#11
"Errol Cavit" wrote in message ...
"robert arndt" wrote in message om... snip But as the dedicated air superiority fighters started having to double as attack aircraft the now idiotic F/A designation is applied to purpose-built multirole aircraft like the F/A 18 Hornet and F/A 22 Raptor while the multirole capable F-16 Falcon and F-15E Strike Eagle remain under the F designation. I think our designation system is in need of redefinition. No, it needs for the system to be followed. There is an excuse for the F/A-18, Actually the new revised designation of the erstwhile F/A-18E is now the FREAK-18E; the changed designation being considered more reflective of the range of capabilities that aircraft possess - fighter, reconnaissance, electronic warfare, attack and aerial refueling. but not for F/A-22 (_reason_ yes, excuse no). AIUI the system defines aircraft with F and A roles as F's Why not use an MR designation for MultiRole aircraft? You mean like the M? e.g. MH-53E, MH-60R, MH-60S. Don't know if it can be used as the 'primary' letter, and can't be bothered looking in the FAQ to check. I suggest the following changes: snip suggested over-long designation system Currently Q is drone. Some changes in this area would probably be useful before too long. |
In article , David L.
Pulver wrote: Also, USAF tactical aviation doesn't like calling anything an "attack" aircraft so aside from the A-10 (clearly not a real modern fighter, being subsonic, even if it can carry a few sidewinders!) we get things like F-105 ("It's a fighter because it's got a gun and is supersonic, even if it's not used as one"). The Harrier and such get in the way a bit, but Sea Harrier at least has an air-intercept radar, while the other types are more attack aircraft Well, in the US, Harriers are designated AV-8 - so attack, not fighter. In the UK, they are Harrier GR.x (x being the mark number), for ground attack and recce - so, still not fighters. The Sea harrier is designated FA.2, since it's got a realistic air combat role. Aetherem Vincere Matt -- To err is human To forgive is not Air Force Policy |
![]() Well, in the US, Harriers are designated AV-8 - so attack, not fighter. In the UK, they are Harrier GR.x (x being the mark number), for ground attack and recce - so, still not fighters. The Sea harrier is designated FA.2, since it's got a realistic air combat role. I think that if the USAF had adopted the harrier, it would have an F designation, or at the very least F/A. The USAF simply doesn't like to recognize the concept of an attack aircraft. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
![]() "Cub Driver" wrote in message ... Well, in the US, Harriers are designated AV-8 - so attack, not fighter. In the UK, they are Harrier GR.x (x being the mark number), for ground attack and recce - so, still not fighters. The Sea harrier is designated FA.2, since it's got a realistic air combat role. I think that if the USAF had adopted the harrier, it would have an F designation, or at the very least F/A. The USAF simply doesn't like to recognize the concept of an attack aircraft. all the best -- Dan Ford With the system used "U.S. Joint Aircraft Designation System of 1962", faults aside, how does the USAF have this choice? Regards, Tex Houston |
![]() With the system used "U.S. Joint Aircraft Designation System of 1962", faults aside, how does the USAF have this choice? By not adopting the aircraft, or by redesigning and redesignating it. Has the USAF adopted an attack aircraft since the A-10 was rammed down its throat? all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
On Fri, 26 Dec 2003 05:25:11 -0500, Cub Driver
wrote: Has the USAF adopted an attack aircraft since the A-10 was rammed down its throat? all the best -- Dan Ford Difficult to let that urban legend prevail without comment. The A-10 was definitely not rammed down any metaphorical AF throat. It was the product of a well designed competition between A-9 and A-10 to build an updated A-1; an airplane with high survivability, close-in accuracy, heavy payload, and good anti-armor capability. The value of such an aircraft had been conclusively demonstrated in SEA and the application for such a type in European NATO Fulda Gap scenarios was obvious. (The initial deployment to Ben****ers/Woodbridge with six FOLs in Germany is illustrative.) Repeat again after me: 1. The USAF recognizes CAS as a mission. 2. The A-10 is a valued aircraft (despite the fact that lots of fighter pilots think Vipers or Eagles are more glamorous.) 3. Folks who fly or have flown the A-10 like and respect it. 4. It has been very successful over the years. 5. The USAF recognizes CAS as a mission. Lather, rinse, repeat. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
![]() It was the product of a well designed competition between A-9 and A-10 to build an updated A-1; Which competition was rammed down the Air Force's throat! Crikey, Ed, have you looked at Campbell's The Warthog and the Combat Air Support Debate ? www.warbirdforum.com/warthog.htm all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
On Sat, 27 Dec 2003 06:15:34 -0500, Cub Driver
wrote: It was the product of a well designed competition between A-9 and A-10 to build an updated A-1; Which competition was rammed down the Air Force's throat! Crikey, Ed, have you looked at Campbell's The Warthog and the Combat Air Support Debate ? all the best -- Dan Ford I'm always reluctant to base an interpretation of a complex issue on a single revisionist author, particularly one that writes more than 20 years after the events. I recently mentioned to BUFDRVR that Clodfelter on Linebacker II is not the only opinion as well. I was active duty during the period of adaptation of the A-10, including both the design competition and the operational deployment in Europe, where I was in Hq USAFE. Later, I went through AGOS and served as ALO to the 2nd Bde, 4th ID where we employed and integrated the A-10. I also had the opportunity to participate in defensive A/A training for the A-10 RTU at Davis-Monthan. And, after retirement from active duty, I worked for Northrop Aircraft Division, where we still had the A-9 files available for program review. Who was doing the throat ramming? It certainly wasn't Congress, which has little clue about operational requirements. Was it the Army? They have been a co-equal since 1947, so they weren't in a position to ram. AF recognized a need for a CAS aircraft, an anti-armor platform, a long-endurance, heavy lifter for battlefield support and a replacement SAR aircraft. It all came bundled in the A-10. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
On Sat, 27 Dec 2003 15:47:17 GMT, Ed Rasimus wrote:
And, after retirement from active duty, I worked for Northrop Aircraft Division, where we still had the A-9 files available for program review. Having has access to the paperwork for the A9, how did it rate IYHO ? Interesting that the otherside went for a similar planform for the Su-25. greg -- Once you try my burger baby,you'll grow a new thyroid gland. I said just eat my burger, baby,make you smart as Charlie Chan. You say the hot sauce can't be beat. Sit back and open wide. |
Questions Regarding Becoming a Marine Fighter Pilot. ? Thanks! | Lee Shores | Military Aviation | 23 | December 11th 03 10:49 PM |
Veteran fighter pilots try to help close training gap | Otis Willie | Military Aviation | 0 | December 2nd 03 10:09 PM |
Legendary fighter ace inspires young troops during Kunsan visit | Otis Willie | Military Aviation | 1 | October 9th 03 06:01 PM |
48th Fighter Wing adds JDAM to F-15 arsenal | Otis Willie | Military Aviation | 0 | July 22nd 03 09:18 PM |
Joint Russian-French 5th generation fighter? | lihakirves | Military Aviation | 1 | July 5th 03 01:36 AM |
