FYI: Dec 12 MythBusters: Airplane Hour
Old December 9th 07, 03:17 PM posted to rec.aviation.piloting
Dana M. Hague
Default FYI: Dec 12 MythBusters: Airplane Hour
On Sun, 09 Dec 2007 05:32:29 -0000, Jim Logajan
"Jamie and Adam take wing to test if a person with no flight training can
safely land an airplane...
...I presume the plane they attempt to land without training is a 747.
Will be interesting to see if they try the real thing and are not limited
to a simulator.)
Air Progress did an article on that around 1976, well, not a non pilot
but a low time private, based on the premise of Arthur Hailey's
"Runway Zero-Eight". Stuck him in a 727 simulator set up in the
middle of a flight and as I recall, he got it down just fine.
Somehow I doubt the Mythbusters budget runs to a real 747 flight...
-Dana
If replying by email, please make the obvious changes.
The Bill of Rights goes too far--it should have stopped at "Congress shall make no law".
Old December 9th 07, 03:19 PM posted to rec.aviation.piloting
Dana M. Hague
Default Dec 12 MythBusters: Airplane Hour
On Sun, 09 Dec 2007 13:32:23 GMT, B A R R Y
If it were so cut and dried, why does it generate threads of several
hundred messages here? G
Because people don't understand basic physics (or aerodynamics).
Neither do the Mythbusters crew, either... or more likely, they just
don't care as long as the show gets ratings.
-Dana
Old December 9th 07, 03:35 PM posted to rec.aviation.homebuilt, rec.aviation.piloting
Harry K
On Dec 9, 7:14 am, " Vacant lot wrote:
"B A R R Y" wrote in messagenews:ghrnl3h2rm847jvivviio87sa7arlkjvo7@4ax .com...
On Sun, 9 Dec 2007 09:12:27 -0400, " Vacant lot
know
the answer. What are they trying to prove?
The show? I've never seen it mentioned before. Or were you talking about
airspeed? I think almost everyone agrees that airspeed must meet a certain
velocity for flight. I allow for some who may still be alive who feel
differently.
The problem is that people, when arguing against take-off, forget that
airspeed is generated by the prop or jet and has nothign at all to do
with how fast, what direction, or even _if_ the wheels are spinning
(as long as the engine can generate enough force to drag them).
The long threads are generated by people who refuse to recognize that.
Harry K
Old December 9th 07, 03:50 PM posted to rec.aviation.piloting
Mxsmanic
Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net writes:
A full-motion simulator would suffice to prove the point. If you can land the
sim, you can land the real thing. If you can't land the sim, well, at least
nobody gets hurt.
Old December 9th 07, 04:23 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
muff528
"Blueskies" wrote in message
et...
"Maxwell" wrote in message
I don't understand the premise of the conveyor belt thing. If you are
talking about thrusting an aircraft forward, like a catapult, you
already
know the answer, and if the belt is running so the the wheels of the
aircraft are spinning madly while it stays still then again you already
know
Only because there are one or two nit pickers on here.... G
Maybe we should start the thread drift right here and now....
You know, people would fully understand that a plane on a treadmill will
not start flying if we had a good educational system. Liberal use of
aerodynamic principles leads to stall spin accidents, and everyone knows
the dreaded downwind turn was by global warming...
Hang on!....Here we go again! :0)
TP
Old December 9th 07, 04:45 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Capt. Geoffrey Thorpe
talking about thrusting an aircraft forward, like a catapult, you already
know
Because the answer depends on a lot of assumptions that are not stated as
part of the original question.
:-p
Geoff
Old December 9th 07, 05:27 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
Dan[_2_]
James Sleeman wrote:
On Dec 9, 6:32 pm, Jim Logajan wrote:
safely land an airplane and if a plane can take off from a conveyor belt
Oh lordy, here we go again, I sense an enormous thread coming.
It's not how big the thread is, it's how you use it.
Dan, U.S. Air Force, retired
Old December 9th 07, 05:29 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
B A R R Y
On Sun, 09 Dec 2007 09:02:36 -0500, Dudley Henriques
It shouldn't :-)
I agree.
Old December 9th 07, 05:33 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.skydiving
cavelamb himself[_4_]
It shouldn't :-)
I agree.
Make that unanimous
Can we drop it now?!
Mythbusters Episode and FMS Marco Leon Piloting 19 February 13th 07 05:45 AM
..and another hour... hellothere.adelphia.net Rotorcraft 7 October 7th 04 11:26 AM
Mythbusters and explosive decompression Casey Wilson Piloting 49 July 15th 04 05:56 PM
MythBusters Hilton Piloting 7 February 4th 04 03:30 AM
Mythbusters Explosive Decompression Experiment C J Campbell Piloting 49 January 16th 04 07:12 AM
