Heathrow = Thrust Reversers deployed
Old January 20th 08, 02:34 AM posted to alt.disasters.aviation,rec.aviation.piloting
Mxsmanic
Default Heathrow = Thrust Reversers deployed
Eeyore writes:
It does. But both the relevant RR and GE engines use FADEC which requires software.
Neither engine has a mechanical throttle. It's controlled ENTIRELY by electronics.
Is the FADEC part of the engine or a separate box in the cockpit or elsewhere
(like an autopilot)?
Boeing never should have made the Airbus mistake.
Old January 20th 08, 02:48 AM posted to alt.disasters.aviation,rec.aviation.piloting
Bertie the Bunyip[_22_]
Mxsmanic wrote in
Eeyore writes:
requires software. Neither engine has a mechanical throttle. It's
elsewhere (like an autopilot)?
He doesn't fjukking know an more than you doo, idiiot.
Bertie
Eeyore[_2_]
Mxsmanic wrote:
Eeyore writes:
At least part of the FADEC system is installed right next to the engine itself. It's a
*system* not just one box.
FADEC happened long ago. It's nothing to do with Airbus. Do you think mechanical linkages
are any more reliable ?
Graham
Old January 20th 08, 02:55 AM posted to alt.disasters.aviation,rec.aviation.piloting
Mxsmanic
Eeyore writes:
I was thinking about the general move to fly-by-wire in recent Boeing
aircraft.
Do you think mechanical linkages are any more reliable?
Absolutely. How often have mechanical throttle linkages for all engines
broken simultaneously in non-fly-by-wire airliners?
Old January 20th 08, 03:01 AM posted to alt.disasters.aviation,rec.aviation.piloting
Eeyore wrote in
Mxsmanic wrote:
Eeyore writes:
engine itself. It's a *system* not just one box.
Nope.
mechanical linkages are any more reliable ?
Fjukkwit planespotter. At least you've flund a little friend at your same
level.
Bertie
Old January 20th 08, 03:02 AM posted to alt.disasters.aviation,rec.aviation.piloting
Mxsmanic wrote in
Eeyore writes:
aircraft.
Why, you don't fly anyway...
Bertie
Old January 20th 08, 03:09 AM posted to alt.disasters.aviation,rec.aviation.piloting
Eeyore[_2_]
Mxsmanic wrote:
Eeyore writes:
aircraft.
Why just Boeing ?
Absolutely.
They're not.
Graham
Old January 20th 08, 03:12 AM posted to alt.disasters.aviation,rec.aviation.piloting
Eeyore wrote in
Mxsmanic wrote:
Eeyore writes:
aircraft.
Why just Boeing ?
Oh this should be good.
Absolutely.
They're not.
Very good.
Bertie
Old January 20th 08, 09:59 AM posted to alt.disasters.aviation,rec.aviation.piloting
Guybrush Threepwood
Mxsmanic wrote:
Eeyore writes:
Please remark that the so called "FADEC" is part of the engine and is mounted on the engine normally. It does not belong to the
aircraft manufacturer. There are other computers in the aircraft side to calculate the inputs to the FADEC. These computers
calculate the thrust demand and are giving this to the engine's FADEC.
Hope this helps.
Gruß Guybrush
Mails landen im Mülleimer!
Old January 20th 08, 10:01 AM posted to alt.disasters.aviation,rec.aviation.piloting
"Guybrush Threepwood" wrote in
Mxsmanic wrote:
Eeyore writes:
mounted on the engine normally. It does not belong to the aircraft
calculate the inputs to the FADEC. These computers calculate the
Hope this helps.
Got Grog?
Bertie
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 1 January 19th 08 08:58 PM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 17 January 19th 08 08:57 PM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 3 January 19th 08 08:57 PM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 1 January 19th 08 06:35 AM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 2 January 19th 08 06:33 AM
