"Robert M. Gary" wrote in message ... On Dec 27, 1:14 pm, Matt Whiting wrote: Phil wrote: I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...642-d205-411d-... Phil What do you want to bet that the brakes weren't set? That would be odd. Why would the brakes be set if no one was on board? Makes it a bit tough to tow. -Robert I hear chalks fix the problem. |
Anyone who watched the Bears game on Sunday and saw Brent Fabre say that it
was the coldest game he'd ever played it knows that it was an absolute ice rink at Midway. You could have set those brakes at a thousand psi and that sucker would have fancydanced across the ice in that wind. No chocks, only tiedowns could have kept that aircraft from moving. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "aluckyguess" wrote in message ... "Robert M. Gary" wrote in message ... On Dec 27, 1:14 pm, Matt Whiting wrote: Phil wrote: I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...642-d205-411d-... Phil What do you want to bet that the brakes weren't set? That would be odd. Why would the brakes be set if no one was on board? Makes it a bit tough to tow. -Robert I hear chalks fix the problem. |
"RST Engineering" wrote in
: Anyone who watched the Bears game on Sunday and saw Brent Fabre say that it was the coldest game he'd ever played it knows that it was an absolute ice rink at Midway. You could have set those brakes at a thousand psi and that sucker would have fancydanced across the ice in that wind. Wel, they would have been set at 3,000 PSI in fact, No chocks, only tiedowns could have kept that aircraft from moving. True. Bertie |
RST Engineering wrote:
No chocks, only tiedowns could have kept that aircraft from moving. Chocks aren't perfect. At my home field we often get violent downbursts from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200712/1 |
Robert M. Gary wrote:
On Dec 27, 1:14 pm, Matt Whiting wrote: Phil wrote: I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...642-d205-411d-... Phil What do you want to bet that the brakes weren't set? That would be odd. Why would the brakes be set if no one was on board? Makes it a bit tough to tow. Uh, to keep the wind from blowing it around? :-) |
Brakes should not be used to secure an airplane that is not attended, always
use chocks. An airline class airplane might be secured in strong winds with chocks and a heavy tug with the tow bar. "Matt Whiting" wrote in message ... | Phil wrote: | I know they call it the Windy City, but this is ridiculous... | | http://www.aero-news.net/index.cfm?C...-86c169181d87& | | | Phil | | What do you want to bet that the brakes weren't set? | | Matt |
Another reason to rely on chocks instead of brakes is the unreliability of a
hydraulic parking brake. The pressure can bleed off and release the brake after a bit. So the mistake might have been setting the parking brake instead of using chocks. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Matt Whiting" wrote in message ... Phil wrote: I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...-86c169181d87& Phil What do you want to bet that the brakes weren't set? Matt |
Phil wrote in
: I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...2-d205-411d-89 15-86c169181d87& Happens all the time. The fins are huge and some airplanes weathervane easily. It happened to one of our airplanes (727) years ago unbeknowst to the crew. The FE did the walkaround and noticed that the Radome had two nostrils. Further investigations revealed that the airplane had turned around in high winds and had ridden up on top of the GPU. The handling agent needed their GPU for another airplane, but found a 727 inconvieniently parked on top of it, so they lifted the nose of the airplane with a forklift in order to get it out. They went right through the radome and into the forward pressure bulkhead. I've had two airplanes weathervane on me, though, both undamaged. Bertie |
On Dec 28, 12:23*am, Bertie the Bunyip wrote:
Phil wrote : I know they call it the Windy City, but this is ridiculous... http://www.aero-news.net/index.cfm?C...2-d205-411d-89 15-86c169181d87& Happens all the time. The fins are huge and some airplanes weathervane easily. It happened to one of our airplanes (727) years ago unbeknowst to the crew.. The FE did the walkaround and noticed that the Radome had two nostrils. Further investigations revealed that the airplane had turned around in high winds and had ridden up on top of the GPU. The handling agent needed their GPU for another airplane, but found a 727 inconvieniently parked on top of it, so they lifted the nose of the airplane with a forklift in order to get it out. They went right through the radome and into the forward pressure bulkhead. I've had two airplanes weathervane on me, though, both undamaged. Bertie Interesting. I've never heard of this before. When it weathervanes, how does that work? Does it pivot around the mains and drag the nosewheel? Phil |
| Thread Tools | |
| Display Modes | |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Instrument Flight Rules | 1 | December 1st 07 06:05 AM |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Piloting | 1 | November 29th 07 08:44 PM |
| Ramp riders 5 | Paul | Aviation Photos | 0 | November 19th 06 11:09 PM |
| MMU ramp fee | Peter Gottlieb | Piloting | 25 | August 9th 03 01:49 AM |
| Flight TWA 800 was shot down/blown up by Al Quadea? | Tiger | Military Aviation | 0 | July 3rd 03 06:38 PM |
