Ricky wrote:
I am not an expert on aerodynamics so I do not know much about the pros & cons of a monoplane vs. a biplane or triplane. I've a re-kindled interest in the Red Baron recently and was looking at a Fokker Triplane replica picts & videos and doing a bit of reading about it's flying characteristics. I have not, however, read much about the "advantage" of 3 wings. I can guess that there would be quite a bit of maneuverability but also a lot of drag. Why a triplane? What are some of it's "advantages?" What are some "disadvantages?" I think you mentioned the main advantage: maneuverability. Also the British Sopwith Triplane and the German Fokker Dr.I appear to have had good climb rates relative to their biplane counterparts. If you think three wings are something, check our the multiplanes of Horatio Phillips: http://www.centennialofflight.gov/es...lips/DI113.htm |
![]() After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. Ricky |
Ricky wrote:
After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. I really doubt that was the reason as lift can easily be increased in a number of ways other than adding wings. I think structural strength was the primary reason for more wings in that era. Matt |
Matt Whiting wrote in news
![]() @news1.epix.net: Ricky wrote: After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. I really doubt that was the reason as lift can easily be increased in a number of ways other than adding wings. I think structural strength was the primary reason for more wings in that era. Not in this case. One of the advantages of a bipe is the rigging allows an extremely rigid structure with light weight and an ability to have a wing that is unrestrained by the need to conceal a lot of structure ( thick spar). The DR1 was revolutionary in that all the panels were canitlever. There was no external bracing except the roll wires between the cabane. The interplane struts were redundant. Bertie |
On Feb 2, 4:40*pm, Matt Whiting wrote:
Ricky wrote: After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. I really doubt that was the reason as lift can easily be increased in a number of ways other than adding wings. *I think structural strength was the primary reason for more wings in that era. Matt Well, hey, that's what I read from a guy who spent years of research on the Fokker Triplane and then built one himself from scratch. Maybe he's mistaken? I doubt it. Ricky |
Ricky wrote:
On Feb 2, 4:40 pm, Matt Whiting wrote: Ricky wrote: After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. I really doubt that was the reason as lift can easily be increased in a number of ways other than adding wings. I think structural strength was the primary reason for more wings in that era. Matt Well, hey, that's what I read from a guy who spent years of research on the Fokker Triplane and then built one himself from scratch. Maybe he's mistaken? I doubt it. I don't. If triplanes were more efficient we would see modern versions of them. Matt |
: Ricky wrote: On Feb 2, 4:40 pm, Matt Whiting wrote: Ricky wrote: After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. I really doubt that was the reason as lift can easily be increased in a number of ways other than adding wings. I think structural strength was the primary reason for more wings in that era. Matt Well, hey, that's what I read from a guy who spent years of research on the Fokker Triplane and then built one himself from scratch. Maybe he's mistaken? I doubt it. I don't. If triplanes were more efficient we would see modern versions of them. Well, in a way you do. Double slotted fowler flaps.... Bertie |
Ricky wrote:
On Feb 2, 4:40 pm, Matt Whiting wrote: Ricky wrote: After reading more on this I have found that the German's were very concerned with the ability of their aircraft to get above the enemy as quickly as possible. An attack from above (especially from out of the sun), was found to be an extremely effective method of victory. The amount of lift generated from 3 wings was found to enhance climb performance quite significantly, thus affording German pilots the abilty to attack from above as was desired. I really doubt that was the reason as lift can easily be increased in a number of ways other than adding wings. I think structural strength was the primary reason for more wings in that era. Matt Well, hey, that's what I read from a guy who spent years of research on the Fokker Triplane and then built one himself from scratch. Maybe he's mistaken? I doubt it. I'd be curious to see his research. It seems quite counter to every other authoritative source I've seen such as: http://www.airspacemag.com/issues/20...ron.php?page=1 Care to post your research source? Matt |
Triplane PWS Po-2 | fox | Aviation Photos | 0 | August 30th 07 08:08 AM |
Dr.1 triplane | Glenn[_2_] | Aviation Photos | 0 | June 16th 07 12:52 PM |
Dr1 Triplane | Glenn[_2_] | Aviation Photos | 1 | June 10th 07 04:07 AM |
