I am in the throws of my annual on the aircraft. This year I have
several things needing fixing and one is the leaky fuel selector. Well, let me tell you that is no easy job. I had to take a lot of the plane apart to get to it. What was Cessna thinking when they designed the placement of the fuel selector. I finally got it out and the A&P is going to replace all the o-rings, etc. I guess it will be fun again for the re-installation process. Anyone else go through this? You have to have small hands and stubby wrenches. -- Regards, Ross C-172F 180HP KSWI |
On Jan 28, 9:37*am, Ross wrote:
I am in the throws of my annual on the aircraft. This year I have several things needing fixing and one is the leaky fuel selector. Well, let me tell you that is no easy job. I had to take a lot of the plane apart to get to it. What was Cessna thinking when they designed the placement of the fuel selector. I finally got it out and the A&P is going to replace all the o-rings, etc. I guess it will be fun again for the re-installation process. Anyone else go through this? You have to have small hands and stubby wrenches. Hehehe, in my Mooney removing the fuel selector was probably the only "easy" thing I've ever done on the plane!! I often envy the 172 owners at annual. It takes me about 2 hours to decowl my Mooney, then another 4 to remove the inspection plates. -Robert |
My trick in close quarters is to consider wrenches expendable and use
a band saw to cut them down. Virtually all wrench handles are too long. I don't know why the tool manufacturers don't wise up......... |
On Jan 28, 6:10 pm, nrp wrote:
My trick in close quarters is to consider wrenches expendable and use a band saw to cut them down. Virtually all wrench handles are too long. I don't know why the tool manufacturers don't wise up......... Buy a couple of sets of cheap wrenches from Harbor Freight (US) or Princess Auto (Canada). Chop and heat and bend to suit special applications like that fuel selector. The 172's selector ain't really all that bad to get in and out. Some are worse. The worst thing about it is the need to completely defuel the tanks to do it. Some airplanes, before manufacturers got cheap, had shutoff cocks at the tank outlets, safety-wired open, and closeable for such maintenance as fuel valve repairs. Dan |
On Jan 29, 2:09*pm, Ross wrote:
wrote: On Jan 28, 6:10 pm, nrp wrote: My trick in close quarters is to consider wrenches expendable and use a band saw to cut them down. *Virtually all wrench handles are too long. *I don't know why the tool manufacturers don't wise up......... * * * * * Buy a couple of sets of cheap wrenches from Harbor Freight (US) or Princess Auto (Canada). Chop and heat and bend to suit special applications like that fuel selector. * * * * The 172's selector ain't really all that bad to get in and out. Some are worse. The worst thing about it is the need to completely defuel the tanks to do it. Some airplanes, before manufacturers got cheap, had shutoff cocks at the tank outlets, safety-wired open, and closeable for such maintenance as fuel valve repairs. * * * * * *Dan Yep, I had burned about half the fuel out of them but still a messy process. I got some 100LL down my sleeve and got a rash from it. We pulled the drains and let it go into a funnel and gas can. Drained fine until it started to run out then fluid dynamics took over and there was not a clean smooth flow. It was rather difficult given the two small inspection plates you had to work though. Then the fact that we had to take the handle position side off the pedestal to get the whole thing out. After this it should be good for another 40 years. In the Mooney community there were a few reports of selectors sticking. That's why I decided to remove mine at annual. $300 later I got the selector back fully overhauled. Probably the cheapest yellow tag I ever bought. -Robert |
On Jan 29, 3:09 pm, Ross wrote:
It was rather difficult given the two small inspection plates you had to work though. Then the fact that we had to take the handle position side off the pedestal to get the whole thing out. After this it should be good for another 40 years. Actually, Cessna's 200-hour inspection requirements call for removal of all those inspection plates in the floor, among many other things, so that cables and pulleys and fuel and brake lines and the structure and that valve can be inspected. Every time we buy another used 172 we find that none of this stuff has been looked at, sometimes in 30 years. The amount of gunk in the belly, wear and damage that's obviously been there a long time, and corroded fasteners all tell the story. We've found fuel strainers that appear to have never been apart. That's a 100-hour thing. We find cracked rudder hinge brackets, a common 172 fault, and cracked stabilizer forward spars, another common problem caused by people pushing the tail down to turn the airplane. The bottom end of the aft doorposts will crack, too, especially if operated off rougher strips, and you can't find that without taking the interior out. We find the bulkhead at the aft end of the baggage compartment cracked. We find the aluminum fuel tubing chafed halfway through above the doors and in the aft doorpost, caused by rubbing on the structure. If that starts leaking in flight you can't stop it. On those same tubes as well as the vent crossover line there are short pieces of rubber hose that need replacing every ten years or sooner. We find those rotten and ready to split. We very often find cracked exhaust components, something there's no excuse for whatever, since the cowling's off anyway to change the oil. We've found crossed trim and elevator cables in Citabrias that were installed like that, one at the factory, one after a major rebuild, and all frayed because they were rubbing on each other. That's a 100-hour requirement, looking at that stuff, and in neither airplane were they caught before we bought them. Good maintenance costs money. But it pays off in the end by avoiding having to replace badly-worn or damaged stuff that could have been caught and quickly remedied years earlier. It's like cancer: catch it soon enough and you might live a long life. Dan |
Yes, I went through that. The fuel selector would not shut off the fuel. A
new selector was price around $1000 ! I could not believe it. The replacement parts were very expensive but a lot cheaper than getting a new selector. I remember the tiny "retainers" were $60 each. The valve was over 30 years old. Things will wear out. Maybe now it is good for another 30 ! Tom Cummings 1973 Cessna 172M "Ross" wrote in message ... I am in the throws of my annual on the aircraft. This year I have several things needing fixing and one is the leaky fuel selector. Well, let me tell you that is no easy job. I had to take a lot of the plane apart to get to it. What was Cessna thinking when they designed the placement of the fuel selector. I finally got it out and the A&P is going to replace all the o-rings, etc. I guess it will be fun again for the re-installation process. Anyone else go through this? You have to have small hands and stubby wrenches. -- Regards, Ross C-172F 180HP KSWI |
Tom Cummings wrote:
Yes, I went through that. The fuel selector would not shut off the fuel. A new selector was price around $1000 ! I could not believe it. The replacement parts were very expensive but a lot cheaper than getting a new selector. I remember the tiny "retainers" were $60 each. The valve was over 30 years old. Things will wear out. Maybe now it is good for another 30 ! Tom Cummings 1973 Cessna 172M "Ross" wrote in message ... I am in the throws of my annual on the aircraft. This year I have several things needing fixing and one is the leaky fuel selector. Well, let me tell you that is no easy job. I had to take a lot of the plane apart to get to it. What was Cessna thinking when they designed the placement of the fuel selector. I finally got it out and the A&P is going to replace all the o-rings, etc. I guess it will be fun again for the re-installation process. Anyone else go through this? You have to have small hands and stubby wrenches. -- Regards, Ross C-172F 180HP KSWI Just finished annual and the overhauled fuel selector works fine. We bought the overhaul kit from McFarland. discovered them in the Cessan Pilots Association magazine. I guess I need to find what this costs? It was just several o rings and a cork gasket. -- Regards, Ross C-172F 180HP KSWI |
Broken fuel selector linkage | J McKernan | Owning | 4 | October 22nd 07 09:29 PM |
Fuel selector question | es330td | Piloting | 36 | October 8th 07 09:05 AM |
Fuel selector or two check valves? | Rob Turk | Home Built | 13 | July 1st 05 12:21 AM |
Fuel Selector Valve | Tom Cummings | Owning | 1 | March 7th 04 02:44 PM |
Fuel Selector Valve | Jay | Home Built | 5 | November 15th 03 11:16 PM |
