![]() "gwengler" wrote in message ... Isn't that interesting. On both Jepp approach plate and low enrout chart, PYRAM is identified as HZN 286R and FMG 332R. I measured it with FliteStar and it's indeed 303T from HZN, which is correct (Station Declination: 17.0°E). LIGBE is defined as by the IRNO / RW16R Localizer at KRNO at 27.4 NM by Jeppesen, but it's also FMG 332R. JO 7350.7B Location Identifiers shows PYRAM to be the intersection of the HZN 286 and FMG 332 radials as well as the FMG 332R 22 DME fix. The low altitude enroute chart is in error, I've sent a message to NACO about it. |
On Dec 14, 9:11 am, "Steven P. McNicoll"
wrote: On Dec 14, 7:24 am, Ron Rosenfeld wrote: On Thu, 13 Dec 2007 12:44:37 -0500, "Kobra" wrote: No idea, but I would like to know how on an ILS approach without GPS one would identify PYRAM. You use your low altitude chart. PYRAM is defined by the 286.0° radial from HZN (Hazen VOR) at 41.7 NM. It is on V165 a few miles south of LIBGE Are you looking at a Jeppesen chart? NACO low altitude enroute chart L-9 shows LIBGE to be where the HZN 286R crosses V165. NACO high altitude enroute chart H-3 shows PYRAM to be where the HZN 286R crosses J5. V165 and J5 are defined by the FMG 332R. Isn't that interesting. On both Jepp approach plate and low enrout chart, PYRAM is identified as HZN 286R and FMG 332R. I measured it with FliteStar and it's indeed 303T from HZN, which is correct (Station Declination: 17.0°E). LIGBE is defined as by the IRNO / RW16R Localizer at KRNO at 27.4 NM by Jeppesen, but it's also FMG 332R. Gerd |
On Fri, 14 Dec 2007 06:11:45 -0800 (PST), "Steven P. McNicoll"
wrote: On Dec 14, 7:24 am, Ron Rosenfeld wrote: On Thu, 13 Dec 2007 12:44:37 -0500, "Kobra" wrote: No idea, but I would like to know how on an ILS approach without GPS one would identify PYRAM. You use your low altitude chart. PYRAM is defined by the 286.0° radial from HZN (Hazen VOR) at 41.7 NM. It is on V165 a few miles south of LIBGE Are you looking at a Jeppesen chart? NACO low altitude enroute chart L-9 shows LIBGE to be where the HZN 286R crosses V165. NACO high altitude enroute chart H-3 shows PYRAM to be where the HZN 286R crosses J5. V165 and J5 are defined by the FMG 332R. Actually I copied the "properties" of the Pyram intersection from FliteStar, which is based on Jepp data. I don't have a Jepp chart for the approach, though. FliteStar does not actually chart the HZN 286°R. LIBGE "measures" to be about 2.7NM NW of PYRAM on V165. Looking at the data from FliteStar, it is interesting that the magnetic variation at PYRAM (and LIGBE) is 15.8°E; but at HZN, the Station Declination is 17.0°E with an Actual MagVar of 14.3°E. OK, I have an electronic copy of L9 and H3 I see what you mean about it showing the HZN 286°R pointing to LIBGE on the LO and to PYRAM on the HI charts. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message ... OK, I have an electronic copy of L9 and H3 I see what you mean about it showing the HZN 286°R pointing to LIBGE on the LO and to PYRAM on the HI charts. For others interested, charts can be viewed online at http://skyvector.com/ .. Enter the fix and you can switch between high, low and sectional charts. |
On Dec 13, 11:34 am, nick name wrote:
The ILS 16R (http://tinyurl.com/353gd5) at Reno (KRNO) has the notation: "8500 to GS intercept 181 (2) and LOC (8.8)" I don't understand this. It appears this means that GS intercept will occur in 2 miles on a 181 heading and that LOC intercept will occur in 8.8 miles. Neither appears to be true from the plan view. In fact, it looks more like LOC intercept will occur in 2 miles and GS intercept in 8.8 (at 8500 feet). Any insights? You fly to PYRAM (which can be identified by FMG 332 radial and HZN 286 radial). From there you continue at 8500 for 2 miles (IRNO DME) at 181 deg. Then (after 2 miles) you turn to 164 deg, i.e. intercept the localizer. From the point you change your heading, it's 8.8 miles (INRO DME) from PYRAM to GS intercept. Gerd |
![]() "gwengler" wrote in message ... You fly to PYRAM (which can be identified by FMG 332 radial and HZN 286 radial). What chart are you looking at? Low altitude enroute chart L-9 shows the intersection of the FMG 332R and HZN 286R to be LIBGE, three miles north of PYRAM. |
On Dec 13, 5:44 pm, "Steven P. McNicoll"
wrote: "gwengler" wrote in message ... You fly to PYRAM (which can be identified by FMG 332 radial and HZN 286 radial). What chart are you looking at? Low altitude enroute chart L-9 shows the intersection of the FMG 332R and HZN 286R to be LIBGE, three miles north of PYRAM. I took this information from the Jeppesen approach plate KRNO ILS16R 11-1 24-Aug-07. PYRAM is clearly identified as I said above. It's 22.2D from FMG. Gerd |
On Dec 13, 10:34 am, nick name wrote:
The ILS 16R (http://tinyurl.com/353gd5) at Reno (KRNO) has the notation: "8500 to GS intercept 181 (2) and LOC (8.8)" I don't understand this. It appears this means that GS intercept will occur in 2 miles on a 181 heading and that LOC intercept will occur in 8.8 miles. Neither appears to be true from the plan view. In fact, it looks more like LOC intercept will occur in 2 miles and GS intercept in 8.8 (at 8500 feet). Any insights? It means maintain 8500 MSL until intercepting the glideslope. You're a total of 10.8 miles from GS intercept at PYRAM, 2 miles on a 181 heading and 8.8 miles on the LOC. |
nick name wrote:
The ILS 16R (http://tinyurl.com/353gd5) at Reno (KRNO) has the notation: "8500 to GS intercept 181 (2) and LOC (8.8)" I don't understand this. It appears this means that GS intercept will occur in 2 miles on a 181 heading and that LOC intercept will occur in 8.8 miles. Neither appears to be true from the plan view. In fact, it looks more like LOC intercept will occur in 2 miles and GS intercept in 8.8 (at 8500 feet). Any insights? The Jeppesen chart makes it much clearer http://tinyurl.com/24kxmt |
