Hobo writes: Has there ever been an aircraft with a gun permanently aligned off-center? I don't mean swivel mounted, but permanently fixed at a point other than straight ahead. Quite a few, actually. Assuming that you're willing to stipulate teh defensive guns on bombers ranging from the Be.2C in WW I (ANd yes, they did drop a few bombs) to the Tu-22M Backfire. In terms of fighters, It's been done a number of times. The most mentioned would be the upward-pointing "Shrage Muzik" guns on German Night Fighters. This allowed them to formate on RAF night bombers in the one quadrant with no lookouts or guns, and shoot into the largest possible area - teh entire planform of the aircraft. The Japanese tried something similar. Wouldn't a gun pointed at a downward angle make ground attack easier? Check out the Junkers-Larson ground attack prototype made for the U.S. Army in the 1920s. It was basically an all-metal Junkers monoplane transport with something like 30 .45 Calibre Thomson Submachineguns firing at vatious angle through the bottom fuselage. The idea was that it would fly along trench lines at low altitude, saturating the trenches with bullets. (The opinions of the Gun Plumber on board who'd have to change 30 75 round drum magazines after each pass has not been recorded. Rest assured that it would have been short, to teh point, disapproving, and contained a lock of words that rhymed with "Duck".) In the 1930s, the French built a large gunship with a downward firing 105mm Howitzer. From the 1960s on, the USAF, and several allied nations, have flown various transports (C-47, C-119, C-130) with arrays of guns pointing out of the side, aimed by maintaining a pylon turn around the target. (Well, at first, at least) These guns have range from 7.62mm machine guns to 105mm Howitzers, backed up by an extensive sensor suite and ballistic computers. The side-firing bit allows you to engange targets without flying over them, which is generally considered a good thing. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
U.S. Army in the 1920s. It was basically an all-metal Junkers monoplane transport with something like 30 .45 Calibre Thomson Submachineguns firing at vatious angle through the bottom fuselage. The idea was that it would fly along trench lines at low altitude, saturating the trenches with bullets. (The opinions of the Gun Plumber on board who'd have to change 30 75 round drum magazines after each pass has not been recorded. Rest assured that it would have been short, to teh point, disapproving, and contained a lock of words that rhymed with "Duck".) I could have sworn I saw something on the history channel once about a modification someone tried on a Canberra... they made a pallet for the bomb bay and fitted a dozen or so guns pointing straight out the bottom of it... I think they showed it firing in ground tests, but that's all I've ever heard about it... |
U.S. Army in the 1920s. It was basically an all-metal Junkers monoplane transport with something like 30 .45 Calibre Thomson Submachineguns firing at vatious angle through the bottom fuselage. The idea was that it would fly along trench lines at low altitude, saturating the trenches with bullets. (The opinions of the Gun Plumber on board who'd have to change 30 75 round drum magazines after each pass has not been recorded. Rest assured that it would have been short, to teh point, disapproving, and contained a lock of words that rhymed with "Duck".) In the 1930s, the French built a large gunship with a downward firing 105mm Howitzer. From the 1960s on, the USAF, and several allied nations, have flown various transports (C-47, C-119, C-130) with arrays of guns pointing out of the side, aimed by maintaining a pylon turn around the target. (Well, at first, at least) These guns have range from 7.62mm machine guns to 105mm Howitzers, backed up by an extensive sensor suite and ballistic computers. The side-firing bit allows you to engange targets without flying over them, which is generally considered a good thing. -- Acutally, I believe the Germans were first. They developed a class of Riesenflugzeug (Giant Aircraft) which began appearing in 1915. By 1916, LT Ernst Neuber began working on his idea of mounting a 130mm cannon vertically in the belly of an R-plane. Static tests began 25 May 1916 using a Gotha East Experimental. On 6 October 1916 the gun was installed on the R-plane and the gun was test fired several time in flight on 19 October. The Germans continued testing and were working on a 105mm automatic cannon firing 20 rounds/minute when the war ended. Neuber even patented his invention (#305,039). There are reports of a side-firing .30 calibre machine gun being used on a DH-4 in 1927. The French system of 1932 used the fameous French 75 mounted side-ways in the Bordelaise A.B. 22 aircraft. The USA tested the side-firing gunship concept duirng the summer of 1964 at Eglin AFB using a C-131 transport and, IIRC, a single .7.62 mini-gun. The first American gunship was the "FC-47" which carried 10 .30 cal side-firing machine guns developed by Major Ronald W. Terry at Eglin AFB. Ed "The French couldn't hate us any more unless we helped 'em out in another war." --Will Rogers (Delete text after dot com for e-mail reply.) |
RobbelothE wrote:
Check out the Junkers-Larson ground attack prototype made for the U.S. Army in the 1920s. It was basically an all-metal Junkers monoplane transport with something like 30 .45 Calibre Thomson Submachineguns firing at vatious angle through the bottom fuselage. The idea was that it would fly along trench lines at low altitude, saturating the trenches with bullets. (The opinions of the Gun Plumber on board who'd have to change 30 75 round drum magazines after each pass has not been recorded. Rest assured that it would have been short, to teh point, disapproving, and contained a lock of words that rhymed with "Duck".) In the 1930s, the French built a large gunship with a downward firing 105mm Howitzer. From the 1960s on, the USAF, and several allied nations, have flown various transports (C-47, C-119, C-130) with arrays of guns pointing out of the side, aimed by maintaining a pylon turn around the target. (Well, at first, at least) These guns have range from 7.62mm machine guns to 105mm Howitzers, backed up by an extensive sensor suite and ballistic computers. The side-firing bit allows you to engange targets without flying over them, which is generally considered a good thing. -- Acutally, I believe the Germans were first. They developed a class of Riesenflugzeug (Giant Aircraft) which began appearing in 1915. By 1916, LT Ernst Neuber began working on his idea of mounting a 130mm cannon vertically in the belly of an R-plane. Static tests began 25 May 1916 using a Gotha East Experimental. On 6 October 1916 the gun was installed on the R-plane and the gun was test fired several time in flight on 19 October. The Germans continued testing and were working on a 105mm automatic cannon firing 20 rounds/minute when the war ended. Neuber even patented his invention (#305,039). There are reports of a side-firing .30 calibre machine gun being used on a DH-4 in 1927. The French system of 1932 used the fameous French 75 mounted side-ways in the Bordelaise A.B. 22 aircraft. The USA tested the side-firing gunship concept duirng the summer of 1964 at Eglin AFB using a C-131 transport and, IIRC, a single .7.62 mini-gun. The first American gunship was the "FC-47" which carried 10 .30 cal side-firing machine guns developed by Major Ronald W. Terry at Eglin AFB. There was an installation in (I think) the Me-163 Komet which would trigger an upward-firing weapon when the shadow of an Allied bomber passed over it. AFAIK was used as well. John |
Hobo wrote:
Wouldn't a gun pointed at a downward angle make ground attack easier? Most likely not, as you wouldn't be able to see what you were shooting at. Mike |
![]() Has there ever been an aircraft with a gun permanently aligned off-center? I don't mean swivel mounted, but permanently fixed at a point other than straight ahead. Yes. The Japanese Army Air Force regularly mounted oblique cannon (aimed upward and forward at perhaps a 30-degree angle) in their interceptors in an attempt (not terribly successful) to shoot down the B-29s which they couldn't otherwise reach. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Curtiss F-type flying boats in WW1 had a Davis recoiless gun mounted
in the nose cockpit. It had to be fired downward because its recoil counterweight was a charge of shot in a grease matrix fired out the back end of the tube. FWIW I understand the initial idea for the 'Puff' series gunships was the technique of servicing missionary stations in the Amazon with Piper Super Cubs by flying in a tight circle while lowering a bucket on a rope. Due to aero drag on the rope the bucket lagged behind and pivoted on the polar axis of the circle and the ground people could remove their mail, etc, and place their outgoing mail and requests in the bucket which was then hauled back up. The rotation was slow enough to be no problem, and then the curvature of the rope reminded someone of the trajectory of a gun so - voila! As for strafing in the F15 with its upward gun - check the -34 for the sight mil settings and fire further out so the bullets will drop down below the extended water line. Time of flight will indicate how far the bullets will drop - it is all solvable with simple trig. Walt BJ |
On Mon, 08 Dec 2003 05:07:41 -0500, Cub Driver
wrote: This is wonderful. Can either of you or anybody point me to more information about this service? I realize there are only 12 issues of Geographic a year, but it would help if I could narrow it down. I remember the same photo and I'm pretty sure it's a mid-'60s issue, probably from 1965-1967. The photo shows somebody either putting mail in or pulling mail out of a bucket hanging on a rope, and you can see the aircraft that's dropping the bucket flying at altitude in the background. I did a lookup on NGS' pubs website at http://www.nationalgeographic.com/pu...s/explore.html and got some possibilities: keyword "Amazon" - Oct 1972 "Amazon--The River Sea" Aug 1970 - "Colombia, from Amazon to Spanish Main" May 1964 - "Indians of the Amazon Darkness" March 1959 - "Children of the Sun and Moon" keyword "Colombia" May 1966 "Capturing Strange Creatures in Colombia" Aug 1970 "Colombia, from Amazon to Spanish Main" Feb 1966 "Flamboyant Is the Word for Bolivia" There are many possibilities - try different keywords for various SA countries and narrow down the results by date. John Hairell ) |
Aircraft Walkaround Center alive and well, new URL | Voigt Lander | Military Aviation | 7 | December 10th 03 04:16 PM |
Center vs. Approach Altitudes | Joseph D. Farrell | Instrument Flight Rules | 8 | October 21st 03 08:34 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Aircraft Walkaround Center update, new section | Robert Lundin | Military Aviation | 0 | August 30th 03 08:12 PM |
PACAF’s Hawaii air ops center sets new goals while adding 109 positions | Otis Willie | Military Aviation | 0 | August 20th 03 09:44 PM |
