#11
I agree bob when it's -23 or colder out and your empty "full fuel" One pilot
310HP at SL. wow air is so dense! "Bob Gardner" wrote in message . .. I would recommend that you calculate Vx and Vy for various density altitudes and weights rather that memorize a number that is valid only at sea level on a standard day at gross weight. Bob Gardner "Jay Honeck" wrote in message news:Bj5gj.287919$Fc.120969@attbi_s21... This group's own Rick Durden published an article in AOPA Pilot this month entitled "Are you a good pilot?" In it, Rick raised many interesting points about things that can affect good piloting. Precision is part of being a good pilot, and it seems that good ones are always striving for perfection, even though they know it's unattainable. As pilots we are always one mistake away from bent metal (or worse) so this is a good thing. In my own flying, I strive to avoid the pitfall of becoming sloppy -- but I have to confess that it's easy to fall into bad habits. When you've droned VFR between Iowa and Wisconsin 500 times, it's easy to become sloppy about altitude -- I mean, who cares if you're off by 100 feet? And heading? Well, shoot, we're just following the magenta line on the display, right? Sloppy. Another example: Practice can make perfect, but repetition can also make you forget things, over time. Mary and I were recently discussing the fact that neither one of us could remember the precise V speeds for Atlas -- a plane we've flown every few days for six years. They've all become automatic and ingrained in our muscle memory -- but we'd have to look at the panel placards to tell the exact speeds. Sloppy. Interestingly, the definition of sloppy piloting has changed somewhat over the years I've been flying. It used to be that you could spot a sloppy pilot by the way they read a sectional chart; nowadays, many pilots don't ever look at a sectional, and a sloppy pilot is defined by how much they fumble with the knobs of their Garmin 1000... As I'm typing this, I'm trying to remember the last time I opened my sectional chart. With a Lowrance 2000c on the pilot's yoke, and a Garmin 496 in the panel, there is literally no reason for us to EVER open a sectional anymore. Both of those instruments have far more information than a chart could ever display -- yet I feel sloppy for not having opened my paper map in the last dozen or so flights. With two pilots on board, we have a good system to offset any inclination to get too sloppy -- it's called "spouse pressure". For example, if I fly a non-rectangular pattern, I'm sure to hear about it -- and vice versa. But even after 30 years we can't read each other's minds, and -- especially after a long lay-off from flying -- it's easy to develop sloppy thought processes. Piloting requires linear thinking, and much of it is habit developed over time, so it's the first thing to go when you haven't flown much. I'm interested in hearing what you do to combat the human tendency toward sloppiness? Any tricks that you might use, or methods you might employ? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
This group's own Rick Durden published an article in AOPA Pilot this month entitled "Are you a good pilot?" In it, Rick raised many interesting points about things that can affect good piloting. Precision is part of being a good pilot, and it seems that good ones are always striving for perfection, even though they know it's unattainable. As pilots we are always one mistake away from bent metal (or worse) so this is a good thing. In my own flying, I strive to avoid the pitfall of becoming sloppy -- but I have to confess that it's easy to fall into bad habits. When you've droned VFR between Iowa and Wisconsin 500 times, it's easy to become sloppy about altitude -- I mean, who cares if you're off by 100 feet? And heading? Well, shoot, we're just following the magenta line on the display, right? Sloppy. Another example: Practice can make perfect, but repetition can also make you forget things, over time. Mary and I were recently discussing the fact that neither one of us could remember the precise V speeds for Atlas -- a plane we've flown every few days for six years. They've all become automatic and ingrained in our muscle memory -- but we'd have to look at the panel placards to tell the exact speeds. Sloppy. Interestingly, the definition of sloppy piloting has changed somewhat over the years I've been flying. It used to be that you could spot a sloppy pilot by the way they read a sectional chart; nowadays, many pilots don't ever look at a sectional, and a sloppy pilot is defined by how much they fumble with the knobs of their Garmin 1000... As I'm typing this, I'm trying to remember the last time I opened my sectional chart. With a Lowrance 2000c on the pilot's yoke, and a Garmin 496 in the panel, there is literally no reason for us to EVER open a sectional anymore. Both of those instruments have far more information than a chart could ever display -- yet I feel sloppy for not having opened my paper map in the last dozen or so flights. With two pilots on board, we have a good system to offset any inclination to get too sloppy -- it's called "spouse pressure". For example, if I fly a non-rectangular pattern, I'm sure to hear about it -- and vice versa. But even after 30 years we can't read each other's minds, and -- especially after a long lay-off from flying -- it's easy to develop sloppy thought processes. Piloting requires linear thinking, and much of it is habit developed over time, so it's the first thing to go when you haven't flown much. I'm interested in hearing what you do to combat the human tendency toward sloppiness? Any tricks that you might use, or methods you might employ? I had two things I used to do. One on cross country and the other involving a slow roll; both involving the altimeter. On cross countries, I would attempt to hold the altimeter needle rock solid with thye hundreds needle on whatever number I was using for level flight without letting the needle come off the number on either side. For the slow roll, it's execution is done in the shape of the capital letter D; a normal D to the right and reversed to the left. I'd assign myself a roll altitude slightly above where I was and use that as my "pinned" altitude for the roll. I would do a pull to the roll set and initiate the roll with the hundreds needle pinned on that number. I would attempt to keep the needle pinned through the roll to the second knife edge, then return the airplane back down to level flight at exactly the initiating altitude. Generally speaking, if you can do these two things well, you have a fairly good hand and feel for the airplane. -- Dudley Henriques |
Sounds like a lot of work, but being a relatively low-time pilot, making
the cards is a way for me to familiarize myself with the details of each flight (I have a home office with all the equipment needed to make the cards, so that makes it easier, too), and then all the info is readily available for re-familiarizing each time. And my higher-time partner has said it's helpful, too, so it works well for us. I used to do something very similar to this, back in our pre-GPS, pre-two-pilot days. I found my "cheat sheets" to be extremely helpful, especially when flying into unknown or big-city airports. These sheets really help because they eliminate more than a few things to remember. As a new(er) pilot, I remember feeling like I was close to mental overload when flying into complex airspace, and anything you can do to minimize that load is definitely helpful. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
letter D; a normal D to the right and reversed to the left. I'd assign myself a roll altitude slightly above where I was and use that as my "pinned" altitude for the roll. I would do a pull to the roll set and initiate the roll with the hundreds needle pinned on that number. I would attempt to keep the needle pinned through the roll to the second knife edge, then return the airplane back down to level flight at exactly the initiating altitude. Hmmm... Maybe I'll forego using this particular technique, Dudley... :-) I had an interesting experience on a flight today that illustrates how easily "sloppy" can creep in. The temperature today soared to 52 degrees (and, man, I am here to tell you that 52 never felt so good), so -- after the morning's pea soup fog burned off -- we headed to the airport. It was my turn to fly out, so I went through my usual routine -- unplug the plane, pull it out, thorough preflight inspection. Once in the plane, I followed my usual "geographic checklist" -- upper left to lower right. I listened to AWOS, set the DG, set the altimeter to field elevation, did my run-up, and off we went. I was planning to do one touch & go and then depart the pattern to the south. There were two guys in the pattern, so I timed my departure to fit into the flow. Upon reaching my turn from crosswind to downwind, I looked at my altimeter and was surprised to see I had overshot my altitude by a full thousand feet! With the cool weather, and light on fuel, Atlas climbs like a homesick angel -- but something just didn't seem right... I looked around and realized that my sight picture matched what 1000 AGL *always* looks like. And it seemed unlikely that I had overshot my altitude by *that* much -- so I tuned in AWOS again to check barometric pressure. Sure 'nuff, I had set the altimeter precisely 1000 feet wrong. I reset accordingly, and continued the flight, chastened by discovering yet another way to fly sloppy. (Mary just laughed. I had caught her doing the exact same thing some years ago -- so now we're "even"...) We flew to a nearby town, swapped seats, and Mary flew us back -- where we met our son pre-flighting the rental C-150. Mary *finally* got her "chauffeured ride" with Joe at the controls today! :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Jan 6, 9:10*am, "Jay Honeck" wrote:
As I'm typing this, I'm trying to remember the last time I opened my sectional chart. *With a Lowrance 2000c on the pilot's yoke, and a Garmin 496 in the panel, there is literally no reason for us to EVER open a sectional anymore. Two GPSes should keep you away from the charts, but I read somewhere that the US military has the ability to turn off or set the sats to send out false signals. In that rare scenario, you'd be dead reckoning it though. Anyways, getting lost is not the end of the world. Wil |
that the US military has the ability to turn off or set the sats to send out false signals. In that rare scenario, you'd be dead reckoning it though. Anyways, getting lost is not the end of the world. I wouldn't be lost without the GPS, since we still keep the current sectional on-board. We may not refer to it much anymore, but it's still there if needed. And, last time I checked, my VORs still worked... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Jan 6, 9:19*pm, "Jay Honeck" wrote:
Two GPSes should keep you away from the charts, but I read somewhere that the US military has the ability to turn off or set the sats to send out false signals. *In that rare scenario, you'd be dead reckoning it though. *Anyways, getting lost is not the end of the world. I wouldn't be lost without the GPS, since we still keep the current sectional on-board. *We may not refer to it much anymore, but it's still there if needed. And, last time I checked, my VORs still worked... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993www.AlexisParkInn.com "Your Aviation Destination" Sounds like you've got it covered then. Cheers, Wil |
"Jay Honeck" wrote in news:g%fgj.24519$Ux2.24339
@attbi_s22: Two GPSes should keep you away from the charts, but I read somewhere that the US military has the ability to turn off or set the sats to send out false signals. In that rare scenario, you'd be dead reckoning it though. Anyways, getting lost is not the end of the world. I wouldn't be lost without the GPS, since we still keep the current sectional on-board. We may not refer to it much anymore, but it's still there if needed. And, last time I checked, my VORs still worked... Aren;'t you marvelous? Bertie |
letter D; a normal D to the right and reversed to the left. I'd assign myself a roll altitude slightly above where I was and use that as my "pinned" altitude for the roll. I would do a pull to the roll set and initiate the roll with the hundreds needle pinned on that number. I would attempt to keep the needle pinned through the roll to the second knife edge, then return the airplane back down to level flight at exactly the initiating altitude. That's rockin. What kind of plane? Why not a barrel roll or two as well? Heh. Keep it interesting. I'm very excited to get started on that stuff. Waiting to hear back from my old flight instructor. |
Piloting | Brandon[_2_] | Piloting | 3 | August 4th 07 10:37 PM |
Now this is piloting... | Gig 601XL Builder | Piloting | 26 | June 9th 06 05:27 PM |
Responsible Piloting | Icebound | Piloting | 2 | May 14th 05 04:18 AM |
GWB's piloting fun.... | David E. Powell | Military Aviation | 27 | May 8th 04 04:05 AM |
Ler's clean up some sloppy terrminology here | Bob | Rotorcraft | 1 | January 16th 04 05:03 AM |
