. To dive at high speed leaves the aircraft with a much greater kinetic energy that must still be lost someplace. Depending on the ship type some may take much longer to dissipate this excess and make it more difficult to precisely hit a touch down point. Often the greater sink rate is held up as the reason for using this technique. It is true that sink rate goes up with speed, but the actual decent angle does not go up nearly as much. For my Ventus B at 45 knots descent rate is 122 ft/min while at 135 knots it is 894 ft/ min, but actual loss per nautical mile is 163 ft/ktm verses 397 ft/ ktm. The other thing we don't mention is the average pilot going to handle the decision making process better at higher speeds and less time? At stable speeds it takes about 11 seconds to lose 300 feet at 135 knots with the spoilers out verses 22 seconds at 45 knots. Do we need that extra time to make proper judgment and fine adjustments to hit a target for a tight off-field landing? Ok, lets try a hypothetical (well maybe not, been there done that ;-) off-field landing. The situation: You are 70 miles from home over unfamiliar territory (read not sure of exact elevation of the terrain below, your altimeter is useless now). You have gone for a Cu over a dry lake bed and it doesn't work. You have selected a landing site in the lake bed that is about 350 feet long and 100 feet wide that looks safe to land. There are tree stumps and other object in other parts of the lakebed. There are no obstructions on the ends of the site so you can do a normal approach. The winds are 15 to 20mph out of the south so you are landing from the north to south. As you drop lower you make a rectangular pattern over the site checking for any missed obstacles. The downwind is fast with the tailwind, as you turn base you estimate you are 400 feet. Your adrenaline is pumping as you prepare for a fairly technical landing. You want to keep it close so that you don't end up short back into the wind and you turn base a little too soon. You are on short final about 350 feet, but about 100 feet over full spoilers decent. What do you do? Slip? "S" turns? Dive until intercepting normal angle for spoilers? Dive until near the ground, and then decelerate? Slow down until intercepting normal angle for spoilers? 360 degree turn? In the real world nearly 15 years ago this was in a 1970 "A" model Standard Cirrus. If you think the Duo will float try the Standard Cirrus. What should we be teaching students? You are somewhere between 11 and 30 seconds from being on the ground and that 100 extra feet will take you past the whole safe landing area and into the tree stumps. Dive until intercepting normal angle for spoilers? Maybe, but can you dive, lose the altitude, decelerate and get it on the ground for a tail wheel first, full stall landing? I would give this a 6 out of 10. This also shortens the time available to make adjustments and requires rapid and precise decisions. Dive until near the ground, and then decelerate? My guess is your chances are slim that you can pull this off and get the ship stopped. Especially, if you were flying my Std. Cirrus. My rating is a 1 out of 10. 360 degree turn? I never like to turn my back on a field. Low and with the winds a good result is not likely. My rating is a 0 out of 10. Slow down until intercepting normal angle for spoilers? This technique is useful for very high approaches, but must be broken off before 300 feet agl because you must have height to accelerate and be able to recover from any inadvertent stalls. From about 1000 feet to 500 feet this technique has the advantage of giving a higher decent rate and giving the pilot more time to evaluate the situation, but the pilot must be ready to respond to any sign of stall. My rating is a 0 out of 10 here. "S" turns? This might be useful. You are low, but may have time to extend the your descent. Any turn at this point will require nearly at least 180 degrees of turning (45 away, 90 back and 45 back to final.) and up to 360 degrees with three changes in direction and roll. The advantage is your speed stays constant and you can see the touchdown point the whole time. A disadvantages is you are no longer lined up on the target so your perception changes as you roll and move to the side. My rating is a 7 out of 10 here. Slip? The forward slip can be very effective at bringing "most" ships down. Check you flight manual of your aircraft and practice at altitude. The old joke about you could always tell who the Std. Cirrus and Libelle pilots were because they were slipping on final is true. But we got very good at it. It would nearly double the sink rate and when kicked out you were nearly at the correct speed. The Std. Cirrus if flown even 5 knots too fast would float a long way before settling. The nice thing about a slip is your speed and angles all stay the same without speeding up the process. You can use your trained judgment to say the angle looks about right here and kick out of the slip and proceed with a normal landing. My rating is a 10 out of 10 here. Summary Each situation is different, but I think we should focus on teaching techniques that are robust and give that average pilot the best opportunity to have a good outcome in an off-field landing. I know of very few off-field landings that start at 1000 feet at the end of down wind. If I have found that much lift on downwind I have cycled the gear and am climbing out, not landing. Any technique that requires bleeding speed in ground effect should not be taught as anything other than a curiosity and never considered for off-filed landings. |
On Oct 24, 5:36 am, Tim Taylor wrote:
High on Final, Summary Thanks to all that have given input so far. My original intent was to do some modeling before starting the discussion, but this is RAS and it has a life of it's own. So here is the issue. You are high on final and full spoilers are to enough; what do you do? List of options so far: 1. Slip 2. "S" turns 3. Dive until intercepting normal angle for spoilers 4. Dive until near the ground, then decelerate 5. Slow down until intercepting normal angle for spoilers 6. 360 degree turn Unfortunately I still don't have good data for what happens to the polar as speed increases with the spoilers open. Condor was a good suggestion, and I am working to see if I can get meaningful data from it. John Cochrane brought the discussion back to the real point which is what would you use in the real world? It is interesting but not that useful to discuss how you do this at your home airport with 2500 to 9000 feet of runway and know precisely the field elevation. When your aircraft and your own safety are on the line in a real off-field, what are you going to do? This is where I find teaching some of these other techniques interesting, but possibly dangerous. The rule of primacy for learning or as the Doobie Brothers album from the 70's title "What were once vices are now habits" suggests we will do in an emergency what we have practiced. Is someone really going to dive a glider to the ground and pull out to land in a short off field landing? Is there really a need to be on the ground 10 seconds faster than using some of the other techniques? Maybe only if a severe thunderstorm is approaching and you must be on the ground now. I think in general the high parasitic drag technique being taught by some schools is a hyped method that may give some less experienced pilots the idea this is a good technique to use for off-field landings. I think it is time to get back to basics and teach sound techniques that provide the best tools for pilots to use day in and day out. The dive until intercepting normal angle for spoilers has some merit, but I still think should be used with caution. Why, because we train to look at landings from a specific angle for a narrow range of landing speeds. To dive at high speed leaves the aircraft with a much greater kinetic energy that must still be lost someplace. Depending on the ship type some may take much longer to dissipate this excess and make it more difficult to precisely hit a touch down point. Often the greater sink rate is held up as the reason for using this technique. It is true that sink rate goes up with speed, but the actual decent angle does not go up nearly as much. For my Ventus B at 45 knots descent rate is 122 ft/min while at 135 knots it is 894 ft/ min, but actual loss per nautical mile is 163 ft/ktm verses 397 ft/ ktm. The other thing we don't mention is the average pilot going to handle the decision making process better at higher speeds and less time? At stable speeds it takes about 11 seconds to lose 300 feet at 135 knots with the spoilers out verses 22 seconds at 45 knots. Do we need that extra time to make proper judgment and fine adjustments to hit a target for a tight off-field landing? Ok, lets try a hypothetical (well maybe not, been there done that ;-) off-field landing. The situation: You are 70 miles from home over unfamiliar territory (read not sure of exact elevation of the terrain below, your altimeter is useless now). You have gone for a Cu over a dry lake bed and it doesn't work. You have selected a landing site in the lake bed that is about 350 feet long and 100 feet wide that looks safe to land. There are tree stumps and other object in other parts of the lakebed. There are no obstructions on the ends of the site so you can do a normal approach. The winds are 15 to 20mph out of the south so you are landing from the north to south. As you drop lower you make a rectangular pattern over the site checking for any missed obstacles. The downwind is fast with the tailwind, as you turn base you estimate you are 400 feet. Your adrenaline is pumping as you prepare for a fairly technical landing. You want to keep it close so that you don't end up short back into the wind and you turn base a little too soon. You are on short final about 350 feet, but about 100 feet over full spoilers decent. What do you do? Slip? "S" turns? Dive until intercepting normal angle for spoilers? Dive until near the ground, and then decelerate? Slow down until intercepting normal angle for spoilers? 360 degree turn? In the real world nearly 15 years ago this was in a 1970 "A" model Standard Cirrus. If you think the Duo will float try the Standard Cirrus. What should we be teaching students? You are somewhere between 11 and 30 seconds from being on the ground and that 100 extra feet will take you past the whole safe landing area and into the tree stumps. Dive until intercepting normal angle for spoilers? Maybe, but can you dive, lose the altitude, decelerate and get it on the ground for a tail wheel first, full stall landing? I would give this a 6 out of 10. This also shortens the time available to make adjustments and requires rapid and precise decisions. Dive until near the ground, and then decelerate? My guess is your chances are slim that you can pull this off and get the ship stopped. Especially, if you were flying my Std. Cirrus. My rating is a 1 out of 10. 360 degree turn? I never like to turn my back on a field. Low and with the winds a good result is not likely. My rating is a 0 out of 10. Slow down until intercepting normal angle for spoilers? This technique is useful for very high approaches, but must be broken off before 300 feet agl because you must have height to accelerate and be able to recover from any inadvertent stalls. From about 1000 feet to 500 feet this technique has the advantage of giving a higher decent rate and giving the pilot more time to evaluate the situation, but the pilot must be ready to respond to any sign of stall. My rating is a 0 out of 10 here. "S" turns? This might be useful. You are low, but may have time to extend the your descent. Any turn at this point will require nearly at least 180 degrees of turning (45 away, 90 back and 45 back to final.) and up to 360 degrees with three changes in direction and roll. The advantage is your speed stays constant and you can see the touchdown point the whole time. A disadvantages is you are no longer lined up on the target so your perception changes as you roll and move to the side. My rating is a 7 out of 10 here. Slip? The forward slip can be very effective at bringing "most" ships down. Check you flight manual of your aircraft and practice at altitude. The old joke about you could always tell who the Std. Cirrus and Libelle pilots were because they were slipping on final is true. But we got very good at it. It would nearly double the sink rate and when kicked out you were nearly at the correct speed. The Std. Cirrus if flown even 5 knots too fast would float a long way before settling. The nice thing about a slip is your speed and angles all stay the same without speeding up the process. You can use your trained judgment to say the angle looks about right here and kick out of the slip and proceed with a normal landing. My rating is a 10 out of 10 here. Summary Each situation is different, but I think we should focus on teaching techniques that are robust and give that average pilot the best opportunity to have a good outcome in an off-field landing. I know of very few off-field landings that start at 1000 feet at the end of down wind. If I have found that much lift on downwind I have cycled the gear and am climbing out, not landing. Any technique that requires bleeding speed in ground effect should not be taught as anything other than a curiosity and never considered for off-filed landings. Great summary Tim ! To further your point on training: One thing we need to do in training is demonstrate the effect of flying the final too fast. Back-to-back pattern flights with different final speeds and the same aim point really help pilots internalize this. Especially for transition pilots (Cirrus, 1-35 come to mind), practicing this on an appropriately long runway brings religion to pattern energy management like no amount of briefing... Be careful out there, Best Regards, Dave "YO" |
On Oct 24, 7:09 am, wrote:
Great summary Tim ! I agree. A quick response to the above choices would be based on how much too high I was. And Tim's list is pretty much in the correct order: 1. Slip 2. "S" turns The first one likely being an overshoot of the turn to final, then a 120-180 back toward the runway, repeat if necessary, then line up on the runway. 3. Dive until intercepting normal angle for spoilers 4. Dive until near the ground, then decelerate Not sure if I like this one... I think #3 is the proper way to do it. Though, if one is REALLY high, then the proper angle for 'normal' final would be pretty close to the ground. I would be in this situation if there are strong winds and chance of downbursts (been there, done that). Turn final way high expecting the 40+ headwind to be there (perhaps downburst since the storm is nearby), but instead the wind quits! In my ASW-20B, I just did a full flap, full spoiler slip with the nose way below the horizon, so it really was a diving slip - remember I was WAAAY high. Ended up stopping at my intended spot even though there was a slight 2-3 knot tailwind. 5. Slow down until intercepting normal angle for spoilers Perhaps 6. 360 degree turn Actually, I doubt one would be on final when this decision is made, so perhaps a 270 degree turn from base to final. But only if the weather is considered to be benign. I watched an ASW-22BL do this at a fairly low altitude while going into a fairly short field on a relatively calm day and it made sense. Due to the ship's low sink rate, the pilot was able to drop perhaps 100' and also end up slightly farther away from the touchdown spot. -Tom |
MA-8 with parachute extended S63-00693.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:52 PM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Extended GPX Schema | Paul Tomblin | Products | 0 | September 25th 04 02:44 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
