Mountain flying
Old January 13th 08, 02:24 PM posted to rec.aviation.soaring
Dave Martin
Default Mountain flying
Some years ago I bought a book in Spain called;
Les Pyrenees en Planeur by Alain Blachard.
It was excellently illustrated and although in French
with a French/English dictionary I was able to make
sense of it, with a little patience.
Having flown in thermal, wave and ridge in the relatively
flat UK. The book helps to make clear the different
techniques required when flying 'in amongst' real mountains
rather than over the tops as we tend to do.
A few years later flying in the Alps it provided a
useful reference.
Sadly I loaned it out and it has failed to return home:-)
I do not know it of is still available
Dave Martin
Ps Sorry if this posts twice
At 00:42 13 January 2008, Pigro wrote:
On Sat, 12 Jan 2008 21:49:01 +0100, John Smith
ASM wrote:
What would be the best book explaining mountain flying???
Jochen von Kalckreuth: Segeln über den Alpen
(I don't know whether there's a
translation)
To French: Au dessus des Alpes en planeur
(or, en planeur Au dessus des Alpes)
Excellent book
Aldo
Old January 17th 08, 05:33 AM posted to rec.aviation.soaring
fredsez
On Jan 15, 4:42*pm, "News" wrote:
Check outwww.greatwesternsoaring.com. *Fred has a great section on mountain
flying, and it's a helluva website, to boot.
"Paul Remde" wrote in message
news:Un8ij.296879$Fc.9720@attbi_s21...
Hi,
I am not an expert on mountain flying, but I do sell a book that looks
very good. *It was written by Mark Palmer and is part of Bob Wander's
"Gliding Mentor" series.
http://www.cumulus-soaring.com/books...WaveFlying.htm
Other weather related books are available he
http://www.cumulus-soaring.com/books...ct.htm#Weather
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
"ASM" wrote in message
Jacek
Pasco, WA- Hide quoted text -
- Show quoted text -
Advice: Go fly in the mountains. You will fly high in thin air. You
will need more space to turn. Read all the books. Pay attention to the
way air flows. Don't hit the rocks. Fred Robinson
Old January 17th 08, 02:15 PM posted to rec.aviation.soaring
Tony Verhulst
You can start he
http://www.mountainflying.com/flying_info_1.htm;It's written for
power pilots but the same rules apply ;
But the focus is different. Some years ago I was at a safety seminar
and, when discussing mountain waves, the lecturer admonished us to stay
away from them. During the break, I went up to him and said "excuse me,
but ....".
Tony V.
Old January 17th 08, 03:46 PM posted to rec.aviation.soaring
Bill Daniels
"fredsez" wrote in message
On Jan 15, 4:42 pm, "News" wrote:
Check outwww.greatwesternsoaring.com. Fred has a great section on mountain
Hi,
very good. It was written by Mark Palmer and is part of Bob Wander's
Good Soaring,
Paul Remde
Jacek
I vote with Fred.
I've spend my entire life flying in mountains and while it's not difficult,
there are subtile ways a mountain can bite you. When you get near big
mountains, visual effects plays tricks on your mind. Here's one that
doesn't require high winds.
As you approach a ridgline or peak at high altitudes, you have to keep part
of your scan on the airspeed indicator. At high altitudes on warm summer
days, true airspeed is significantly higher than indicated airspeed.
If you don't monitor your airspeed, your brain will start interpreting
ground speed as airspeed. As the fast moving terrain begins to fill your
visual field, you'll feel an overpowering sensation of speed. You're
scooting over the ground at an unbelievable speed and yet the ASI shows you
just above stall.
If you pull up to get away from the terrain, you stall and become yet
another statistic. If you do hit the ground in the high, thin air, you hit
fast and hard - it's rarely survivable.
Always leave yourself a downhill escape route. Don't glide into rising
terrain such that there's no way to lower the nose and dive out of the
situation. You don't want to be in a situation where you have to turn
while recovering from a low airspeed.
Bill Daniels
Old January 19th 08, 06:53 PM posted to rec.aviation.soaring
Bruce
There is no substitute for experience. Go and do it - if possible with expert
guidance. Reading the books helps, but having the mentor in the back seat for
direct feedback is priceless.
One excellent option if you can afford the travel and time is to go to Omarama
and do a mountain flying course with GlideOmarama or Southern Soaring. Have just
completed the latter - and learned a lot in a very short time, had a lot of fun
and flew in some of the most remarkable terrain. Of course I got the "worst
weather in living memory" - but still good enough for 11 hours in the Duo.
The Grand Prix pilots I spoke to also found the courses useful.
Southern Soaring is much smaller and more personal, suited me perfectly.
Bruce
Hi,
Good Soaring,
Paul Remde
Jacek
Old January 19th 08, 07:23 PM posted to rec.aviation.soaring
Eric Greenwell
expert guidance. Reading the books helps, but having the mentor in the
back seat for direct feedback is priceless.
Omarama and do a mountain flying course with GlideOmarama or Southern
Soaring. Have just completed the latter - and learned a lot in a very
short time, had a lot of fun and flew in some of the most remarkable
terrain. Of course I got the "worst weather in living memory" - but
Gavin is also planning courses in the USA in 2008 during our summer -
Minden, Ely, and Parowan - in case a trip to New Zealand (highly
recommended) is not possible. See http://www.glideomarama.com/usa/40
Mountain Flying Doug Piloting 3 November 9th 06 05:11 PM
Mountain flying time... [email protected] Rotorcraft 13 April 8th 05 10:12 PM
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 [email protected] Piloting 0 April 3rd 05 08:48 PM
Mountain Flying Course? Nicholas Kliewer Instrument Flight Rules 15 May 9th 04 05:29 AM
ADV: CPA Mountain Flying Course 2004 Dates [email protected] Piloting 0 February 13th 04 04:30 AM
