![]() "Token" wrote in message news ![]() http://www.cnn.com/2003/WORLD/meast/...ain/index.html This story is claiming that a MANPAD hit a courier aircraft today. If the story is correct it was an SA-7, I would think a 7b. Imagine how much better something designed in the last quarter century might do? Horrifying for us all. A few months ago there was a thread in here about heat seekers and high bypass ratio engines. Those certainly look like high bypass ratio engines to me. I only saw a glimpse but it looked like an A310 with GE CF6 engines. The RB211 engine might have a reasonable chance of obscuring the hot exhaust nozzle as the shorter length of the Rolls Royce engines' 3 spool shaft allows the fan cowling to extend back beyond the exhaust nozzle thus covering up hot metal completely. (RR use this technique to reduce noise however) Several times threads have erupted here about the ability of a MANPAD to take down an airliner on take-off. One data point is poor statistics so I am not commenting one way or the other, but here is one that got wacked on climb-out, and managed to go around and land. T! |
If you look at the picture the damage is to the wing mid-way to the wingtip
not the engine maybr do due to a proximity detonation? Myc |
![]() "Tarver Engineering" wrote in message ... "Mycroft" david wrote in message ... If you look at the picture the damage is to the wing mid-way to the wingtip not the engine maybr do due to a proximity detonation? It missed the engine, either way. Either way, it scrubbed the mission. Pete |
"Pete" wrote:
"Tarver Engineering" wrote in message ... "Mycroft" david wrote in message ... If you look at the picture the damage is to the wing mid-way to the wingtip not the engine maybr do due to a proximity detonation? It missed the engine, either way. Either way, it scrubbed the mission. Pete Probably not the only items that needed scrubbing I'll wager... -- -Gord. |
![]() "Mycroft" david wrote in message ... If you look at the picture the damage is to the wing mid-way to the wingtip not the engine maybr do due to a proximity detonation? Myc I would suspect that if the missile did indeed hit the engine at all that fragments of either the weapon or the motor could have hit the wing. More likely the weapon missed the engine proper and impacted someplace near on the wing, or came in at an angle, clipped the engine, and impacted the wing. I believe that this is quite common from the pictures of missile hits during Desert Storm. Example he http://www.pats-world.com/gulfwar/ab...181/181-11.jpg The news reports on this incident I have seen so far all are saying it was an SA-7. But if it was anything later than that (SA-14 or newer) it would be a plume tracker anyway. A plume tracker must "push ahead" before impact or it will pass harmlessly behind the engine and through the plume. I would think the push ahead would result in many hits on parts of the aircraft other than the engine itself. As far as the possibility of proximity fuzing, according to most web sources the SA-7 is contact fused only. Here is an example link: http://www.fas.org/man/dod-101/sys/missile/row/sa-7.htm That site also claims that the Stinger, the SA-14 and the SA-16 have the same type of contact fusing, it does not specify for the SA-18. T! |
"The Enlightenment" writes: "Token" wrote in message news ![]() http://www.cnn.com/2003/WORLD/meast/...ain/index.html This story is claiming that a MANPAD hit a courier aircraft today. If the story is correct it was an SA-7, I would think a 7b. Imagine how much better something designed in the last quarter century might do? Horrifying for us all. In this case, I don't think so. The warheads on the newer MANPADS aren't any bigger, or, on the whole, much more differntly designed than the ones you'll find on the SA-7/Redeye/Blowpipe. Where they're more sopisticated is getting that warhead into proximity fuze range, so that it goes off. In this case, the warhead went off. (There was a case last summer involving an El Al jet where they didn't.) Terminal effects are going to be the same. The better ECCM adn guidance laws built into an SA-14, say, aren't going to improve your Pk against a slow, unagile, and unaware target like the DHL Airbus. You don't need that extra 10% for that kind of target. A few months ago there was a thread in here about heat seekers and high bypass ratio engines. Those certainly look like high bypass ratio engines to me. I only saw a glimpse but it looked like an A310 with GE CF6 engines. The RB211 engine might have a reasonable chance of obscuring the hot exhaust nozzle as the shorter length of the Rolls Royce engines' 3 spool shaft allows the fan cowling to extend back beyond the exhaust nozzle thus covering up hot metal completely. (RR use this technique to reduce noise however) And since the missile is more likely to be homing on the hot spot of the exhaust plume, which is a bit behind the nozzle, I'd rather boupt that wheterh it was a CF6 or an RB.211 would make any difference. A direct hit on an engine isn't necessary - getting the warhead close enough to fuze means that the fragments are going into the aircraft right where all that side's fuel, hydraulics, electrical lines, control rums, and, if appropriate, hot air bleeds are routed. Anywhere on a large jet near the engines is a mighty tender spot. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"Peter Stickney" wrote in message
... In article , In this case, I don't think so. The warheads on the newer MANPADS aren't any bigger, or, on the whole, much more differntly designed than the ones you'll find on the SA-7/Redeye/Blowpipe. Where they're more sopisticated is getting that warhead into proximity fuze range, so that it goes off. In this case, the warhead went off. (There was a case last summer involving an El Al jet where they didn't.) Terminal effects are going to be the same. The better ECCM adn guidance laws built into an SA-14, say, aren't going to improve your Pk against a slow, unagile, and unaware target like the DHL Airbus. You don't need that extra 10% for that kind of target. The Shorts ManPADS family that started with Blowpipe is one where there was significant improvement in the warhead. The Blowpipe had a combination blast and shaped charge warhead so that it also had a ground target capability for self defence. With Javelin GL and S-15 (Starburst), the change was made to a blast warhead without the compromise of a shaped charge. The latest, Starstreak, actually has three kinetic energy projectiles that are launched from the main stage and which fly in formation. That said, I think Shorts missiles could be voted among the least likely to find their way into terrorist hands, even if they are the ManPADS systems most capable of bringing down large airliners (well, RBS-70 is, but it's an even greater pain in the arse to lug about); the training bill is just too high. -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
Token wrote:
http://www.cnn.com/2003/WORLD/meast/...ain/index.html This story is claiming that a MANPAD hit a courier aircraft today. If the story is correct it was an SA-7, I would think a 7b. Imagine how much better something designed in the last quarter century might do? A few months ago there was a thread in here about heat seekers and high bypass ratio engines. Those certainly look like high bypass ratio engines to me. Several times threads have erupted here about the ability of a MANPAD to take down an airliner on take-off. One data point is poor statistics so I am not commenting one way or the other, but here is one that got wacked on climb-out, and managed to go around and land. We can be thankful they do not seem to have ManPADS with a forward aspect engagement capability. Those tend to be directed at the centre of mass rather than heat sources. Something like Blowpipe, although obsolete, has a 3.5 lb. warhead. -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
LA Times : Freight Dogs | G Farris | Instrument Flight Rules | 1 | January 13th 05 12:02 PM |
Dillsburg freight rates to Europe | Tom | Home Built | 0 | May 31st 04 11:55 AM |
Been ripped by AS&S deceptive freight pricing??? | Kenny Danielson | Home Built | 43 | August 30th 03 07:31 PM |
