contest corner -- start anywhere
Old January 30th 08, 10:04 PM posted to rec.aviation.soaring
Tuno
Default contest corner -- start anywhere
Chris,
I really don't think it's all that complex. As Andy points out, what
you're suggesting might be even more complex.
I like the new rule because fundamentally, your distance in the first
leg is based on where you exit a three-dimensional cylinder. That is
not complicated at all. The extra language focuses on the two-minute-
under-MSH possibilities, but that, I believe, will rarely present
challenges to pilot or scorer.
This rule will have the effect of reducing crowding at the edge of
start cylinders. That alone is Good Thing.
2NO
Old January 31st 08, 09:39 PM posted to rec.aviation.soaring
2NO
I agree with this Ted's point. I believe in the west in particular
where you can get above MSH with some regularity you will see pilots
looking for the best thermal anywhere inside the cylinder and starting
out the top, or barring that finding a thermal just outside the
cylinder (probably more likely on the front side - but less
concentrated around the direct course line), making a start out the
edge and climbing out that way. Since you will now have starts over
the entire start area, I expect to see less traffic density rather
than more.
I am not worried about trying to engineer our way to preventing people
from bumping gaggles, they do it on course already and we will have
created as much as a 10 mile span to spread out the initial courseline
- that's a lot of territory. My guess it you will see less leeching as
well because it'll be harder to hang out at the likely exit point
since it could be almost anywhere.
9B
contest corner -- Soaring Magazine BB Soaring 8 February 15th 07 04:36 AM
Safety Corner-Nov/issue snoop Soaring 17 November 12th 06 10:13 PM
Did the F/A-22 Raptor turn the corner in 2003? Henry J. Cobb Military Aviation 75 January 15th 04 08:19 PM
VNE and the "coffin corner"? Jim Soaring 13 December 17th 03 06:07 AM
Aileron / flap corner drag ? tango4 Soaring 10 November 4th 03 11:08 AM
