Stress Analysis
Old January 19th 08, 06:09 AM posted to rec.aviation.homebuilt
Default Stress Analysis
On Jan 17, 9:40*pm, "J.Kahn" wrote:
Charles Vincent wrote:
On Jan 14, 11:31 am, "J.Kahn" wrote:
If someone was to design a steel tube fuselage or a modification to a
steel tube fuselage, does anybody know of a relatively inexpensive and
painless way to get a stress analysis done, or software to do it?
John
Sorry, I got two links mixed up. This link
http://homepage.usask.ca/~ijm451/fin...resources.html
has references that are free or donation asked. The MYSTRAN software
is $200 for a 1 year license. Cheap in the software world.
Regards,
Bud
A Finite Element Analysis package is worse than useless without mastery
of the basics. *If you can't do it by hand, what you get from FEA could
get you or someone else killed. *EAA still sells "Stress Without Tears"
that takes you through the basic principles and simplified equations for
doing stress analysis of aircraft structures. *If you can't master that,
you aren't going to do much better learning the ins and outs of meshing
for FEA.
Charles.
Don't see it on the EAA site but it is available on Amazon. * Just what
I'm looking for.
Thanks for the input all!
John- Hide quoted text -
- Show quoted text -
If you are inclined to take a look at the real thing, not the Reader's
Digest version, you can download almost anything you want for free
from this site at NASA.
http://euler9.tripod.com/analysis/asm.html
There are also links to much more.
Regards,
Bud
Old January 19th 08, 06:59 AM posted to rec.aviation.homebuilt
Charles Vincent
Regards,
Bud
That is fascinating Bud and I have actually reviewed it before. Somehow
though I have missed the section on the stress analysis of a steel tube
fuselage.
The books recommended by myself and others are primers. As such they
give the reader the needed context of where to apply a euler equation to
an airframe and how to apply it.
Charles
Old January 19th 08, 04:30 PM posted to rec.aviation.homebuilt
Charles Vincent
Regards,
Bud
By the way, that is not in fact a NASA site, but a private site. The
NASA material can also be found on the NASA site though the last time I
looked. It is disheartening, but a lot of the NASA material (actually
NACA) has been made inaccessible in the last couple of years.
Charles
Old January 15th 08, 07:16 AM posted to rec.aviation.homebuilt
John
Now that the beers have worn off.....
No!
Bud
Old January 17th 08, 07:35 PM posted to rec.aviation.homebuilt
John
Consider posting this question to www.eng-tips.com
Wing stress program [email protected] Home Built 6 November 3rd 05 11:32 PM
Wing stress program [email protected] Home Built 0 November 2nd 05 04:49 PM
Welding prep, cutting notches and stress risers Michael Horowitz Home Built 11 August 21st 05 03:03 AM
stress cards? Ablang-Duff Military Aviation 4 December 27th 03 10:37 AM
Hinges under stress - mechanical engineering type question Corrie Home Built 21 August 6th 03 09:49 AM
