Glider Shapes
Old January 4th 08, 11:13 PM posted to rec.aviation.soaring
Gary Emerson
Default Glider Shapes
brtlmj wrote:
Standard control system layout (no parallelogram stick)
Excuse my ignorance... what is a parallelogram stick?
Bartek
The standard configuration has the stick pivoting forward and aft as
well as side to side. The parallelogram stick SLIDES forward and aft,
but pivots side to side. Some people really like it, but it's a minor
design by numbers.
Old January 5th 08, 12:51 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
Bartek
design by numbers.
Excuse any appearance of anality, but the parallelogram sticks I've seen
in Mosquitoes did not *slide* forward and aft. Rather they moved
forward and aft on a 3-sided parallelogram linkage (having beautiful
bearing movements). There were 2 always-parallel, essentially vertical
pieces connected at the top by an always-horizontal piece. (Imagine a
cereal box end-on, long sides horizontal. [Approximate] mid-pitch
position would be short sides vertical. Forward would squash the 'gram
to the left (say); aft to the right.) I can't remember if the
Mosquito's hand grip attached to a 3rd upright welded to the top
horizontal, or extended aft and up from an extension of it.
Parallelogram geometry is such that vertical acceleration forces exerted
by one's hand in turbulence are muted due to near 90-degree interior
angles of the parallelogram in normal flight regimes. I thought it
quite elegant; it's certainly more 'turbulence benign' than a sharply
aft-pointed stick or S-curved stick, where positive G induces aft stick.
(Tangentially, George Moffat attributes at least one fatality to an
owner-added S-curved stick; apparently a strong negative gust at low
altitude and high speed resulted in an inadvertent pitch-down.)
My Zuni's side stick (and the sole HP-18 example I've seen) had sliding
pitch implementations rather than pivoting. Every sliding pitch
implementation I've played with (think Cessna/Piper power plane) has had
MUCH more pitch friction than that in Mosquito parallelograms.
Completely different concepts...
Regards,
Bob W.
Old January 5th 08, 12:53 AM posted to rec.aviation.soaring
Excuse MY ignorance !
Is there an advantage of the parallelogram configuration over the
conventional stick in the manufacture or in the handling ? For a
"universal" glider, the simpler it is with all the specs already given
(L/D, retractable gear, etc...), the more appealing it would be.
Eventually, though, ease of manufacture and price will be the
clinchers.
Cheers, Charles
Old January 5th 08, 04:24 AM posted to rec.aviation.soaring
noel.wade
clinchers.
Cheers, *Charles
Charles -
Supposedly there is an advantage in the arm movements required for
pitch adjustments. The Parallelogram stick means that if you feel a
sudden "G" force up or down, it won't likely cause you to move the
stick (whereas if a pivoting stick was already forward or aft some,
the "G" force would tend to make it go in that direction more with the
increased weight of your arm and the lag in response-time of human
muscles, and anatomical arrangements and whatnot).
However, I've tried a couple of Zuni sticks (the sliding kind) and a
DG-303 stick (true parallelogram) while on the ground. Both were a
bit weird, and I did NOT like the Zuni stick. My reasoning is this:
The straight push-pull arrangement requires that you move your whole
forearm to change the stick position (pitch up or down), whereas a
"traditional" stick just requires small wrist movements. Therefore I
think its easier to be sensitive and have fine-motor-control with a
traditional stick (wrist and hand muscles and nerves are WAY more
coordinated than forearm and elbow muscles). I also wonder about the
ability to feel "stick forces" through the push-pull or parallelogram
arrangements. Don't want to over-control at high speed or miss the
cues that you're slowing in a thermal turn and risking mushing or
stalling...
Just my $0.02 - I've only been flying for a couple of years at this
point, so I'm certainly no sage!
Take care,
--Noel
Old January 5th 08, 01:33 AM posted to rec.aviation.soaring
brtlmj
design by numbers.
Thanks!
B.
Old January 5th 08, 03:52 AM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Fri, 04 Jan 2008 14:06:14 -0600, Gary Emerson
[snip]
Room for 2+ batteries.
And for the standard 21st-century USAn arse.
rj
Old January 5th 08, 02:53 AM posted to rec.aviation.soaring
Mike Schumann
A Ballistic Recovery Chute.
Mike Schumann
"Brad" wrote in message
This sort of follows up on the future of soaring thread, but is more
focused on the sailplane design aspect.
Ok.....here is the scenario: the powers that be have decided that once
again the soaring community needs a sailplane that represents Joe
Sailplane Pilot. Joe sailplane pilot wants a sailplane that will get
him where he wants to go, but on a budget. Joe's a smart
guy..............he knows a thing or two about sailplanes; having
spent
considerable time poking and prodding their various bits and pieces.
He
decides he wants a composite ship, now he
want's......................what????
Here is where you fill in the blanks.............if for no other
reason
than to whack away at the keyboard.....or not!
Cheers,
Brad
Posted via a free Usenet account from http://www.teranews.com
Old January 5th 08, 12:48 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
A generous amount of panel space would be good.
IMO the minimum is space for 8 instruments (compass, T&B or AH, 2
varios, ASI, altimeter, radio, transponder or FLARM) and at least two
instruments will need to be 80 mm. It should also be possible to mount a
GPS or PDA without obscuring anything. This should work in nicely with a
roomy, comfortable cockpit if the panel is a Discus/ASW-20 style rather
than the DG/LS pedestal arrangement.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 5th 08, 02:05 PM posted to rec.aviation.soaring
rlovinggood
The sailplane of the future, heck, the sailplane of NOW should have a
finish that never requires sanding nor refinishing in order to
maintain it's performance. It should come out of the factory in
perfect condition and stay that way. Waxing would be "optional", and
only for those who need some quiet time with their glider.
Not that I'm trying to put refinishers out of business. No! There's
a lot of old ships that will still need refinishing for years to come,
but the NEW ones should have surfaces that will never need to be
refinished.
Oh yea, this glider of the future with the no-refinish surfaces,
should have performance capability better than ASG-29/Ventus 2/DG808/
LS10/eta/EB28, etc...
Ray Lovinggood
Carrboro, North Carolina, USA
Old January 5th 08, 04:14 PM posted to rec.aviation.soaring
nimbusgb
The basic list raised by Gary is good. But there's nothing wrong with
parellelogram sticks.
If its less than 1:40 I'm not interested. It should be 'expandable' so
an optional upgrade to 18m wings perhaps?
The World class was based on price and it flopped heavily so sorry
price is way down the list.
I dont see why a 1:40 ship cant be built for low cost. Surely its the
airfoil and materials technology that have come on. An 1:40 libelle
must be possible with a modern aifoil or a 1:45 LS4
Glider art Mal Soaring 2 December 13th 06 06:54 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Sea Glider OscarCVox Soaring 8 July 12th 04 12:08 AM
Calculating CL for various wing shapes ian .at.bendigo Home Built 0 August 28th 03 12:47 PM
