#11
![]() "Bob Gardner" wrote in message . .. It's almost a sure thing that the top 500 feet of Stewart's airspace has been released to the overlying approach control by Letter of Agreement, so SWF controllers wouldn't even be interested in you unless you transitioned lower than that. In any event "Am I cleared through Stewart's airspace?" would clear up any uncertainty. From the New York TRACON / Stewart Tower LOA: 4. PROCEDURES: b. IFR Arrival. (1) N90 shall: (f) When the weather is VFR, coordinate with the TOWER all instrument approaches to Runway 6 at Dutchess (POU). f. Surface Area. (1) The TOWER authorizes the TRACON to: (a) Provide radar services within the Surface Area at 3,000 feet MSL. (b) Descend into Class D airspace within the approach course airspace depicted in Attachment A, as coordinated in paragraph 4.b.(1).(f). ATTACHMENT A Dutchess Runway 6 Approach Course Airspace Airspace based on Final Approach Trapezoid as defined in FAA Order 8260.3B - "United States Standard for Terminal Instrument Procedures (TERPS)" Chapter 5, Paragraph 513. |
Tman wrote:
Appreciate this groups insight ![]() When getting VFR advisories into an uncontrolled field, when and how ought one transition to the CTAF. A lot of it is going to depend on which uncontrolled airport you are going into. Take for example KELD. Center only has radar coverage of the area down to ~2000 ft. Pattern alt is ~1000 feet. So flight following is going to have very little information on what's in the pattern. A good rule of thumb would be to be on the freq where you are going to get the most and best information. And not only be prepared to make that decision yourself but PLAN to make that decision yourself because flight following might well forget you. |
In any event "Am I cleared through Stewart's airspace?" would clear up any uncertainty. "Steven P. McNicoll" wrote in message From the New York TRACON / Stewart Tower LOA: While Steven's post is technically correct and with supporting data no less, it takes a tangent to the OP's original questions. The LOA mentioned references mostly TRACON problem of descending northeast bound traffic landing KPOU clipping the KSWF class D. The OP's answer was in Bob's simple statement above. And having flown the similar route westbound many times, the ATC response will be "unable the handoff to Stewart Tower,..." usually followed by "what are your intentions?" if you are above 3000, or "VFR services terminated, squawk 1200, try Stewart Tower on 121.00" if you are below 3000. I've found SWF to accommodate a westbound transition at 2500 (landing MGJ) with little problem, but even the more typical crossing SWF at above 3000 is no problem landing MGJ. You'll just need to plan your descent on the west side of MGJ after over flying the field. Depending on my aircraft's requirements, if landing 03, I begin a 500-700 fpm descent when crossing MGJ westbound, descend for about two minutes and begin a standard rate descending right hand turn, ending in a 45 inbound at pattern. Pretty much what the OP did, except I never feel as rushed and would not descend at 1200 fpm just to keep it tight. As to when to give up FF, I usually call the airport in sight, and I definitely want to be on CTAF at five miles. Here in the NE, there could be 2 to 3 other planes looking to do the same thing I am at the very same time (ie all overflying the field or entering the 45 from different directions) and my eyeballs only work to about 3-5 miles at best. This area is going to become very interesting over the next ten years. Since the Port Authority of NY/NJ just took over official ownership of KSWF last week. I saw plans for major highway and interstate changes to get airport access. This area could see the next Class C if the plans are even half fulfilled. That would probably open a new desk at TRACON and give even better access for services. However, us VFR spamcans will have one less block of airspace to just buzz around in. |
On Sun, 4 Nov 2007 11:45:19 -0500, "Tman" N/A wrote:
Since you are talking to ATC, unless told to maintain clearance or altitude, there is no reason you can't fly through class D or C airspace or even B if told cleared through the Bravo. Really AIM 3.2.5 says that i need to have two-way radio contact with the "ATC facility providing ATC services", which in this case i think means i need to be talking to Stewart Tower, not NY Approach (?). And this uncontrolled field he's asking about has a tower? It should be at least 5 out, Airport in sight, request frequency change. They'll approve the change and terminate FF at that point usually with any traffic advisories if they see any. 5 out gives you at least a bit of time to monitor CTAF or UNICOM and anounce your intentions. Roger (K8RI) T |
Flight Questions | Jed | Piloting | 32 | September 15th 07 03:12 PM |
GPS approach in VFR wx at uncontrolled field | BobKK47 | Instrument Flight Rules | 14 | March 13th 07 03:06 PM |
Closing IFR flight plan at uncontrolled field | paul kgyy | Instrument Flight Rules | 18 | February 9th 06 02:27 PM |
Boeing Field/Mus. Of Flight Trip | gatt | Piloting | 0 | August 5th 04 08:12 PM |
Position and Hold at uncontrolled field | dave | Piloting | 42 | February 26th 04 01:25 AM |
