Rob Cherney wrote: I did a lot of research on batteries and settled on the Odyssey when a replacement was needed for Long-EZ N271J. I put a PC-925 (27 A-h) in her back in February. So far, so good. I use a sealed lead-acid lawn tractor battery from the local automobile parts store in my Long EZ -- about $25 as I recall. I swap it out every 2 to 3 years. It cranks in 20 degree F temps and I've never had one fail. I prefer this to buying an expensive battery and hoping it will last 4+ years. Too heavy? Not for me. In fact I have two 8 lb lead shot bags straddling the thing. David O -- http://www.AirplaneZone.com |
On Sun, 31 Aug 2003 11:17:54 -0400, David O
wrote: Rob Cherney wrote: I did a lot of research on batteries and settled on the Odyssey when a replacement was needed for Long-EZ N271J. I put a PC-925 (27 A-h) in her back in February. So far, so good. I use a sealed lead-acid lawn tractor battery from the local automobile parts store in my Long EZ -- about $25 as I recall. I swap it out every 2 to 3 years. It cranks in 20 degree F temps and I've never had one fail. I prefer this to buying an expensive battery and hoping it will last 4+ years. Trading lifetime for cost works when you have easy access to the battery to swap it out (like Long-EZs I've seen) but it's a bear when it's hard to access the battery. The gel-cell in my Fly Baby is mounted forward of the instrument panel, flush with the cockpit floor, underneath a big box containing all the avionics and electrical system paraphernalia (circuit breakers, gauges, etc.). Getting to the box requires jackknifing as far as the instrument panel will let me or almost standing on my head hanging over the cockpit sidewalls. The box, as it exists now, cannot be removed without physically dismounting the transponder (hardwired with no connectors). I can, barely, move it far enough to get the battery out from underneath. Needless to say, this is NOT a process I like to do very often. I'll gladly pay $25 or $50 more for a battery I only have to replace every four years instead of every two. Now, if only I could find one... :-) Ron "Standing on my head next weekend" Wanttaja |
Ron Wanttaja wrote:
snip Now, if only I could find one... :-) Agreed on all points, including the last. ![]() David O -- http://www.AirplaneZone.com |
************************************************* ******************************* I've used an Odyssey PC 925 in my RV-4 for 1 1/2 years and it sits on its SIDE, in the same place the worthless Gel-Cel fit,and cranks with seemingly no end. It survived me learning hot-starts last summer just fine. NO MORE Gel-Cels for me !! I put the one from the RV-4 in my antique Farmall runway mower. Most expensive mower battery in the neighborhood! Bob Olds RV-4 , N1191X Charleston,Arkansas ************************************************* ****************************** Alright. I agree. There is nothing like a fine quality piece of equipment that you can rely upon. I had a 35 Amp-hr Gel-cell in my RV-6. It was expensive, it weighed a lot and it crapped out on me when it got cold. I have no idea why Van recommends it. I still have access to that airplane and I flew it this last weekend. I was in Utah this morning at 37 degrees F and worried as hell about it cranking. But, after I put the Lightspeed ignition system in that thing and went to a mult-vis oil for the cold, it cranks fine. An old timer told me how to start that thing about three years ago. His name is Paul Muskat and he's an old examiner who retired many years ago, plus he's an A & P. He passed this on to me and I swear to God it's the answer to the starting problems I had on the RV-6. In fact I'm not so sure I needed to buy and instal that Lightspeed ignition after I changed the way I started--due to Paul. Here's what he said: Prime this thing with about 4 pumps of the prime plunger. Of course wait until it stops wheezing each time so you know you are getting a good shot of fuel. MAKE SURE YOUR MAG SWITCHES ARE OFF. Go around and pull that O-320 through all four cylinders Then get in and crank it. I did that this morning and it hit on the first cylinder. Of course Claus's plasma ignition system is about like starting an electric motor. If you do the ABOVE, then crack the throttle and hit the starter, with the retardation and advancement of timing that the Lightspeed ignition gives you, the prop just starts turning, you drop out the starter and it continues to turn like an electric motor. I've never seen anything like it in a Lycoming. What a NOVEL idea, change the timing as needed just like you do in a car. How innovative. How modern. Christ, sometimes I think we are in the stone age with Lycoming and Continental. They should have done this years ago. It works great guys. Hell, 4 D-Cell batteries would start that RV-6 now. BWB |
An old timer told me how to start that thing about three years ago. His name is Paul Muskat and he's an old examiner who retired many years ago, plus he's an A & P. He passed this on to me and I swear to God it's the answer to the starting problems I had on the RV-6. In fact I'm not so sure I needed to buy and instal that Lightspeed ignition after I changed the way I started--due to Paul. Here's what he said: Lightspeed ignition, NOT required, *IF* you follow the steps that were recommended to you below. Prime this thing with about 4 pumps of the prime plunger. Of course wait until it stops wheezing each time so you know you are getting a good shot of fuel. MAKE SURE YOUR MAG SWITCHES ARE OFF. Yep - absolutely key part of the process. Go around and pull that O-320 through all four cylinders Not necessary, *IF* you can crank with... MAGS OFF. Then get in and crank it. I did that this morning and it hit on the first cylinder. BWB Yep. What was happening... you were *FROSTING* the sparkplugs. Once ICED... Ya either wait for the ice to melt or remove it. If you don't believe it.... pull a plug when the engine absolutely won't start. Check for ICE shorting across the electrodes! It will be there in mass quantities !!!!!! I learned this the hard way, as a 16 year old teenager. I had a car that would not start below 32 degrees. Ditto for a Cessna 175. Above 32, both would always start on the first lick. Below 32 degrees... Both engines required FUEL to be in the cylinders BEFORE turning on the ignition or the hot spark would cause ICE to form across the sparkplug electrodes. In SOME, but not all engines... The hot spark causes the cold moist air WITHOUT FUEL in the cylinder to CONDENSE across the electrodes as ice... if it's 32 or colder. Once shorted in this manner, your screwed until it warms up or you remove the ice. Trust me on this one. g Barnyard BOb -- believe it or not |
On Thu, 04 Sep 2003 03:21:18 -0500, Barnyard BOb --
wrote: An old timer told me how to start that thing about three years ago. His name is Paul Muskat and he's an old examiner who retired many years ago, plus he's an A & P. He passed this on to me and I swear to God it's the answer to the starting problems I had on the RV-6. In fact I'm not so sure I needed to buy and instal that Lightspeed ignition after I changed the way I started--due to Paul. Here's what he said: Lightspeed ignition, NOT required, *IF* you follow the steps that were recommended to you below. I know that now and agree. I jumped the gun on that one. I should have known how to start that engine without spending a grand on that fancy ignition. But I didn't. Yep. What was happening... you were *FROSTING* the sparkplugs. Once ICED... Ya either wait for the ice to melt or remove it. If you don't believe it.... pull a plug when the engine absolutely won't start. Check for ICE shorting across the electrodes! It will be there in mass quantities !!!!!! Interesting. I don't quite see the physics of that. Must have something to do with the adiabatic expansion of air in the cylinder causing the temp to drop way down. I learned this the hard way, as a 16 year old teenager. I had a car that would not start below 32 degrees. Ditto for a Cessna 175. Above 32, both would always start on the first lick. Below 32 degrees... Both engines required FUEL to be in the cylinders BEFORE turning on the ignition or the hot spark would cause ICE to form across the sparkplug electrodes. What's the difference between pulling it through by hand or cranking it? The same thing is happening except that you don't get a spark? In SOME, but not all engines... The hot spark causes the cold moist air WITHOUT FUEL in the cylinder to CONDENSE across the electrodes as ice... if it's 32 or colder. Why? How? Once shorted in this manner, your screwed until it warms up or you remove the ice. Trust me on this one. g Nature is amazing in it's own right. Being a physicist I know that the truth is much stranger than fiction, but I don't see this one for some reason. I'm not saying I don't believe it. I'm just saying I can't see the mechanism. Bill Barnyard BOb -- believe it or not |
| Thread Tools | |
| Display Modes | |
