Engine configuration
Old December 22nd 07, 04:19 AM posted to rec.aviation.homebuilt
Dale Scroggins[_2_]
Default Engine configuration
Have you ever read Lycoming's recommendations for leaning their engines?
The engine runs as cool at 25 degrees lean of peak as it will 25 degrees
rich of peak. It isn't as smooth, and it has that lean "bark", but it
doesn't hurt the engine if the power setting is below 75 percent. The
engine runs cleaner.
We had a customer once who was scared to lean his engine correctly. He
leaned just enough to keep the engine smooth at altitude. One day he took
off from a mountaintop airport and had two intake valves seize. Luckily,
there was another airport in the valley below, so the airframe survived
fine. But his fear of leaning sure made a mess of that Lycoming.
"Ron Webb" wrote in message
Yea, I've heard of it. You won't catch me, or anyone I know trying it for
very long. Experimenting on a $15K IO360
is not something I am comfortable with.
Never heard of "agressive leaning" of air cooled aircraft engines?
Below peak power it is very viable
Posted via a free Usenet account from http://www.teranews.com
Old December 22nd 07, 04:43 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Fri, 21 Dec 2007 17:19:51 -0900, "Ron Webb"
Well beyond the experimentation phase. Very well documented.
Actually RECOMMENDED on engines designed for 87 octane when running
100LL. Keeps the valves from hanging from "lead poisoning"
Also greatly extends cruise range.
This was investigated and proven by of all people, Charles Lindburg,
WAYYYYY back then.
Also see:
http://www.megginson.com/blogs/lahso...12/23/leaning/
Old December 23rd 07, 04:04 PM posted to rec.aviation.homebuilt
GeorgeB
On Fri, 21 Dec 2007 17:45:28 -0900, "Ron Webb"
Blanton's claim that you could get 230 reliable HP out of it was vigorously
debated.
With open intake, open exhaust, ported heads, big cam and carb, and forged
rods and pistons for reliability my desktop Dynamometer program shows over
330 HP at 6500 RPM, and 278 HP at a more sedate 5000 RPM possible, without
forced induction. Dyno2000 is usually very close to right. Blanton claimed
260 HP, derated to 230 HP.
I doubt that anyone will argue with that statement. The problem isn't
in getting that power out, it is with getting the heat out, even with
water cooled engines. An engine, to give 2000 hours MTBF (well, with
a 2000 hour TBO, you would want the MTBF significnatly longer) needs
more than great tuning.
You did say reliable; remember that an airplane engine typically will
be expected to operate at 75% to 85% power for hours at a time; an
automobile engine in a 2500 lb car (think Cessna 182 or Cirrus)
running at 60 MPH probably averages 20 HP. I cannot prove my
automobile numbers, and they may be all wet.
Look at highly tuned auto engiens ... NASCAR probably gets 800 HP from
350 cu-in ... and they last 4 or 5 hours. Drag racers likely get over
double that, but their engines last minutes.
Contrary to what many think, most accept that the "obsolete"
Lyconental engines are pretty good products, making below 0.4 lb/hp-hr
SFC ... better than many cars. That's EFFICIENT!
I'd bet that if an auto engine would out perform Lycontental, we'd see
them certified and in use; the only water cooled engine I know of in
certified applications is the water cooled HEAD engine by Rotax. They
get 80 HP @ 5500 rpm from 74 cu-in ... and a 1500 hr TBO. They are
not cheap to build, either; even the uncertified ones are in the
$15,000 range.
Business wants to make money; if you can build a 230 HP engine that
will reliably give 2000 hours in an airplane and sell it for $10,000,
I'd bet that getting it certified and insured will be a piece of cake
.... certified, it is probalby over a $30,000 sale.
But my own opinion ... if it were that easy, it would have been done.
Old December 23rd 07, 07:39 PM posted to rec.aviation.homebuilt
Morgans[_2_]
$15,000 range.
It has been, by many people. Many V-8's and V-6's are well past 2,000
hours, with no rebuilding necessary.
Orenda did it, and certified it, but designed their own V-8, but it is not
much different than GM V-8's.
It might be time to trot out the blog on how GM torture tests it's engines,
before a design goes into
production. I don't have the file handy, but perhaps someone else does.
Without the file handy, it is an easy jump to say that their duty cycles and
punishment make a certification test run look like child's play.
The problem with auto engine conversions is seldom the engine. It is
usually in the accessories, or the prop speed reducers. There are good
products out there for those, too. One has to only put them together.
Old December 23rd 07, 08:45 PM posted to rec.aviation.homebuilt
Ron Webb
Here's one current example of a very well done Ford 5.0L V8. There are MANY
more.
http://www.haaspowerair.com/index.html
The FAA, and the legal system conspire to make selling these things an
unprofitable enterprise...but it can be done - even by an individual in his
garage...as proven thousands of times.
engines, before a design goes into
and punishment make a certification test run look like child's play.
Old December 23rd 07, 08:54 PM posted to rec.aviation.homebuilt
Bill Daniels
"Morgans" wrote in message
$15,000 range.
FWIW, My Chrysler 318 Cu In V8 just turned 8600 hours without any service
other than oil changes and spark plugs. Of course, that's in a Jeep Grand
Cherokee. As I understand it, the 318 is neither better or worse than other
V8's.
In the Jeep, it gets 20mpg at 60mph which is 3gph.
That's 45hp @ 2100 RPM.
It weighs about 545 pounds.
If you insist on 200HP @ 4500rpm output at cruise, which you would want to
do to justify all that weight, it might not last as long.
Bill Daniels
Old December 23rd 07, 09:47 PM posted to rec.aviation.homebuilt
Matt Whiting
$15,000 range.
V8's.
Wow, you have an hour meter in your Jeep. I never saw that on the
options list!
Matt
Old December 23rd 07, 10:35 PM posted to rec.aviation.homebuilt
Bill Daniels
"Matt Whiting" wrote in message
$15,000 range.
not much different than GM V-8's.
Grand Cherokee. As I understand it, the 318 is neither better or worse
than other V8's.
Wow, you have an hour meter in your Jeep. I never saw that on the options
list!
Matt
It's in the vehicle computer but you have to have a scanner to see it.
You'd be amazed at the information those black boxes keep on you.
Bill D
Old December 23rd 07, 10:37 PM posted to rec.aviation.homebuilt
GTH
more.
I do not doubt there are MANY successful V8 engines in MANY airplanes
flying MANY happy hours.
The problem is, MANY is not proving anything.
What we would need is, HOW MANY such engines made it to TBO, and in HOW
MANY clearly identified airplanes.
Only a few hundreds would suffice...;-)
Best regards,
Gilles
http://contrails.free.fr
Old December 24th 07, 12:41 AM posted to rec.aviation.homebuilt
Ron Webb
And that's what the situation will not allow (for it's own reasons). When
you can't field a standardized package, with known engineering behind it,
you are stuck evaluating "backyard" prototypes, done by mostly amateurs,
against the pro's with 30 year proven packages.
It's just amazing that our stats are still competitive, even so. The NTSB
database
(http://www.ntsb.gov/ntsb/query.asp)
has fields for homebuilt vs certificated aircraft. (though not engines).
I've played with it quite a lot, and as best I can tell, the homebuilt
industry has about 2x as many accidents per flight hour. Almost all of these
are stupid stuff. When you do find a crash because of an engine failure,
it's usually a poorly designed fuel feed, a PSRU belt broken, or a poorly
designed cooling system causing an in flight overheat. Amateur engineering
can be fatal.
Engine configuration Michael Henry Home Built 42 December 20th 07 10:30 PM
Engine configuration cavedweller Home Built 7 December 16th 07 01:23 AM
V-22 Prop Configuration, 3-vs-4 blades Don McIntyre Naval Aviation 23 April 10th 06 03:23 AM
T-2C Buckeye nav light configuration. Mike W. Naval Aviation 14 March 17th 05 07:05 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 05:57 PM
