Many pilots, if they have heard about ADS-B, think that it means free
weather. IT DOES NOT This proposal will mandate potentially costly avionics that in my analysis provide little or nothing to the GA pilot. You will still have to keep your Mode C transponder. You won't get free weather. You won't get traffic alerts in your cockpit. You only get to pay thousands (TBD but possibly over $7000 per plane) for something that only helps the airlines. The official link to read the NPRM and submit comments is he http://tinyurl.com/2raefd My analysis (which is still in work and may not be done until November or later) is he http://tinyurl.com/2wem8j My suggestion is that you read what I have written then read the NPRM. If you agree with my analysis, please reply to the FAA and AOPA. You may use any or all of my reply but I strongly suggest changing it to reflect your views (possibly shorter). Ron Lee |
![]() "Ron Lee" wrote in message ... Many pilots, if they have heard about ADS-B, think that it means free weather. IT DOES NOT This proposal will mandate potentially costly avionics that in my analysis provide little or nothing to the GA pilot. You will still have to keep your Mode C transponder. You won't get free weather. You won't get traffic alerts in your cockpit. You only get to pay thousands (TBD but possibly over $7000 per plane) for something that only helps the airlines. The official link to read the NPRM and submit comments is he http://tinyurl.com/2raefd My analysis (which is still in work and may not be done until November or later) is he http://tinyurl.com/2wem8j My suggestion is that you read what I have written then read the NPRM. If you agree with my analysis, please reply to the FAA and AOPA. You may use any or all of my reply but I strongly suggest changing it to reflect your views (possibly shorter). Ron Lee Shall we still write to the FAA if we don't agree with your analysis? |
"S Green" wrote:
My suggestion is that you read what I have written then read the NPRM. If you agree with my analysis, please reply to the FAA and AOPA. You may use any or all of my reply but I strongly suggest changing it to reflect your views (possibly shorter). Ron Lee Shall we still write to the FAA if we don't agree with your analysis? You are free to disagree with anything I wrote. I would be surprised if you did not concur with my views if you read everything provided. Ron Lee |
Ron Lee wrote:
"S Green" wrote: My suggestion is that you read what I have written then read the NPRM. If you agree with my analysis, please reply to the FAA and AOPA. You may use any or all of my reply but I strongly suggest changing it to reflect your views (possibly shorter). Shall we still write to the FAA if we don't agree with your analysis? You are free to disagree with anything I wrote. I would be surprised if you did not concur with my views if you read everything provided. Around 1985, I attended an RTCA meeting where this transponder mode was discussed. (S-mode?). What has happened since, other than 20 years ago positional (GPS) information was not available, but barometeric, velocity and heading were, along with acft identification. My recollection was that the degree of acft identification was a sticky point then, and that transponder signal clutter could be intense in termial areas. My attitude then and now was and is that, I would not stand in the way of pormulgating it gradually (is 20+ years gradual enough?). Clearly, the data processing and sensors are now all in place. So, other than the possibly that the FAA can make terribly inefficient actions while wasting huge amounts of taxpayer money in the process if we don't maintain a close rein on the matter, what are the negative aspects of this specific NPRM? Angelo Campanella (Flying IFR since 1965). |
Angelo Campanella wrote:
So, other than the possibly that the FAA can make terribly inefficient actions while wasting huge amounts of taxpayer money in the process if we don't maintain a close rein on the matter, what are the negative aspects of this specific NPRM? Read the NPRM. Read my response. Does the mandate of a multi thousand dollar piece of equipment that provides little or no benefit to you matter? The FAA needs more PRIMARY radars...not reliance on ADS-B or transponders. Ron Lee |
So, other than the possibly that the FAA can make terribly inefficient actions while wasting huge amounts of taxpayer money in the process if we don't maintain a close rein on the matter, what are the negative aspects of this specific NPRM? Read my writeup. One biggie is having to pay lots of money for no benefit (I don't consider the SAR related possible benefit as worth anything to me). Ron Lee |
![]() "Ron Lee" wrote in message ... Angelo Campanella wrote: So, other than the possibly that the FAA can make terribly inefficient actions while wasting huge amounts of taxpayer money in the process if we don't maintain a close rein on the matter, what are the negative aspects of this specific NPRM? Read my writeup. One biggie is having to pay lots of money for no benefit (I don't consider the SAR related possible benefit as worth anything to me). What was the link for your write-up, again, please? One comment off the top of my head, (before I have read more of your info about the issue) is that if the feds want us to all change to a GPS reporting type of traffic surveillance and control, is that they should pay to put the technology in each plane. A box could be contracted (to be designed and built) that would have a GPS in it linked to the reporting transmitter, in a all in one unit. To save cost and complexity, it would not need to have any display of the GPS data available to the pilot. The government is going to be doing a similar type of purchase of technology for the public to make the change from standard definition TV to high definition TV, by allowing all households to get two coupons free of charge to be exchanged for a set top box that changed high definition signals to standard definition signal for the old TV's. -- Jim in NC |
FAA ADS-B Out NPRM needs to be drastically changed | Ron Lee[_2_] | Piloting | 14 | October 9th 07 08:23 PM |
nprm for private aviation | [email protected] | Piloting | 4 | September 11th 07 07:14 PM |
DC ADIZ NPRM | Blueskies | Piloting | 3 | August 17th 05 04:22 PM |
DC ADIZ NPRM | Blueskies | Home Built | 0 | August 15th 05 11:41 PM |
NPRM proposing to update the AC 43.13 2A - | [email protected] | Home Built | 0 | January 3rd 05 03:56 PM |
