![]() "B2431" wrote in message ... Just as a matter of curiosity why were rotary engines used? Dan, U. S. Air Force, retired see http://www.aviation-history.com/engi...ary-theory.htm Keith |
Date: 11/13/2003 9:49 PM Central Standard Time Message-id: (B2431) wrote: Just as a matter of curiosity why were rotary engines used? Dan, U. S. Air Force, retired Dan, did you mean 'rotary' or perhaps 'radial'?. Also the thought occurs that you might have meant 'rotary' as in a Wankel? -- -Gord. This thread is about rotary engines as in "bolt the prop to the engine case and hold the crankshaft." I would have thought it would act like a huge gyroscope with the ensuing handling problebs.. Dan, U. S. Air Force, retired |
![]() "B2431" wrote in message ... From: "Gord Beaman" ) Date: 11/13/2003 9:49 PM Central Standard Time -Gord. This thread is about rotary engines as in "bolt the prop to the engine case and hold the crankshaft." I would have thought it would act like a huge gyroscope with the ensuing handling problebs.. It did, thats one of the reasons why the Sopwith Camel was such a dangerous aircraft to fly. An expert pilot could use the effect to advantage but it killed a lot of novices. Keith |
![]() I would have thought it would act like a huge gyroscope with the ensuing handling problebs.. The rotary did just that. Of course, the horsepower was comparatively low. The Nieuport 28 was a late-model fighter with 160 hp. Even at that, I recall that pilots preferred to turn in the direction favored by the torque. all the best -- Dan Ford email: (put CUB in subject line) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Le Rhone, Clerget, and Oberursel rotary engines used conventional
poppet valves in the heads for intake and exhaust. Gnome rotaries were a little different: intake was through a poppet valve in the piston crown! There was no actuating mechanism. The suction of the intake stroke pulled the valve open. Later Gnomes had no intake valves. In the "Monosoupape" design, the exhaust valve remained open so long past dead center, it became an intake valve. The cylinder drew some air in through the exhaust port. (The port went directly to the air, so it didn't inhale too much of its own exhaust gas.) After the valve closed, the descending piston created a suction in the cylinder. Near bottom dead center, the piston uncovered intake ports in the cylinder wall. A rich mixture rushed in from the crankcase. Diluted with the air already present, it made a correct mixture. Compression and power strokes occurred in the normal fashion. To prevent blowback into the crankcase at the end of the power stroke, the exhaust valve opened early and released combustion pressure before the cylinder ports uncovered. As far as I know, the crankcase was the "intake manifold" in all rotary engines. Mixture entered the crankcase via the crankshaft. The portion that passed through the rear main bearing was hollow, like a pipe. That passage connected the stationary carburetor to the spinning crankcase. Although rotary engines drew air and fuel through the crankcase, they were not 2-strokes. Crankcase volume remained constant as the engine revolved, so it couldn't pressurize the mixture like the crankcase of a chain saw or motorcycle engine. There was no blower either, so rotaries had to be 4-strokes. -- Paul Hirose To reply by email delete INVALID from address. |
Paul Hirose wrote:
Le Rhone, Clerget, and Oberursel rotary engines used conventional poppet valves in the heads for intake and exhaust. Gnome rotaries were a little different: intake was through a poppet valve in the piston crown! There was no actuating mechanism. The suction of the intake stroke pulled the valve open. Later Gnomes had no intake valves. In the "Monosoupape" design, the exhaust valve remained open so long past dead center, it became an intake valve. The cylinder drew some air in through the exhaust port. (The port went directly to the air, so it didn't inhale too much of its own exhaust gas.) After the valve closed, the descending piston created a suction in the cylinder. Near bottom dead center, the piston uncovered intake ports in the cylinder wall. A rich mixture rushed in from the crankcase. Diluted with the air already present, it made a correct mixture. Compression and power strokes occurred in the normal fashion. To prevent blowback into the crankcase at the end of the power stroke, the exhaust valve opened early and released combustion pressure before the cylinder ports uncovered. As far as I know, the crankcase was the "intake manifold" in all rotary engines. Mixture entered the crankcase via the crankshaft. The portion that passed through the rear main bearing was hollow, like a pipe. That passage connected the stationary carburetor to the spinning crankcase. Although rotary engines drew air and fuel through the crankcase, they were not 2-strokes. Crankcase volume remained constant as the engine revolved, so it couldn't pressurize the mixture like the crankcase of a chain saw or motorcycle engine. There was no blower either, so rotaries had to be 4-strokes. Correct me if I'm wrong, but based on your description above the main reason that WW1 rotaries don't meet the criteria of a "two-stroke" is because they required 720-deg's of crankshaft rotation to complete one power cycle as opposed to one power cycle in only 360 degrees of crankshaft rotation. Another critical difference is how the crankcase volume remained the same in WW1 engines. As you said, the pressure varies in the crankcase of a 2-stroke. When the crankshaft has rotated past bottom dead center the crankcase pressure is below atmospheric. This is necessary so as to produce a vacuum and allow a fresh charge of unburned mixture gasses to flow through the reed valve into the crankcase at the start of the next compression cycle. |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
