C-182's to avoid?
Old November 14th 07, 05:20 PM posted to rec.aviation.owning
Jay Honeck
Default C-182's to avoid?
Is there a line in time or models where 182's should be avoided?
Better an older 182 or a newer 177 with 180 hp constant speed?
IMHO it's a dicey time to be buying any big-bore, fuel-injected, 200+
horsepower airplane. With 100 LL on its way out -- and no approved
replacement in the wings -- prices of these birds have no where to go
but down.
If I were looking for a plane like this (and I own a very similar
airplane) I would restrict my search to normally-aspirated, low
compression engines that can run on mogas. (Although even that is a
crap-shoot now, with mandatory ethanol pollution in many states.) At
least you'll have a plane that can be used (and sold) at some point
down the line.
Unless oil prices stabilize -- which seems unlikely -- the market for
gasoline-powered, high-compression aircraft will remain very, very
uncertain.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 14th 07, 05:37 PM posted to rec.aviation.owning
RST Engineering
The O-470 is a low compression engine that runs on mogas. You ought to
know, Jay, you've filled our 182 up from the Grape several times now.
"If you think you can, or think you can't, you're right."
--Henry Ford
"Jay Honeck" wrote in message
but down.
down the line.
uncertain.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 14th 07, 10:27 PM posted to rec.aviation.owning
Matt Whiting
but down.
down the line.
Jay, my 1967 C-182 ran just fine on auto gas.
Matt
Old November 15th 07, 12:07 AM posted to rec.aviation.owning
Alan Browne
Alan Browne wrote:
I was speaking with a somewhat smug fellow the other day who claimed
Thanks everyone for your replies.
Cheers,
Alan
Old November 15th 07, 04:19 AM posted to rec.aviation.owning
Newps
I've been hearing that for 15 years. It's no more true today than back
then.
-- and no approved
92UL is but a few signatures away. A very tiny number of engines can't
use it but everything else can.
but down.
Merely a downturn as in the 70's. Aviation is cyclical.
down the line.
Buying a plane that can run on mogas has a lower life expectancy than
100LL. Won't be long before all mogas has alcohol.
Old November 15th 07, 04:40 AM posted to rec.aviation.owning
nrp
Check:
http://download.aopa.org/epilot/2007/071114epa.pdf
Old November 15th 07, 02:00 PM posted to rec.aviation.owning
Jay Honeck
Yep, I know. But the OP was asking about which models to avoid, so I
was suggesting that he avoid the later fuel-injected, high compression
models that can only run on 100 LL.
Jay Honeck
Iowa City, IA
Pathfinder N56993
See & Avoid Ol Shy & Bashful Piloting 27 August 2nd 07 01:27 PM
See and avoid... Ramy Soaring 22 January 30th 07 09:18 PM
See and Avoid applies to both IFR and VFR Brad Z Piloting 14 July 17th 04 05:48 AM
Avoid CSA website F.L. Whiteley Soaring 2 June 23rd 04 10:21 PM
See and avoid Kees Mies Piloting 39 March 22nd 04 08:31 PM
