more confusion on cessna performance chart
Old January 15th 08, 05:57 AM posted to rec.aviation.student, rec.aviation.piloting
terry
Default more confusion on cessna performance chart
On Jan 15, 11:58*am, wrote:
So why would the takeoff distance required vary with temperature at
the same density altitude?, it goes against everything I understood
about peformance being a function of the air density.
Any help appreciated.
Terry
PPL downunder
I wonder if Cessna used formulas at all. I would think rather not.
They probably measured all of those values during the certification
process. I don't see how any aircraft could get its performance info
certificated based solely on mathematical calculations. You have to
test the plane for realiable data.
If I'm right and all those data points come from actual flight data
(and an average of that, too), then it's not a big surprise that
simple calculations regarding density altitude don't seem to make
sense.
Also density altitude calculations that consider only temperature are
at best approximations -- good enough ones for most conditions,
probably. But density altitude is also dependent on moisture content
of the air, which is perhaps even less known in a given air parcel
than temperature.
Has anyone on the list ever worked with or for Cessna who might know
how they generate their performance charts? Experimental measurement
-- or calculated "guess"?
good points, but the data looks too smooth to me to be entirely
based on experiment, although obviously some of it must be..
I dont think moisture is the issue. the effect of moisture on air
density really only becomes significant at higher temperatures and if
this were the factor in play
then you would expect the higher temperature data to have the worse
performance ( moisture lowers the density and even at 100% relative
humidity there is very little water in air at 0 dec C)
The data actually show the opposite effect. if you plot take off
distance vs density ht. you can see 4 distinct curves wtih from top to
bottom, density altitude calculated at 1, 10,20,30 and 40 deg C
respectively. They are all smooth curves which fit a binomial
equation quite nicely. No I think the use of a different method to
convert pressure altitude to density altitude seems like the best
explanation.
terry
Old January 15th 08, 06:21 AM posted to rec.aviation.student, rec.aviation.piloting
terry
On Jan 15, 9:02*am, TakeFlight wrote:
Rolling resistance of tires?
Hard to say what Cessna's assumptions are, especially when they didn't
include their formula, just a data set.
I would think rolling resistance would be less at lower temperatures.
rubber softens at higher temps and gets a better grip. the data shows
the reverse , at lower temps for the same density altitude the
distance required is higher.
Old January 15th 08, 06:18 PM posted to rec.aviation.student,rec.aviation.piloting
RST Engineering
There is a very excellent text with derived equations for almost anything
having to do with flight. "The Axioms Of Flight" by James Embree, ISBN
0-9601062-7-8. I have most of the equations plugged into either Excel or
Basic and mostly they agree with "manufacturer's data" within an rch.
Old January 15th 08, 06:24 PM posted to rec.aviation.student, rec.aviation.piloting
terry
having to do with flight. *"The Axioms Of Flight" by James Embree, ISBN
0-9601062-7-8. *I have most of the equations plugged into either Excel or
Thanks for the reference. BTW what is an rch?
Terry
Old January 15th 08, 06:44 PM posted to rec.aviation.student,rec.aviation.piloting
RST Engineering
It is a steeped-in-tradition engineering convention used to describe
something that is very, very close to the correct answer. It derives from
the very fine hair found on the lower-midsection of the adult female, of
which the red has been experimentally found to be the smallest in diameter.
It took centuries of trial and measurement to prove this experiment correct
"If you think you can, or think you can't, you're right."
--Henry Ford
Terry
Old January 15th 08, 06:53 PM posted to rec.aviation.student,rec.aviation.piloting
Jim Macklin
roflol, what kinds of experiments are/were needed to prove
the axiom?
"RST Engineering" wrote in message
to describe
It derives from
adult female, of
experiment correct
| Jim
| --Henry Ford
| Terry
Old January 15th 08, 07:36 PM posted to rec.aviation.student,rec.aviation.piloting
RST Engineering
"Jim Macklin" wrote in message
the axiom?
Don't get me started. You know how I am...
Two guys walking down the sidewalk and pass a good looking brunette.
"Ever sleep with a brunette?" "Yeah, I've slept with a few brunettes."
They pass a beautiful blonde.
"Ever sleep with a blonde?" "Yeah, I've slept with a few blondes."
They pass a KNOCKOUT redhead.
"Ever sleep with a redhead?" "Not a wink."
to describe
It derives from
adult female, of
experiment correct
| Jim
| --Henry Ford
| Terry
Old January 15th 08, 09:05 PM posted to rec.aviation.student, rec.aviation.piloting
Ken S. Tucker
Terry
PPL downunder
sense.
than temperature.
explanation.
terry
http://en.wikipedia.org/wiki/Density_altitude
http://en.wikipedia.org/wiki/Pressure_altitude
Humidity feeds into "density altitude" because water
vapour molecule H2O has density ~ 10 compared to
Nitrogen N2 ~ 14 *at equal pressures*.
I'm guessing: but I get the impression that the onset
of turbulence over wings was also dependant on temp-
erature, even when the density altitude is the same.
In Quantum Theory that makes sense.
To start, warm air is more chaotic than cold air at the
molecular level, and the chaos *seeds* the turbulence.
You know, hot fluids are less viscous than cold and so
less sticky. That's likely a secondary correction.
Regards
Ken
Old January 15th 08, 11:06 PM posted to rec.aviation.student,rec.aviation.piloting
RST Engineering
O ??????
--Henry Ford
correct {;-)
ORCH
Old January 16th 08, 12:02 AM posted to rec.aviation.student,rec.aviation.piloting
Matt Whiting
Stiff tire sidewalls are harder to flex and thus absorb more energy in
the process. This is why radial tires, even though they flex more, have
lower rolling resistance than bias ply tires. It isn't intuitive, but
it is reality.
Matt
Confusion Jon Woellhaf Instrument Flight Rules 85 December 29th 07 12:45 AM
Confusion Plus Kevin Berlyn Home Built 1 March 6th 05 07:40 AM
Cessna 150 with 150hp engine performance The Ponderosa Owning 0 September 18th 04 07:14 AM
confusion G.A. Seguin Soaring 0 July 14th 04 01:08 AM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 09:04 AM
