#11
On Sun, 11 Nov 2007 20:36:36 -0600, SockPuppet
wrote: I have to say I'm pretty surprised to hear that aircraft alternators don't have permanent magnets. Wow. Of all places not to have permanent magnets: an aircraft, where so much is usually done for redundancy. I find it kind of amazing. All the alternators I've ever seen had permanent magnets... Huh? I can't think of an alternator that DOES have permanent magnets, unless you count the "lighting coils" on 2-strokes. I missed the start of this discussion, but the reason NOT to use permanent magnets in an alternator is that the output voltage will vary with the rpm. This means that the alternator has to have permanent magnets strong enough to produce sufficient 12V current even at idle, and regulator has to be able to regulate the full rpm voltage down to 12V while handling the full load current... which, just after the engine starts and the battery's charging, can be a lot. This means a big heavy regulator that needs to dissapate a lot of heat. The field current is a lot less than the alternator's output current, OTOH, so a fairly small, light regulator can handle the job, and no regulation is needed on the alternator's output. And, of course, an aircraft engine DOES have redundancy: Even if the alternator or regulator fails, the magnetos keep the fan turning. -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- What has four legs and an arm? A happy pit bull. |
| Thread Tools | |
| Display Modes | |
| Another Long Cross Country: HPN to PAO in 6 Days (long) | Journeyman | Piloting | 19 | June 16th 06 12:47 AM |
| Charging System Gremlin | [email protected] | Owning | 9 | May 8th 06 09:41 PM |
| "System Failure Is Blamed In U.S. Downing Of British Jet" | Mike | Military Aviation | 20 | May 21st 04 07:39 PM |
| LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT | Ewe n0 who | Naval Aviation | 0 | March 17th 04 08:57 PM |
| LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT | Ewe n0 who | Military Aviation | 0 | March 17th 04 08:57 PM |
